Question about HP OfficeJet 6210 All-In-One InkJet Printer
My F4240 will print and copy but wont scan - HP OfficeJet 6210 All-In-One InkJet Printer
  • 21 Answers
Hi
I am providing you steps for Windows XP if your O.S is other then please reply.
Solution ;
Try copying if copying is fine then Scan through WIA.
If the scanning is successful, proceed with step 3. If scanning was not successful then I request you to perform the step given in step 4 and then perform step 3.
Step 3: Manually check for DIM
The digital imaging monitor must be running for the scan to function to work. The digital imaging monitor normally appears in the system tray in the bottom right-hand corner of the computer screen, next to the time.
If the digital imaging monitor appears in the system tray, go to the section Populate Destination List.
NOTE: If hpqtra08 is not on the list in the Startup tab, this indicates that the driver was not correctly installed. Uninstall and reinstall the driver.
9. Populate the Destination List with following steps:
a. Open the HP Solution Center.
b. Click on Settings --> Scan Settings --> Button Settings.
c. In the window opened, select "Scan to button" tab
d. Click the Destination List tab.
e. Click on each of the programs you want to appear in the scan to list.
f. Click the Add button. This moves the selected programs to the Front Panel Destination List.
g. Click OK.
h. Now try the scan to function from the all-in-one.
To save the above changes I request you to perform steps given below as Dest test.
1. Close all applications including HP Solution Center.
2. Open and run the DESTTEST file from the location:
C:\Programfiles\hp\digitalimaging\bin\Under Destination:
a. (Optional) Set the Category for the Destination List scroll
down menu on WEB_APP.
2. On the 5th option "Close Dest Test After sending to Destination", put a check mark and click on Save Results Before Exit.
3. Click on Exit in the bottom.
4. Now Open the HP Solution center, Click on Settings -> Scan Settings & Preferences -> Scan To Setup.
5. You will see all Button settings on the right side under the front panel destination List. In Case If not, click on Restore Defaults, click on Apply and click on Ok.
6. Push Scan To button on the unit you will see all the Destination List on the unit. Select the appropriate one.
Posted on Oct 04, 2009
2 Suggested Answers
Hp4620 wont copy pages
Hi try removing the print head, run it under the tap, dry, then replace the head and retry
Aug 12, 2014 | HP Officejet 4620 e-All-in-One Printer,...
Need a printer driver for my f4240 hp deskjet
Make sure you get the 64 bit version of the printer driver. Uninstall the printer drivers first then reload the 64 bit drivers.
Mar 16, 2017 | HP Deskjet F4240
I want to scan with hp deskjet f4240 all in one
Go for it!
Here's a link to an online pdf manual that will tell you how to scan with your machine...
May 04, 2009 | Office Equipment & Supplies
Need manual for HP Deskjet Printer F4240. Where
go to www.hp.com. click on the suport & drivers link, put in your printer model number and click the button, you should find it there.
Mar 16, 2009 | HP Office Equipment & Supplies
Lexmark X1185 won't scan.
I believe you have to push the scan button in order for it to scan and save. The copy buttons will only print either a black copy or a color copy.
Sep 12, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
HP OfficeJet 6210 All-In-One InkJet Printer Logo
429 people viewed this question
Seeker5211
Seeker5211
