Hi,It's not that big of a job.First UNPLUG the power cord! with the washer about 18 - 24 inches from the wall tip it back and have a helper hold it.The bottom panel should pull away from the main cabinet by firmly prying with a wide (2 in.) pry bar If this doesn't work look for screws which may be holding it in place.Once removed you should be able to see the motor belt and larger driven pulley.Also look at the condition of the pulley on the motor,some were made of plastic and simply fall apart.There should be some adjustment bolts near the motor mount,loosen them to install the new belt and retighten. Good luck and work safe.
Was this helpful?
Yes
No
Popular Solutions for Amana ALW480DA Top Load Washer
I need to replace the belt on my Amana ALW480DAW. The other one burnt up and broke. I have the new...
(More)
I need to replace the belt on my Amana ALW480DAW. The other one burnt up and broke. I have the new one. Do you have a diagram I could view to help me install the new one?
