Question about Delta & Single Handle Shower Faucet
Repairing a delta single shower faucet. The handle comes off easily. Should the ball assembly just pull straight out or is there something else that needs to be loosened. I bought new seats and springs to replace.
  • 334 Answers
There is a nut that needs to be removed, allowing you to remove the ball assembly.
Look at the ring nut right below the #1 in this pic.
Your's should be similar to this one.
repairing a delta single shower faucet. The handle - 9936d1215385468-how-remove-single-valve-handle-delta-shower-untitled.jpg
Posted on Oct 03, 2009
How to fix delta shower single knob faucet
Take handle off (either set-screw from side or bottom of handle, or phillips screw under cap on end of handle), pull off sleeve that's behind handle, unscrew nut that holds cartridge (strap wrench works great) and pull cartridge out.
Apr 29, 2015 | Delta & Single Handle Shower Faucet
MY SINGLE HANDLE SHOWER FAUCET DRIPS RAPIDLY. THE ONLY BRAND NAME MARKING IS "MASTER PLUMBER". iS THERE A REPAIR KIT FOR THIS FAUCET?
Those faucets are made by different companies and they put their name on them. Delta Price Pfister most likely. Sorry but you will need to pull it apart and see which it is. That is a hardware brand faucet and may be made by any of the major brands.
Feb 08, 2011 | Delta & Single Handle Shower Faucet
HOW DO I INSTALL A SEAL KIT
A metal ball controls the temperature and flow of water from the spout in the vast majority of Delta single-lever faucets. That ball rests on three rubber seals, each seal suspending the ball with a single spring. Over time, wear on the seals, the springs and even the ball itself typically results in leaks. Thankfully, repairing the faucet is relatively simple, and Delta even makes repair kits with the replacement parts needed for each model.
Turn off the valve that controls the main water supply. The valve is located next to the water meter, inside or outside the house, and must be twisted in a clockwise direction.
Remove the plastic cap from the center of the faucet's handle by prying the cap free with the blade of a dull knife or a flat-head screwdriver, then remove the screw in the center of the faucet handle with a Phillips-head screwdriver. Pull the handle off the faucet assembly to remove it
  • Remove the single bonnet nut that surrounds the faucet valve with an adjustable wrench. Grip the bonnet nut at the base, which is ribbed to give the wrench a surface to grasp, and turn in a counterclockwise direction to remove it.
  • Remove the circular, white plastic cam that surrounds the top of the faucet, pulling it off and revealing a rubber seal, which you also remove. Next, pull the metal ball out of the faucet assembly and pry out the ball's supporting rubber seals and their springs with a screwdriver (the springs slide onto the bottom of each seal, so they will come out along with the seals).
  • Slide one replacement spring onto each of the three replacement seals that come with the Delta repair kit for your faucet model, then insert each seal into the assembly. Insert the replacement ball from the repair kit, then cap it by putting the replacement rubber seal over the ball, followed by the plastic cam
  • Place the bonnet nut over the faucet valve, then tighten the nut with an adjustable wrench. Position the handle onto the end of the faucet, then insert a screw into the center of the handle, tighten it with a Phillips-head screwdriver and, finally, press the decorative plastic cap over the screw.
  • Turn on the valve that controls the main water supply by twisting the valve in a counterclockwise direction to complete the repair
  • Jan 28, 2011 | Delta & Single Handle Shower Faucet
    Delta single lever faucet leakingafter bing shut off.
    Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
    Jun 26, 2010 | Delta & Single Handle Shower Faucet
    How do i install a new cartdridge for a delta single handle faucet in my tub
    Remove the shower control handle. If the cartridge is threaded there will be a nut on the top. Remove with a crescent wrench. If there is no nut then there will be a retaining clip and the cartridge will then pull straight out. Installation is the reverse procedure.
    May 31, 2010 | Delta & Single Handle Shower Faucet
    Slow drip from Delta single lever shower faucet
    remove handle with allen wrench then unscrew sliver ring that covers ball with stem sticking out you might need a strap wrench if the threads are corroded
    Mar 07, 2010 | Home
    Leaking shower faucet
    I do believe that Delta guarantees their faucets for life. Go online to get the 800 number and call them, have the model number ready. They actually sent my girlfriend a replacement for her $300 kitchen faucet and also the guts to 2 bathroom faucets. They come with diagrams also. Of course I had to install them, but they stand behind their stuff.
    Nov 20, 2009 | Delta & Single Handle Shower Faucet
    Delta & Single Handle Shower Faucet  Logo
    730 people viewed this question
    Top Delta Home Experts
    Mike
    Donni Steen
    john h
    Are you a Delta Home Expert? Answer questions, earn points and help others
