Question about Sport & Outdoor - Others
A short that drains the battery
We were camping and our power went out. we bought a new inverter and a new battery. The battery kept going dead after testing the electrical system the two air wents, one in bath and one in kitchen. we found the little fans that pulls air our had a short, there is something else that is on that circut does anyone know what else it could be. many thanks, phyllis
we have a 2001 fleetwood prowler travel trailer
I had a similar problem, it took 2 dead batteries to figure it out. to make a long story short check the brakes, ours had the emergency brake pull out .. the one that is connected usually via cable to the tow vehicle. this engaged the brakes as long as the battery was charged when the battery was dead no brakes.. your brakes may still be engaging if they are worn and just not locking the brakes up.
Posted on Oct 06, 2009
Power to amp but no light happened when my battery went dead replaced
the power amp has a short in the unit and it drain everything out of the battery, that why the battery is dead. it is really possible that a capacitor is open or shorting out cause the unit to drain the battery.
Mar 26, 2014 | Volfenhag ZX-8400 Car Audio Amplifier
New battery went down to 5volts over a two day period
You have dead short in your system draining the battery.
Unless you have a place where the truck was wrecked and the wires were pinched causing a short circuit, the other thing that often causes this is a short in the alternator.
God bless your efforts to find the problem.,.l
Aug 28, 2017 | 2010 Ford Ranger
Hello, I have a 1986 Jeep Comanche, 4 cylinder 4x4 5 speed that i just bought used. The battery is brand new, same with cap rotor wires and the alternator i just bought. the jeep kept draining the battery...
If you mean it is going dead while sitting you might have a short or another issue drawing power from the battery. take your truck to your local battery warehouse/store the should have a meter thet will tell you if something is drawing on your system. It could be something simple, like maybe the mercury switch on your under hood light is bad and the light is not turning off thus running your battery dead over night.
Mar 12, 2011 | 1987 Jeep Comanche
I purchased the motorized bumper boat float. We
didnt specify model --generic answer---check and lube motor sounds like bearings dry --but [should have notified] notify the company of the motor problem may have been a fix or possible replacement if warrantied ---
Apr 13, 2017 | Excalibur Toys
Battery goes dead overnight on four occasions
I dont think the dealer knew what he was doing ,your altenator has 6 diodes inside it and the are a one way check valve for current,If one fails no light will come on because it is still charging,But will drain your battery,I hope this helps you and have a merry x mas and please dont forget to vote on this solution
Dec 19, 2009 | 2009 Hyundai Genesis
Battery died while parked 1995 Grand Cherokee Laredo
no when vehicle is off only a few things can drain the battery usually dome lights or headlights
Aug 18, 2009 | 1995 Jeep Grand Cherokee
Yamaha ef2400 inverter does not start.
it is possible the batteries are dead or needs to be charged
May 28, 2009 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Motor will not run with the choke off & rpm's go up and down
sounds like your fuel has gone stale, drain tank and put in fresh fuel, with no additive, better to drain the tank after use than use additives
Feb 15, 2009 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Sport & Outdoor - Others Logo
169 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
