Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
What is the ut out pressure, the motor keeps running past the red zone of the guage, when would it stop automatically?
    President:
  • 2,976 Answers
The cut out pressure is adjustable. Normally, it is not above 120 PSI. It is adjustable with a screw on the cutout switch.
Posted on Oct 03, 2009
I have SSR up series 15-30hp air copressor.The compressor will start and build pressure until the pressure gets to a certain reading on the gauge and the unloader valve begin to unload the air out. But the...
The compressor will run stop start or load unload. There is a switch for this. Make sure the right mode is selected.stop start for light use. Load unload for heavy. This mode keeps the starting and stopping to keep from burning up the motor. That is rated by stops per hour. They shouldnt be more than 10 times per hour
Dec 30, 2014 | Air Tools & Compressors
How much freon does a 1997 lincoln town car take
I'm pretty sure that model took 1.2lbs of 134a. If you have a newer recharge kit with pressure guage it will have a red section indicating high pressure not to fill past that point. If your freon is fully depleted (no cold air) I'd recommend running a can of stop leak/dye which has a flourescent dye to help locate leak if you don't have a leak detector which I'm guessing you may not. good luck
Jan 07, 2011 | 1997 Lincoln Town Car
I have a 2002 Chrysler Town & Country 3.8 litre. For the past two years we have had to have the air conditioner repaired under warranty. Unfortunately, it is doing the same thing but no longer under...
A/C work requries special tools and training, or risk serious injury. Have a qualified shop do this work, and live.
It sounds like you have hooked up to the high pressure side, extremely dangerous.
You need to know the pressures and tempratures, in order to correctly diagnose the system. Take it to a shop for this job.
May 30, 2010 | 2002 Chrysler PT Cruiser
Hi I have accord 96 when park temp guage past the
you can hook up your fan to a switch, fairly simple, auto zone would be able to explain it to you. so that when you turn on your car it automatically turns on and stays on, or so that you can turn on/off as you see fit. id probably have it run non-stop while car is going. i think they should all do that anyways, but they are trying to save you gas by having a sensor.
Mar 11, 2010 | 1996 Honda Accord
My compressor runs fine until it gets to about 100 psi. It then sounds like it labors hard, and then blows the circuit breaker. Any suggestions? It is a Crafstman 6 hp,k 30 gal, 150psi max single cylinder...
Never assume anything; check your pressure guage to make sure it is reading correctly. If a guage gets faulty, it could be showing less pressure than before, but everything else is the same, therefore the pressure is the same as always but the guage says different. If guage is good and 100 lb shows just as there is 100 lb in the tank, then maybe your electric line is not sufficient capacity and the motor starts to labor because it is pulling more energy than the line can produce and therefore everything heats up and the breaker pops. Have you moved the compressor or had a need to change the electric line and maybe it is too long or toosmall to handle what it did in the past ? Or, maybe the motor windings are old and getting deteriorated, thus allowing the motor to lose power and without the extra power to fight the pressure as it builds, the motor and line strain to work, and the breaker pops. Or, maybe the inlet and outlet valves on the head are weak and cannot hold the pressure in check as it builds in the tank thereby forcing the motor to work even harder against the pressure it already built-up; in this case, the head needs to be removed and new valves and springs replaced. Most compressor companies offer a valve kit just for this purpose. Goodluck, Macgvior
Jan 31, 2010 | Air Tools & Compressors
92 Corona auto - fill radiator with water - drive 90 minutes did 150 k no serious hills- temperature guage needle moved up after moving from 100 k to 50 k - no water - temperature guage just about in red -...
sounds like a coolant hose has a pin-hole or burst slightly open. pressure test cooling system or if you do not have a tester ----fill system with water and with bonnet open run engine untill it gets hot, builds pressure and starts leaking ,just keep an eye as where it leaks,
Dec 20, 2009 | 1992 Toyota Corolla
Mini Cooper temperature gauge goes to red zone, fan comes on
If you have a new thermostat, then your temp sensor is faulty. If sensor is new, then it is the wiring to sensor or problem with the ECM
Aug 25, 2009 | 2006 Mini Cooper
Oil pressure guage shows low to nothing
Hi there
You should check the oil pressure sensor/wiring should be located around the oil filter area usually.
If you can't see any obvious issues than post another question with you progress and ill help you work through it...
Mar 11, 2009 | 1990 Toyota 4Runner
Engine Stalls
for the oil pressure guage issue you need to change the oil pressure sending unit.
Dec 22, 2008 | 1999 Mercury Mountaineer
Oil pressure gauge reads past 80
now unless there is a very loud knocking of the motor which would mean that the engine's top end was not getting any oil I would say that your oil guage is sprung and needs replacing. a high pressure rating would indicate a restriction in the oil flow pasdt the sending unit or a plugged oil filter. if the filter were plugged you would know it because your enging would run tight in no time at all. replace the guage itself... please rate this........thanks
Sep 29, 2008 | 2005 Chevrolet Trailblazer Ext
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
69 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
