Question about Kodak EASYSHARE 5100 All-In-One Printer
My printer will not print with the black cartridge, it looks like it just dried up but I have changed it several times to be sure. It started after I was on vacation for a couple weeks. It was real light then quit altogether.
    Sergeant:
    Champion:
  • 208 Answers
You need to run the head clean procedure as follows:
1 Start the AiO Home Center.
2 Click Maintenance.
3 Click Printhead Cleaning
You may have to do it more than once.
Posted on Oct 03, 2009
My Pixma mp830 will not print black text. What do I do?
Hy, your printhead has dry ink inside. Try to put the print head in ditiled water ( NOT tap water) and live it over night. If that dosent help try in warm distiled water and live it over night. Be careful not to put the print head in the printer when is wet...let it dry for 2-3 hours. If still dosent work you need to replace the printhead.
May 25, 2012 | Canon PIXMA MP830 All-In-One InkJet...
I have a Brother MFC-6490CW that my husband purchased for me somewhere between one and two years ago. I just recently decided to use it, and the black ink would not print. I thought the original...
Power purge the machine:
Hold down the menu key. While still holding the menu key, unplug the machine and plug it back in. Do not let go of the key until the machine reboots and the screen says "maintenence". Hit the following keys: 7, 6, 4,black start. The machine will then go into "power purge" or deep clean mode for about 5-7 minutes. When complete hit: 99 to get out of maintanence and reboot. Be sure to have extra ink cartidges on hand as it does use up a lot of ink but this process works the best every time when the printer wont print
Feb 25, 2011 | Brother MFC 6490CW InkJet Printer
Just replaced black cartridge in my 2600n color laser. I have smudged about a half inch wide 2/3rds over the right of each page. It only smudges in black. I have recalibrated several times. Printed at...
If this just started after you replaced the toner cartridge, one would have to say that it is a bad toner cartridge.
Print something that smudges. Pull down the front cover and look at the cartridges. Pay attention to the top one(black).
Look at the drum on that cartridge. You should see the toner sitting there. Compare it to the other cartridges which should be clean.
Feb 08, 2011 | HP Color LaserJet 2600n Printer
Mfc-620cn prints all colors but black. went through clean process several times. any suggestions?
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | Brother MFC-620CN All-In-One InkJet...
Kodak esp 3250 won't print black. Changed cartridge and still won't print black. Just installed new printer.
I fixed my ESP 3250 print problems by removing the cartridges and print head. Using a Q-tip and warm water, added drops of water to each of the print head ink wells until the water / ink from the wells bled thru onto a cleanex. Did this several times. Dryed the print head fairly well. Then added a drop of water to each cartridge for each color. Reasembled and ran an alignment and to my surprise, it works! I hadn't used my printer in a while, so the ink had dryed on the felt for both the print head and cartridges.......
May 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Changed ink and now the printer wont print
The old ink has probably dried, plugging the jets. Try going through the cleaning cycle (several times if necessary). If it begins to print at all then let the printer set overnight and try cleaning again.
Fred
May 09, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Every cartridge prints except black. I have replaced the cart twice and still no joy.It shows as full on my computer. It just won't print.
Unfortunately, it's most likely that residual ink has dried and clogged the black print head. Plan on doing LOTS of cleaning cycles for the Black cartridge only if possible. It will consume lots of ink, so be prepared. After several cleanings and tests (as many as 10) you should see a gradually improving appearance of black. If not, try looking into the ink level counter to make sure it has reset to full as it shouls when you insert a new cartridge. If it is not, you sjould be able to change it. If that does not work, it's likely time for a new printer.
Apr 26, 2010 | Epson Stylus Multifunction Inkjet Printer/...
After replacing black ink cartridge, black ink will not print
check the cartridge contacts in the printer \
a lot of time they geet covered in ink this will not allow the cartridge to print properly and cause headaches
clean with a baby wipe or a paper towel with soap on it
dry thuoly with hair dryer and try again
Aug 03, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Print quality reduced.
You probly have a cloged cartridge. Most of HP's cartridges are water based ink. Take the cartridge that is not printing good, color or b/w, set the copper colored end, which is the print head on a dry paper towel. You should be able to see all colors as a solid line, or the black will show 2 solid black lines. The one that is not correct, take a paper towel and get it damp, and set the print head on the damp towel, be sure to fold the towel or it will stain the table you set it on. and let it set for a few minutes. Try the dry towel again. You may have to do this several times..You also should have software to prime your cartridages. After cleaning, try to prime the cartridge.
Feb 27, 2009 | HP DeskJet 5150 InkJet Printer
Black is not printing. Have changed cartridge twice and cleaned heads several times
Most likely the printer head is clogged either you have had a bad cartridge that was dried out and dried all the black ink in the brothers.
the only way to clear this up is take it to a place that cleans the head manually, or try top get to the printer head and clean them yourself.
Dec 04, 2008 | Brother Office Equipment & Supplies
Kodak EASYSHARE 5100 All-In-One Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
