Coleman furnace and the fan takes awhile to come on then runs for about a minute then shuts down. im thinking the fan cycling switch was moved and now takes longer to reach temp
  • 80 Answers
If it operates on a fan/limit switch it is possible the settings are wrong. Typical settings are: Fan Off-110F Fan On-140F High Limit-170F. If these are correct, you probably have a bad f/l switch. The bi-metal spring in these switches fatigue and will not rotate the switch smoothly.
Posted on Oct 04, 2009
We have a Coleman Electric Furnace Serial # AOL6042086, Model # AHP36C3XH21A and the fan runs constantly, will not shut off. We have replaced the thermostat and just replaced the control board. We h
I wish I was a furnace expert but I will give a push in the right direction. When a gas/electric fan runs it has two speeds. When you turn on the FAN ON switch it should run at the slower speed. If it doesn't turn on or turn off again when you turn it back you have a wiring problem or a thermostat problem. Make sure the thermostat is compatible with your unit and wired properly (on both ends). The other time the fan runs is "in session" when heat or cooling is applied to the system. It should run until the system finishes the cycle then a bit more (30 seconds or 1 minute) to blow the treated air completely through the ducts. If it doesn't stop then you may have a bad fan time delay or relay. Check parts for your model and various appliance repair site online.
Nov 25, 2014 | Coleman Mobile Modular Home Electric...
Furnace kicks on then shuts off
Coleman furnaces us a temperature delay with a temperature on around 130F to 150F and off around 110F.
If the inrush of cold air cools the delay below the off temperature the fan will go off until the heater heats it up to the on temperature.
Jan 06, 2014 | Coleman Home Electric Furnace Eb15b/Eb15d
I have a Coleman Evcon gas (propane) furnace. When the t-stat is switched to heat the furnace heats up but the blower will never turn on. The unit then shuts down and tries to cycle again. I have replaced...
If the unit fires but the main blower fan doesn't come on the the unit is shutting off on a temp high limit switch and it sounds like the problem is the main blower fan motor or control
Jan 18, 2010 | Coleman Heating & Cooling
Coleman furnace -- fan runs, ingniter won't light,
The chances are that the furnace was running when the power went out. This will cause the high limit switch to cutout and needs to be manually reset.
You will find that switch in the blower compartment near the blower. Usually somewher near the highest point of the cabinet.
Push the little red button firmly till it clicks.
When the power goes out while the furnace is running the heat builds up because the blower shuts down immediately and causes this limit switch to cut out.
If you have a electric tester you can also follow the low voltage circuit till you find the open switch. Ther is usually a wiring schematic on the door cover of most furnaces.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 09, 2009 | Coleman Propane Forced Air Heater...
Coleman Presidential II Model 7656A Mobilehome Furnace blower p
have you changed t-stat? if so you need to increase the heat anticipator. if you have a fan limit switch, the setting may need adjusting. Thay will change with age
Nov 01, 2009 | Heating & Cooling
Draft fan keeps on running after furnace shuts
That sounds pretty normal for most furnace/heater products. They run the heating element with fan for a cycle then after the heater reaches temperature it will shut off and the fan will continue to run to cool the element and to circulate the heat that it produced. If you want the manual for this product it looks like you can get it here: http://homeappliance.manualsonline.com/ex/product/headline/m/Coleman%2BEvcon/d/furnace/p/DGATO75BDC
Oct 26, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Furnace blower not working how it should
first off buy yourself a honeywell stat, in my personal opinion lux stats are garbage, I have run into so many that are bad stats !!! but as far as your fan not shuting down, sounds to me like your fan center on your circuit board is bad and will not shut down the fan when needed, you will have to replace the circuit board, as the fan center is a part of the whole of the circuit board, hope that helps
Jan 19, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
