Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
To replace my modem on Cox Cable, my instructions say to scroll down to Control Panels on the Apple icon and then click TCP/IP. I can't find that on my Mac OSX, v. 10.5.8 laptop.
    Problem Solver:
  • 14 Answers
ON THE TRAY AT THE BOTTOM OF YOUR DESK TOP THERE SHOULD BE A PREFERANCE ICON OPEN THAT UP ONCE OPEN YOU WILL SEE NETWORK OPEN THAT AND AWAY YOU GO
Posted on Oct 04, 2009
I am trying to connect a Mac ibook to my cable modem
Use Network preferences to verify your TCP/IP settings and that Built-in Ethernet is your primary network interface. Follow these steps if you are using Mac OS X v10.5:
  1. From the Apple menu, choose System Preferences.
  2. From the View menu, choose Network
  3. Be sure that "Built-in Ethernet" has not the status Inactive listed below the entry in the list of network ports.
  4. Make sure Built-in Ethernet is the selected, or primary, network interface: Click the action button (gear icon) below the list of network port and choose "Set Service Order...".Services can be dragged to change order. Services are listed with descending priority.
  5. Select a network port in the list of port to configure it.
  6. Click Advanced..., then click the TCP/IP tab.
  7. Follow your ISP's instructions for setting up this pane. For more information, see Mac OS X: How to Connect to the Internet With Cable or DSL.
  8. Click OK when finished.
  9. If you have made any changes, click Apply Now.
If you are using Mac OS X 10.4
  2. From the View menu, choose Network.
  3. Choose Active Network Ports from the Show pop-up menu.
  4. Be sure that the checkbox for "Built-in Ethernet" is selected.
  5. Drag Built-in Ethernet to the top of the Port Configurations list to make it the preferred, or primary, network interface.
  6. Choose "Built-in Ethernet" from the "Show" pop-up menu.
  7. Click TCP/IP.
  8. Follow your ISP's instructions for setting up this pane. For more information, see Mac OS X: How to Connect to the Internet With Cable or DSL.
Jul 11, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Tip
Setting up a Router
Chapter 1: Connecting the Wireless-G Broadband Router
Hardware Installation
1. Locate an optimum location for the Broadband Router. The best place for the Broadband Router is usually at the center of your wireless network, with line of sight to all of your mobile stations.
2. Fix the direction of the antenna. Try to place it in a position that will best cover your wireless network. Normally, the higher you place the antenna, the better the performance will be. The antenna's position
enhances the receiving sensitivity.
3. Connect a standard Ethernet network cable to the Broadband Router’s Internet port. Then, connect the other end of the Ethernet cable to your Cable or DSL Broadband modem.
4. Connect your network PCs or Ethernet devices to one of the Broadband Router’s numbered ports with a standard Ethernet network cable.
5. Connect the AC Power Adapter to the Broadband Router's Power Socket and the other end into an electrical outlet. Only use the power adapter supplied with the Broadband Router. Use of a different adapter may result in product damage.
Chapter 2: Configuring the PCs
Overview
The instructions in this chapter will help you configure each of your computers to be able to communicate with the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/ IP) address automatically, so your PC can function as a DHCP client. Computers use IP addresses to communicate with the Router and each other across a network, such as the Internet.
First, find out which Windows operating system your computer is running.
You can find out by clicking the Start button. Read the side panel of the Start menu to find out which operating system your PC is running.
You may need to do this for each computer you are connecting to the Router. The next few pages tell you, step by step, how to configure your network settings based on the type of Windows operating system you are using. Make sure that an Ethernet or wireless adapter (also known as a network adapter) has been successfully installed in each PC you will configure.
Configuring Windows 98 and Millennium PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network icon.
2. On the Configuration tab, select the TCP/ IP line for the applicable Ethernet adapter. Do not choose a TCP/ IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/ IP appears by itself, select that line. Click the Properties button.
3. Click the IP Address tab. Select Obtain an IP address automatically.
4. Now click the Gateway tab, and verify that the Installed Gateway field is blank. Click the OK button.
5. Click the OK button again. Windows may ask you for the original Windows installation disk or additional files. Check for the files at c:windowsoptionscabs, or insert your Windows CD-ROM into your CD-ROM drive and check the correct file location, e.g., D:win98, D:win9x, etc. (if “D” is the letter of your CD-ROM drive).
6. Windows may ask you to restart your PC. Click the Yes button. If Windows does not ask you to restart, restart your computer anyway.
Configuring Windows 2000 PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dial-up Connections icon.
2. Select the Local Area Connection icon for the applicable Ethernet adapter (usually it is the first Local Area Connection listed). Double-click the Local Area Connection. Click the Properties button.
3. Make sure the box next to Internet Protocol (TCP/ IP) is checked. Highlight Internet Protocol (TCP/ IP), and click the Properties button.
4. Select Obtain an IP address automatically. Once the new window appears, click the OK button. Click the OK button again to complete the PC configuration.
5. Restart your computer.
Configuring Windows XP PCs
The following instructions assume you are running Windows XP with the default interface. If you are using the Classic interface (where the icons and menus look like previous Windows versions), please follow the instructions for Windows 2000.
1. Click the Start button and then the Control Panel icon. Click the Network and Internet Connections icon. Then click the Network Connections icon.
If you would like more information on setting up your connection, please post your questions and I will surely respond.
Also for any clarification, you can email me at titilayosodipe@live.com
Best regards.
Sholly-NG
on Jan 07, 2010 | Computers & Internet
Tip
Setting up a Router
in product damage.
Overview
the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/IP) address automatically, so
First, find out which Windows operating system your computer is running. You can find out by clicking the Start
2. On the Configuration tab, select the TCP/IP line for the applicable Ethernet adapter.9641e30.jpg
Do not choose a TCP/IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/IP appears by
3. Click the IP Address tab. Select Obtain an IP address automatically.a443500.jpg
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dialup
Connections icon.
Connection listed). Double-click the Local Area Connection. Click the Properties button.ea4fa3a.jpg
3. Make sure the box next to Internet Protocol (TCP/IP) is checked. Highlight Internet Protocol (TCP/IP), and click
Connection listed). Double-click the Local Area Connection. Click the Properties button.f2e300e.jpg
If you would like more information on setting up your connection, please ask me a question.....
Cheers.
on Jan 03, 2010 | Computers & Internet
Can`t obtain an IP adress from router or modem.
You may have already tried this but it is where I will start.
  1. Unplug the power cord from the router and the modem at the unit.
  2. Wait 30 seconds.
  3. Plug the power back into the modem.
  4. Plug th power back into the router.
  5. Give it a few minutes or until the lights are back up on the display.
This should prompt your ISP to reset you IP Address. If you need more help please let me know. Thanks (and please vote) J.H.
Dec 11, 2010 | Computers & Internet
MY COMPUTER WILL NOT DETECT MY MODEM. I AM TRYING TO GET CALLER ID APP. TO RUN ON MY MONITOR AND IT CAN'T FIND THE MODEM. I HAVE A WESTELL 6100.
THERE ARE A VARIETY OF REASONS A COMPUTER WILL NOT SEE THE ROUTER/MODEM.
1. THE CABLE BETWEEN THE COMPUTER AND THE MODEM COULD BE THE WRONG KIND. THERE ARE TWO KINDS OF CABLES A CROSS-OVER, TYPICALLY YELLOW WITH A CROSS OVER LABEL OR A STRAIGHT THROUGH CABLE. THE WRONG CABLE WILL JUST NOT WORK.
2. THE COMPUTER IS SET FOR A SPECIFIC IP ADDRESS AND GATEWAY WHICH IS NOT WHAT THE DEFAULT IS FOR THE MODEM. CHECK YOUR CONTROL PANEL, THEN NETWORK CONNECTION PROPERTIES, THEN THE TCP IP PROPERTIES. YOU WILL TYPICALLY HAVE TO SCROLL DOWN ON THE NETWORK PROPERTIES WINDOW TO SEE THE TCP IP. IF IT IS SET TO AN ADDRESS, WRITE THE INFORMATION DOWN THEN SET BOTH IP AND DNS TO BE OBTAINED AUTOMATICALLY.
3. THE MODEM COULD BE BAD, OR THE NETWORK CONNECTION ONYOUR COMPUTER COULD BE BAD OR HAVE A BAD DRIVER. CHECK THE SYSTEM, DEVICE MANAGER AND NETWORK ADAPTER TO MAKE SURE IT IS FUNCTIONAL, A YELLOW ICON INDICATES A PROBLEM.
CHECK IT ALL OUT, SEE WHAT YOU LEARN AND
IF ONE OF THESE ITEMS LEADS TO THE SOLUTION, PLEASE LEAVE FEEDBACK OTHERWISE SEND MORE INFORMATION BASED ON WHAT YOU LEARNED.
Feb 09, 2010 | Computers & Internet
Tip
Full details on how to set up your Wireless-G WRT54G Router
in product damage.
Overview
the Router.
Check for the files at c:\windows\options\cabs, or insert your Windows CD-ROM into your CD-ROM drive and
check the correct file location, e.g., D:\win98, D:\win9x, etc. (if “D” is the letter of your CD-ROM drive).
Connections icon.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
on Jun 28, 2008 | Linksys Wireless-G WRT54G Router
Dell Laptop is not pulling IP address
Connect it directly to the modem with the ethernet cable first...Windows will configure the Dell...then the wireless should work.
Feb 27, 2009 | Dell Inspiron 6000 Notebook
Netgear MR314
in product damage.
Overview
the Router.
Connections icon.
Jul 05, 2008 | NetGear MR314 802.11b
My router stopped working
Try to create a new connection.
in product damage.
Overview
the Router.
Connections icon.
2 linksys200 ? configurer sur le meme reseau
in product damage.
Overview
the Router.
Connections icon.
Jun 23, 2008 | Linksys Computers & Internet
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
387 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
