Question about Welding Tools
Did not get one, can not figure out how to use it lotus plasma cutter how thick, speed power etc.
  • 25 Answers
Ha?
Posted on Oct 18, 2009
My pro cut 55 Lincoln plasma cutter sounds like a machine gun when I strike it and put it to the metal. It cuts holes when you hold the trigger down and try and make a continous cut. new air dryer
(From: https://app.aws.org/forum/topic_show.pl?tid=31328)
"Remember, they are a drag machine up to about 3/8" thick material. Keep the power down as low as possible for the material being cut. Keep the right air filters on to supply clean air. Keep the air pressure between 60 (min or it will shut down) and 70 for most applications (more is not better-just like oxygen on the torch or air to an air-arc).
Also, check that the air hose hasn't come loose from the gun.
That was Brian's problem from YouTube (http://www.fixya.com/answer/answerpageslideview.aspx?thid=26182813&ctg=373&brd=5236)
May 02, 2016 | Lincoln Welding Tools
Mishto plasma cutter won't work
You need to check the power supply, the air pressure switch.
Mar 29, 2013 | Welding Tools
Where can I get consumables for a lotos LT5000D plasma cutter, and is there something else compatible.
You can order them through Lotus Technologies,
http://www.lotostechnology.com/product_p/ltp5000d.htm
Or if you see a name on any of the components like Airco, Tweco, etc, you cold get through your current supplier or you could take them to a local welding supply and see if they can identify them. Chances are very good they simply used something readily available.
Jan 14, 2012 | Welding Tools
Would you purchase the 400 hobart or go to 500 hobart plasma they seem to cut the same thickness on the metal chart..
It's all about duration. How much metal do you need to cut continuously. Although the 400 will cut a similar spec it won't hold out as long. So if it;s lots of short cuts the 400 is fine, if you need to cut thicker gauge for longer period go 500.
Aug 16, 2011 | Airforce HOBART AIRFORCE 400 PLASMA CUTTER...
Is the esab 1250 worth buying and how much should i buy it for
Hi:
Esab's plasmas and machines are the best for manufacturing and shop maintenance. Are made for the tough jobs. Retail price brand new price is around 3200.00 US dollars.Cutting wise is a high speed cutting machine and will cut up to 1-1/2".
Mar 07, 2011 | RTO Esab Power Cut 1250 Plasma W/Pt 32EH...
Plasma cutter wont cut steady
Is your air compressor able to keep up with the continuous regulated air flow?
If positive air flow is not constant same pressure all the time
cutting will stop..>>
Also if your movements are to fast and or material to thick machine will behave that way..
Jan 22, 2009 | Hobart Welding Tools
Hobart 250 a keeps cutting off the flame
If you have a bad air supply then the moisture in the air will cause the torch to cut off and the cut quality depends also on air supply,speed,metal thickness and condition of your consumables,meaning your electrode and other related parts in the torch tip.Hope this helps
Jan 05, 2009 | Miller Hobart AirForce 250A Plasma Cutter ...
Plasma Cutters support
In this process, an inert gas (in some units, compressed air) is blown at high speed out of a nozzle; at the same time an electrical arc is formed through that gas from the nozzle to the surface being cut, turning some of that gas to plasma. The plasma is sufficiently hot to melt the metal being cut and moves sufficiently fast to blow molten metal away from the
Aug 27, 2008 | MILLER 192049 SWIRL RING PLASMA CUTTER
Plasma cutters support
Plasma Arc cutting is an excellent choice for most cutting applications but it is particularly well suited for applications where speed and excellent cut quality are important. Because of the intense heat of the plasma arc – around 40,000° F compared to 5,700° F, with gases used with Oxy-Fuel torches – the cut is clean with little or no dross.
Aug 27, 2008 | Miller Spectrum 1000 Plasma Cutter...
Welding Tools Logo
66 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
