When i lift the handle up it starts to leek and i cant stop it
If we are talking about a faucet then your problem is call the packing nut. sometimes the packing nut cracks or after so many time the faucet been open it just gets wear so what i recommend you to do is turn water off down under the sink and take a screw driver to remove handle, then with a pair of chanalocks remove trim and stem note: make sure stem is in on positiion if not in on position the treats on the faucet may cross treat and then you will have to replace the faucet so dont forget before you star taking it apart turn it off and star removing everything on the top, i will just replace the stem and you problem will be fix. but if you want to try a cheaper solution that may work just remove the handle and the trim and with the chanalocks adjust the packing nut that will be the nut on top of the stem right below the handle and tested.
