Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
No cycle my washer fills up but does not start the wash cycle. when turned to other settings still nothing happens. only thing that works is when i change the load size to a larger one it adds more water. any help i do not know model
  • Anonymous Dec 23, 2007
    Same issue but slightly different etiology. If we open and slam the lid it will sometimes start at the water level originally selected. Time also seeems to play a part, problem seems to creep in after several loads. We have not touched the timer but still have the problem.
    Scholar:
  • 196 Answers
Solution #1
I believe this unit has a three wire switch. This type of switch must have full contact to operate in any mode. It is normal for a worn switch to work and then stop. If the unit won't start, a new switch will be needed .
Solution #2. The water level control may be bad. If it is the unit will fill with water and then stop.
Posted on Dec 30, 2007
    Problem Solver:
  • 11 Answers
Replace the timer
Posted on Dec 22, 2007
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Whirlpool GSQ9669LW1 washer. Originally Load Size was set to small. After water was filled to that level and machine started to work, wanted to add more water. Turned the Load Size knob to Medium, nothing...
You would have to start the wash cycle all over in order to get enough water for the med load size. Once the washer starts it cycle you have to cancel that cycle to start a new one. Hope this is a help to your question
Apr 24, 2014 | Whirlpool Washing Machines
Washer just started on fill cycle to start and continued filling
you have a hose that came loose to the pressure switch or the tub or you have a bad pressure switch
or the fill cup is blocked
Apr 22, 2009 | GE WJSR2070B Top Load Washer
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
Washer will fill up but after that nothing happens?
The lid switch is my first thing to check. There are two wires going to this switch, jump these together and this will tell you if it is working. The clicking noise won't tell you for sure.
Next, you need a volt meter to see if power is getting to the motor, if so, you have a bad motor.
Jan 23, 2009 | Kenmore Washing Machines
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
On/off button & non crease button flashing
Sounds like the pump and sump hose is blocked,Check both out
Oct 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
113 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
