Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer door leaking alot of water on floor no ice on door
  • 71 Answers
This really sounds like a plugged drain. When the unit goes into defrost the water should run down the drain into the drain pan...when the drain is plugged it will run over and down to the bottom of the freezer thus leaking out the bottom of the door and onto the floor. You will need to take everything out of the freezer and remove the screws that hold the back panel on break out the ice at the bottom and use hot water to pour down the drain to clear it.....also if you have a small hose to shove down the drain that will help out alot.
Posted on Oct 04, 2009
  • 66 Answers
SOURCE: Water leaking from freezer door and ice maker not gettin water
Check the fill tube for the ice maker and make sure it is in the correct place. This sounds like the fill tube has been moved and is running water into the freezer instead of the ice maker. Let me know what you find. I am here to help you.
Posted on Nov 12, 2008
  • 72 Answers
SOURCE: Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
Posted on Jun 17, 2009
mgprice
  • 744 Answers
SOURCE: water is leaking outside the door. once u open the
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Posted on Aug 05, 2009
  • 358 Answers
SOURCE: Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Posted on Sep 28, 2009
  • 3 Answers
SOURCE: samsung twin door fridge water leaking onto floor
I have a Samsung side by side - model RS253BAWW.
Water was leaking onto floor from main refrigerator, not freezer. It was determined to be a blocked defrost drain.
The repair technician removed the trays and food from fridge, remove the screws from the panel at back, disconnected everything and remove panel.
The stainless tray at bottom of fridge as well as panel itself had solid ice blockage.
He placed panel in sink and used something similar to a blow dryer with narrow hose on it to defrost both the panel and drain in fridge. Took him maybe 15 minutes and charged $99 total for the visit.
In future I will do this myself now that I know how but thought it may be useful information to others who are having similar problems.
Posted on Sep 08, 2010
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
MAYTAG DOUBLE DOOR REFRIG
THE PROBLEM IS WITH THE AUTO DEFROST (IF THE FEATURE IS AVAILABLE) OR ELSE YOU HAVE TO MANUALLY DEFROST IT REGULARLY
Sep 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Water leaking from inside of freezer bottom
Check the defrost of the freezer which you are using right now.For More information please visit Clothes Dryer Element.
Oct 06, 2012 | Hotpoint HSS25GFP Side by Side...
My refrigerator expelled water tonight. Whe I woke, this morning, I found the floor with water. Can you tell me what could be happening?
if the drain is blocked in the freezer water can leak out onto the floor if it's leaking out of the frezer door.open the door and check the bottom rack,if it's frozen in or ice is on the floor of the freezer then it's the drain.also if you have a water line going to the machine one of the water lines could have cracked.let me know what you find and we can go from there
Jan 08, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Ice builds up on floor of freezer apparently some leaking as my lamented floor is showing some damage. i have cut off water supply to icemaker and water tap thinking this was problem.
most likely you have a plugged and frozen defrost drain. check behind the bottom basket of your freezer section to confirm this you will find alot of ice build up. to repair you self:
  • unplug refrig.
  • unload freezer section
  • remove rear access cover (on jenn-air's there are 2 screws about mid way up they are painted white and arent very obvious).
  • clear all ice
  • flush drain hole with warm water. ( i use a turkey baster filled with hot water to get best results)
  • reassemble unit
  • reapply power
this should stop your water leak. thanks Peyton
Oct 10, 2010 | Jenn-Air JSD2789GES Side by Side...
Water is slowly dripping onto the floor from the bottom of the freezer door. it is as if the door is full of water. any suggestions?
ARe the temperatures good inside the freezer? If they are not near 0° F, that is the cause of the water drip.
If it is nice and cold in freezer, check freezer floor, is there a sheet of ice? you have a clogged defrost drain, clear it or have it cleared for you.
Good temps no ice on freezer floor? possible water leak inside door from water dispenser
Aug 13, 2010 | GE GSH25JFR Side by Side Refrigerator
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water runs out of freezer door overnight ,at times
Have a look at this link:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/7670-leaks-water-floor-front-freezer.html
or this one:
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Apr 17, 2009 | Westinghouse Refrigerators
Nov 12, 2008 | Frigidaire FRS266ZDSB Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
104 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
