What is fl?not cooling because of filter check.
  • 45 Answers
Have you reset the filter sysbol on the remote
Posted on Oct 04, 2009
2002 Buick Lesabre while driving on Hwy car just started to slow. Pulled over and turned off the ignition. Restarted the car and it was fine from IA to FL then happened 3 more times in FL.
Check the oil, the low oil sensor will disable the ignition. Always check oil often when traveling. Change the air filter and the fuel filter before beginning a long trip.
Jun 14, 2017 | Buick Cars & Trucks
What does a FL code on great lakes spa mean
Has to do with the Flow, meaning it thinks or is not pushing enough water to safely turn on and heat the water. If you just changed the filter i would say go over the install papers and double check you did everything the same as it was or as it should be. Did you release all the air from the filter after you changed it? Also double check and try runing it with the valves fully open so its not restricted. 2nd most likely thing is something clogged up your piping when you changed out the filter but thats not too likely especially if the pump seems to be moving water fine. Lastly it might be a Flow/Pressure switch that ended up going bad at a perfect timing, but perfect timing makes me think its something to do with the filter.
Jul 10, 2015 | Pool & Spa
Washer is blinking the code fl.
Greg, best thing is to take the drain pump motor out. get to the impeller and check for any obstructions. Normally the filter is on the frame of the drain pump assembly.
Jun 16, 2010 | Kenmore 23822 Top Load Washer
Washer won't drain..like filter is clogged
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%@#$
Mar 27, 2010 | Kenmore Elite 21082
Not draining water, not spinning, error code FL
I THINK, (Not sure, but fairly convinced) that the error FL is a warning that your FiLter is blocked. When this happens, the pump can't drain the water in the alloted time that the machine has set to do it, so at the end of the pump out, there is still water left. Bacause of this, it won't allow the spin cycle to engage. You need to find your filter and clean it out. If this fixes the problem, make a regular habit of checking and cleaning the filter every month or so (Depending on how much washing you do... You will figure out a good time scale after you have done a few checks and decided how fast the lingt and rubbish builds up in the filter).
Oct 09, 2009 | Kenmore 24032\24036 Top Load Washer
My ac is carrier company window a/c its indicating {fl}
From the manual.
Message on the display(electronic models) E4 1. Failure in the inside temperature sensor E5 2. Failure in the outside temperature sensor FL 3. Dirty filter
To fix vaccume  (or wash your filter) then  hold down "Select"(or "Mode") and "-" (or "^") for 3 secconds.
Jan 30, 2009 | Carrier 52PQ307 Wall/Window Air...
97 jimmy wont start
If it starts with starting fluid, this means the firing and electrical is fine,however, its not getting fuel. I suggest trying the fuel filter first,but, its probably going to be the fuel pump.
Dec 29, 2008 | 1997 GMC Jimmy
Side by side kenmore refrigerator not cooling.Tampa FL.
HI thanks for your question. the problem you are having is that its not going into the defrost cycle. its not an expensive repair, probably $ 150. 00. unless you have the proper meter to check i would call a tech . but its more likely the defrost timer. or the defrost thermostat. thanks the appliance doc. please rate my answer. thanks.
Oct 08, 2008 | Kenmore 53642 / 53644 Side by Side...
What FL stands for?
FL means change filter media
Sep 13, 2007 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
