Set up to play dvd movie on TV
I forgot how to set my RCA TV for playing a DVD movie on my new Toshiba DVD Player SD-4000. The fellow at the store told me, but I forgot.
  • 8 more comments
  • Dennis Renner
    Dennis Renner Dec 22, 2007
    I have the RCA cable up but the TV settings must not be right for taking the signal. Nothing comes through. It seems to be a setting issue for the TV. Someone said press Aux several times on the TV remote and it will find the new divice and override TV but that doesn't happen. Also, it has nothing to do with the old way for video, involving setting the channel right. It may have something to do with the menu for the TV which has a channel option of two settings but none of these seems to make a difference. So what is it?
  • Dennis Renner
    Yes. And two months ago when a store person told me how to set it up these were connected right and I the dVD worked. I forgot what else I had to do to get the TV to take the signal.
  • Dennis Renner
    I'm trying to get the settings right to play my Toshiba SD4000 dvd player through my RCA F27649 TV. I had it two months ago but forgot. The three color coded connection RCA cable is still connected the way it was when I knew how to set the TV to show the signal. I've tried using the remote and pressing aux. There must be some other setting problem addressed in the owners manuals I do not have.
  • Dennis Renner
    I have an rca F27649 . . . I don't see any aux 1, 2, or three options and only one choice for channel on the menue . . video and s video. Neither makes a different. I don't have another TV to try, but I can see how a new RCA cable could go bad in two months . . . Nobody has a manual to check?
  • Dennis Renner
    I tried the manual and found the instructions for using the remote useful, for example the who input button, but when I used it I got a promising screen instead of snow or black but it says "unusable signal."
    There is an explanation about programing the remote to your input devise . . . vcr or whatever and a page of codes but none for a Toshiba DVD. There is a Tosheba code of 5026. But I'm remembering that at one point two months ago I DID have a way to set up for using the DVD signal . . . I just forgot.
  • Dennis Renner
    I did check but I'll double check. You know, I didn't follow the auto-tuning page as you suggested because in the past that got me into auto tuning available TV or cable channels.
  • Dennis Renner
    Bingo, dear otacon, that seems to have been the variable once the manual you linked me to got me to the who-input button and the signal unusable lable. Now before I sign off and accept, can you tell me how to switch bank and forth from the DVD and TV? I'm almost afraid to experiment, it feels so good to have the DVD signal.
  • Dennis Renner
    But I didn't program anything with auto tuning. What I did was use who-input. Now maybe I should be able to simply toggle betgween TV and who-input. That is when I watch tv, I should have the TV button pushed. When I want to go to the DVD I should just go to who-input and try the options until the DVD player, which is already loaded, pops up the picture. Right?
  • Dennis Renner
    No. That didn't work. So how do I go back to watching TV?
    Maybe I just turn the dvd off; the signal stops blocking out the jTV signal and voila. I'll try that.
  • Dennis Renner
    OK. When I hear from you about what seems to work and you confirm it, as simple as it is, I'll accept and we'll be done. Now all I have to do is use the who-input and toggle between three options. One is the DVD one is "front" (no signal), and the other is TV. That was the solution. As simple as that, not all of the other information that applied to other connections. The manual got me to it, not anything from any expert, but your initiative in finding a close manual got me to the who-input button for which you deserve credit.
    Sergeant:
    Champion:
  • 231 Answers
Well first thing you should do to stop all this guessing ..Is try the dvd player on another tv if possible..if its working then problem is connections and or INPUT setting..if you have dvd in INPUT1 then set the tv to INPUT1
Posted on Dec 22, 2007
    President:
  • 1,950 Answers
You just need an RCA cable. Find the output from your dvd and connect to the input of your tv. The cable has three connectors in three colors...red/white/yellow. Res and white is audio and yellow is the video.
  • 9 more comments
  • Damen Wong
    Damen Wong Dec 22, 2007
    On each end of the cable are three connectors (red/white/yellow).
  • Damen Wong
    There should be nothing to set up except for switching to the channel to see the input from the dvd player. Usually youw need to switch to AUX like you said or AV (A/V). If your TV has more than one input there are more AUX/AV channels. For example if there are three inputs on your TV, then there would be AUX1, AUX2 and AUX 3.
  • Damen Wong
    Which TV do you have?
  • Damen Wong
    Make sure that you are connecting to the proper connectors. On the DVD it's the ANALOGUE AUDIO OUT (L/R) which are the red/white connectors and the VIDEO OUT jack which is yellow. I once by mistake connected to the VIDEO OUT (Y/PB/PR) component video jacks by mistake. Make sure you connected to the proper jacks like on the DVD and make sure it's an input and not out put (I also made that mistake in the past).
  • Damen Wong
    If the cables are connected properly then all you need to do is to find the right AV or A/V or AUX channel. If all fails, then there is a chance that the cable has malfunctioned and a new one is required.
  • Damen Wong
    Are you sure it's a F27649 and not a G27649?
  • Damen Wong
    If it's the G27649 here is the user manual (I couldn't find the F27649 manual)....check out page 36: auto tuning feature.
  • Damen Wong
    did you check that under the video input source menu that video input is selected and not s-video input?
  • Damen Wong
    After you programmed the DVD channel with the auto tuning...pressing the DVD button on your remote should take you to the DVD channel and to get out of that just key in another channel.
  • Damen Wong
    Yup, you are right.
  • Damen Wong
    When in regular tv mode...press who-input to switch to dvd...then pressing who input again goes back to where you were before you switched to DVD.
Cant figure out which cables to plug into which holes. only have red,yellow & white cables. have a plug-in for coaxial (orange)-do i need a coaxial cable. have an Orion tv w/a dvd player in it-but it...
rca video out on DVD player toshiba SD3960 av in on tv
yellow is video part of rca
red and white is audio cable part of rca
change input source to AV 1 on tv when wacthing dvd player
for a more detailed explanation a photo of back of dvd player and model number of TV would be helpful
Mar 05, 2018 | Toshiba DVD Player
DVD player won't play new movies
Try this
1.While the previews are playing, press the Menu Button on your DVD player remote to access the DVD's Main Menu.
2.Go to Scene Selection and press your Enter or Ok button on your DVD player remote.
3.Highlight Scene 2 and press the Enter or Ok button. This will start the DVD in Scene 2.
4.Use your rewind or reverse button on your DVD player remote to rewind back to the beginning of Scene 1.
Walt Disney Home Entertainment Technical Support
1-800-723-4763, Monday's 9:30-7:30 and Tuesday through Friday 9:30-6:30 CST
Excerpt from email tech support Walt Disney
Dec 07, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
We have a 23" Toshiba with a internal DVD player.
No,tv internal DVD player are not on sale by itself as a seperate unit,only can buy it from the tv corporations themselves and it not cheap and have to have experience to putting it in into the tv internal tv itself.The tv internal DVD player now,could be the laser eye data reader have problems reading mp3 and mp4 files on the DVD disc,which are video files.Now tries to play more than one DVD movies dic,tries like to play like 5 to 6 original DVD movies.One disc don't play tries another DVD disc.Tries this might forcing the laser eye reader to read DVD dics again and than might fix it to read video files again.Or just buy an external DVD player hook it up to the tv and play DVD disc on to the tv video modes.DVD players external devices are really cheap these day,like can buy new one for $40.
Mar 25, 2011 | Toshiba 23HLV84 23 in. TV/DVD Combo
Player will not start. it has power but the movie does not start. model number sd-p1600
This is not a TV problem? The sd-p1600 is a portable DVD player. Are you trying to connect it to your TV? Or is you Portable DVD Player not playing?
Jan 06, 2011 | Toshiba 42H81 42" Rear Projection...
My dvd player works and plays movies but i changed the video to s-video and now i can't see anything on my screen just able to hear movie play. how do i reset it back to normal video?
Make sure you're tv is set on S-VIDEO, not AV1 or AV2 or VIDEO 1 or VIDEO 2, etc... there's most likely a setting on your tv to select your input to S-VIDEO.
Oct 09, 2010 | Toshiba SD-4100 DVD Player
Can't play dvd-r or dvd+r
try to buy and play original dvd movies. when it play, it is how you burn your dvd, use some software which will automatically create dvd movies so you can play to your DVD player.. If not, try to clean DVD lens using lens cleaner. usually used DVDr will not play to DVD player.. try also to use new blank DVD
Aug 26, 2007 | Toshiba SD-1800 DVD Player
My Toshiba SD-3960 sound does not work.
First thing before a landfill is to go into the units menu and see if something in the audio got turned off if not then inspect the connectors on the back for breakage. Good Luck
Apr 02, 2006 | Toshiba SD-3960 DVD Player
Open Questions:
Televison & Video Logo
193 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
