Question about Frigidaire ATF6000ES Front Load Washer
It takes forever to get a load washed could it be the timer?
    President:
  • 1,304 Answers
Probaly the saop
if your using more than a table spoon thats your issue
it will rinse till it detects no suds
Posted on Oct 05, 2009
Ge washing machine wsxh208a1ww, The dial seems to get stuck during all cycles. If you go out and manually turn the dial one click it will keeping going. But it takes forever to do a load of laundry since...
The bad news is that you most likely need a new timer. I get mine (used) from e-bay after looking up the parts at "Sears Parts" by model number. Sears will sell you new parts by model number for your GE.
Be blessed.
Nov 08, 2010 | GE Washer Washing Machine Timer WH12X1000
Hoover 700LB - fills as per normal and washes but cycle knob does not move, click or progress towards the next cycle therefore washes forever...timer perhaps and if so is it worth fixing?
Hi just read your posting.Does the timer move at all from the original position that you started it from?If it does not move at all then you need a new or reconditioned timer.If it does move but stops at a specific spot,What position does it stop at?Are you in Australia? If so I can give you the contacts on where to purchase a timer.Please reply and I can guide you on how to get the correct timer number for your machine.Looking forward to your reply.
Jul 24, 2010 | Hoover HTC243 Top Load Washer
I have a Hoover 550 MB Top Loader washing machine . The cycle won't move from wash to spin . it doesn;t progress out of wash cycle , it stays there forever .
Will the unit spin if you manually turn the timer dial to spin? If so, remove power, remove the clock motor from the timer, and inspect the clock and mating timer gearing for debris or damaged gear teeth. At the worst, replace the timer. You may be able to scrape or file the damaged teeth so that the timer will progress.
Oct 19, 2009 | Hoover HTC243 Top Load Washer
The machine takes forever to run loads its like the timer is not working
HI Doctor, Sorry no one can help you with this yet. Maybe I can. The timer has a small motor on it that may not be working. If there are two screws on the head on either side, remove these then flip the top up. Turn the timer on and look on the back of it. There is the motor to run the timer. Is it turning? you will see it moving if it is. If not, you may be able to get another from a used appliance dealer or a parts shop in your area. This is my idea. I hope it helps you
Joe
Aug 04, 2009 | Amana NTW5205TQ Top Load Washer
The washer takes forever to complete it will take
front load washsher do take longer to wash than top load but it should not take 2 hours on a short cycle. has it always done this
Jun 23, 2009 | LG WM-2277HW Front Load Washer
Touchpad--No Response
The "2H" is an error code indicating the control panel needs to be replaced.
May 08, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Cycle takes forever
The washer will run through the programe with or without the belt on.
Could be timer, or other possibilities,but not the belt.
You will have to investigate further.
Plz rate my comments.
Thanks.
Jan 03, 2009 | Roper RAS8445KQ Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
