Question about Sony KP-46WT510 46" Rear Projection HDTV
Colors seperate and picture bent
I have the same problem,ever once in awhile the 3 colors seperate and the picture looks bent!
What is the problem?
  • 83 Answers
THIS is a convergens problum .pls. prees menu key and see convergence menu select and see cross line on center the screen select one by one colour line to meching and cross line is white see the pictur is ok.
Posted on Oct 16, 2009
  • shailesh parikh Oct 16, 2009
Screen looks like it is in 3D colors are seperated.
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergnce board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 22, 2010 | Toshiba Televison & Video
Colors seperating and out ends of screen curved
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors pictures shadows or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 27, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Colors seperate
Yes, this problem is fixable.
Replace convergence out chips on D board of tv to fix the color separation issue.
Jun 05, 2010 | Sony KP-46WT500 46" Rear Projection...
The picture shows all 3 colors seperate from each
Sounds like a problem in your convergence circuit. This is the circuit responsible for making sure all 3 colors align perfectly so that you don't see what you are seeing now. If you have tried adjusting it and that did not work then you will need to have the convergence circuit repaired.
May 24, 2010 | RCA R52WM24 52" HDTV Projection Television
Wave & three colors
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Panasonic PT-51HX41 51" Rear Projection...
ALL 3 COLORS ARE SEPERATED AND CONVERGANCE DOES NOT FIX
We fixed this same problem as a dyi project. Check out www.tvrepairkits.com. The kit itself come with the proper chips, fuses, and very detailed instructions which includes pictures. They also have online help if you have questions. If you know how to solder and are a very careful person, this is something that you can fix yourself.
Mar 08, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
On the left side it has a 3 d picture like the colors are seperating (green, and red) the middle and right side is perfect
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Oct 24, 2009 | Televison & Video
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Mitsubishi projection tv
I have a similar problem. I have tried to fix the convergence via the remote and that has not helped. My three colors are separated and the edge of the picture is bent in toward the center. I am going to try a hard reset but i suspect the convergence IC are fried. Since the set is not HD, I will probably replace it if the hard reset does not work.
Nov 22, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
149 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
