Question about Black & Decker Garden
Cmm1100.... it's charged and i work the tw levers on the handle...is there something else i need to do....i pull back on the on handle and press the run handle forward and nothing happens
  • Chuck
    Chuck May 11, 2010
    If the lawn mower is not starting please check the following:
    Make sure the safety key has been inserted back into the mower after you removed it for charging.
    Make
    sure the safety key is not in any way deformed. If the key is deformed
    please contact one of our service centers to find out about getting a
    replacement key sent to you. After
    checking the key and making sure it is fully inserted and not deformed,
    try starting the mower again. If the mower is still not starting please
    try the following:
    Remove the
    safety key, turn the mower onto its side, and carefully try to turn the
    blade. The blade should turn easily with no audible noise. If the blade
    is difficult to turn or it will not turn this would indicate motor
    failure and you will need to get the unit into a service center.
    If
    the blade spins freely, turn the mower back over and make sure the
    battery is fully charged. When the mower is fully charged a green light
    should be displayed when the unit is plugged in. If the unit is fully
    charged, you checked all of the above and the unit is still not
    running, you will need to get the unit into a service center to
    be repaired or replaced.
  • 3 Answers
The problem is the switch under the key sometimes gets dislodged.
It happens to mine now and then.
I remove the cover 4 screws raise it up and carefully recenter the switch. then cover it again.
Pretty simple but annoying now and then.
Posted on May 12, 2010
I have a Poulan 600 series lawn mower n when I got to pull start my lawn mower it's locked up n won't let u get the full pull start to fire it up.
Probably the cable from your safety shutdown is broken. One way to tell is follow the shutdown cable from the top of the handle bar down to the motor which should be attached to a lever on the left hand side of the engine. When you pull the thin handle on top of the handle bar towards you the lever on the side of the engine should move back also.
Jun 03, 2015 | Poulan Garden
Why does my onity ht24 lock not open when the handle is pushed down? it always works when the handle is lifted up but almost never when the handle is pushed down.
The lever return spring might be weak or broken. Lift the lever slightly and then push down. If it opens, that's the problem. If it still won't open, something else might be broken or badly worn. The handle is pushed down far more often than it's pulled up.
Apr 29, 2014 | Locks & Locksmithing
Need to get door handle and window lever off 1963 pontiac tempest??
there is a special tool that slides in behind the crank and lever that pops the snap ring out the back side and they just pull off, then you put snap ring back on the handles and push them back on when ready
Jun 10, 2012 | Cars & Trucks
How do I put the saw on the pole
1. Remove battery from chain saw.
2. Separate main handle from chain saw
power head by pressing both release
buttons on main handle and pulling
apart. The release buttons are just in
front of the trigger.
3. Align rib on chain saw power head with
groove in power head adapter on pole.
4. Slide power head into power head
adapter until units "snap" together.
IMPORTANT: Both release
buttons on power head adapter must be
fully engaged.
5. Align rib on handle adapter on pole
with groove in main handle.
6. Slide main handle into handle adapter
IMPORTANT: Both release buttons
on main handle must be fully
engaged.
7. Slide battery onto main handle until
release buttons "snap" together.
Be sure the battery is charged.
To extend the pole:
1. Loosen the clamping
lever. Pole will slide
freely.
2. Pull inner pole section out to desired
length of extension.
3. To lock pole in position, tighten clamping
lever.
Sep 12, 2011 | Remington Cordless 18-Volt 8-Inch Cordless...
I started mower in tall grass. It started up and immediately stopped. Could not get it started. Replaced battery. Charged 12 hours. Still will not operate. Green light is on. Noticed the blade seems to...
After charging the mower, you must place the safety key in the mower before it will start. On models that have a bail handle, be sure to pull the bail handle back to the mower handle before engaging the start lever. If your mower still does not start, remove the safety key and ensure the bail and start lever are in the "off" position. Then firmly re-insert the safety key, pull the bail handle to the mower handle and engage the start lever.
Note - It is important that the bail and start lever are returned to the "off" position before inserting the safety key.
Give it try, if it still will not operate you may have to take it in for service.
Good luck, let me know.
Regards,
Jul 30, 2009 | Black & Decker 19" Electric Lawnhog...
Need to fix a broken moen kitchen faucet
I had the same problem with my Aberdeen single lever with a pull-out sprayer a few months back. If you are the original owner of the faucet, it's under warranty; you shouldn't have to pay for any parts. Call: 1-800-BUY-MOEN (1-800-289-6636) and tell Customer Service what the problem is. They will send you the Handle Mechanism Kit at no charge. (Mine was part #93980 for my Aberdeen faucet, but yours may be a different part number.) It's tricky to take apart and get back together but my husband and I have zero plumbing experience and got it all fixed in about 20 minutes. The Moen.com website also has exploded parts diagrams of all their faucets so you can identify exactly what part you need, and they have some little videos and slideshows to show how to replace parts. If you can't reach Customer Service on the phone, you can go to "Contact Us" on their website and email them a description of your problem.
Jun 17, 2009 | Moen Plumbing
I cannot close milano stroller
Above the wheels at the rear of pram there are small levers that you must activate. I'm pretty sure you press the left one first (do not need to hold down) then hold down the opposite side's lever and push forward and down on the handle of the pram. If this doesn't work try pressing the levers in the opposite way first. Originally the pram would have had stickers "1" and "2" on the levers to dirict you how to fold. If in Oz look up Karisles on google and follow the prompts to download instruction manual.
May 28, 2009 | Peg Perego Milano XL Stroller
98 Breeze Drivers seat forward / back adjusment won't work.
look under the seat and first see if something is jammed under it.... and that the wire that moves with the lever is intact. different instructions if that is a power seat.
Mar 06, 2009 | 1998 Plymouth Breeze
I read the answers written here and I can see why some people are still confused. So I will try to break it down into steps:
1. With your foot press down on the lever numbered 1 at the bottom of the stroller. This lever holds in place.
2. With your foot press down on the the lever numbered 2 at the bottom of the stroller. Hold this lever down with your foot because it does not lock in like lever numbered 1.
3. While your foot is still pressed on lever number 2, hold the handle bar with both hands and **** it forward. This step is rather tricky. So think of it as punching both hands forward horizontally while holding the handle bars.
At this point the stroller will come apart and fold. Now if you see that the stroller is stuck in position and does not fold or comes apart only with a lot of force then you have to oil the joints. Use WD-40 and spray it on the joints on the side of the stroller located right below where it say "PegPerego" on the body of stroller. That is where the joint where the stroller folds is located.
Hope this helps.
Feb 22, 2009 | Peg Perego Milano XL Stroller
Cannot open door from inside on front driverside
29 cent part my fix your problem. There is a nipple on the interior door lock lever that fits into a slot on the door handle lever. Look at passenger side to compare. The nipple is covered with a plastic spacer that may come off. The spacer keeps the lock nipple snug in the handle lever slot; pull the handle lever, it engages the lock lever, opening door. I bought a .29 cent aluminum spacer (#8x1/4 x 1/4) from Orchard hardware. Take needle nose pliers and slip the spacer on, then super glue. Unfortunately if lock lever (where riveted) is badly worn, then it may pivot upward instead of perpendicular to the door, thus defeating new spacer. But you may now be able to open door by pulling handle lever and lock lever at the same time. If you need to replace door handle, others on this site have suggested that you not replace metal frame that door handle is mounted on, but drill out rivets that hold door handle mount.
Jan 29, 2009 | 2001 Lincoln LS
Garden Logo
117 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
