Question about Seagate FreeAgent Go 80 GB USB 2.0 Hard Drive
80 gig free agent go, USB
I was saving a file to this hard drive when it "locked up". After I rebooted the computer the drive is no longer recognized, and it makes a continous beeping sound. I have tried two different laptops with the same results. What can I do to recover?
  • 70 Answers
Is your hard drive detected by the BIOS? You can also check this by Right click on taskbar > properties > startmenu > customize > advanced > scroll down completely and select system administration tools "Display on the all programs menu" > ok. Click on start > all programs > administrative tools > computer management > double click on storage. click on disk management(local) here you should see your lacie. If you dont then the drive is probably not detected. If you see, you can just partition it from here and it will appear in your my computer. If it is indeed detected, you will have to use a application like Recover my files to recover your data and then partition and format the drive.
Posted on Dec 24, 2007
I checked the Right click on taskbar > properties > startmenu > customize > advanced > scroll down completely and select system administration tools "Display on the all programs menu" > ok. Click on start > all programs > administrative tools > computer management > double click on storage. click on disk management(local) - the drive was not detected.
Posted on Mar 31, 2008
When I plug my seagate free agent go portable hard drive (250 gig) into my usb, it register's that there is a device pluged into the computer (give's me the DING, that window's is famous for) but say's it...
try a different usb drive. if you are using win 7 or vista uninstall that device driver you downloaded. if its xp re install your usb drivers from the windows site just go to your device manager
win 7 vista click on computer sys prop device manager see if drive is connected hit update driver or roll back. same with usb system on win xp right click my comp. go to prop, then device manager let me know if this helps. but really important to make sure that you are plugged into a usb port in the back of the pc not thru a hub
Mar 16, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Dropped my1TB EXTERNAL Seagate drive, now not WORKING
Probably nothing. Hard drives are delicate machines seeing as th have microscopic lasers that are held by a tiny little arm between the discs. If it fell hard, so will all your DATA
Dec 19, 2009 | Computers & Internet
How do I transfer files to my seagate free agent?
Just left-click the file or folder you want to copy, choose copy.
Open My Computer and find the external drive, double click, once the folder opens just right-click and choose Paste.
That's pretty much it....or you could also drag files / folders to the drive.
Hope this helps.
Nov 24, 2009 | Seagate FreeAgent Go 80 GB USB 2.0 Hard...
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a 500 gig Seagate Free Agent external hard drive that I am having problems with. The problem is that the amber light on the hard drive comes on solid (bright) at initial start up, but then goes dim...
windows - delayed write failed
Windows was unable to save all the data for the file I:\$mft.
The data has been lost. This errors may be caused by failure of
your computer hardware or network connection. Plese try to save elseware.
Aug 03, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Maxtor External Hard Drive not recognized
you can find a program on the maxtor/seagate site maybe you can fix this with that..
Gr Rich
Jan 08, 2009 | Maxtor OneTouch III 500 GB Hard Drive
Installation issue - Not recognizing
hmm, no problem plugging in either side, just be sure to do the power cable first. What's doing the beep, beep?
Found a guy who had similar prob, here was his solution:
Go to Control Panel. Click on Device Manager.
Check to see if FreeAgent is shown as a disk drive.
If not, check the device list for any Free Agent device, double click and check driver. No driver installed? Update does not work? On the driver tab….click uninstall device.
Shut down computer. Unplug Free agent USB and power at the drive.
Reboot computer. As it is rebooting, plug in the power cord. Wait a minute or two….then plug in USB cord.
Windows will “found new device” ….. Just let the computer complete the reboot.
Then go to the device manager. Chances are you will find Free Agent in the drives….and in the USB list of devices. Open windows explorer….and you should see you Free Agent as a drive.
Windows will ask you to install manufacturer disk. You have no disk…non needed. Windows has installed the device. Just click on close. I you keep getting windows wants to install device…..ignore it. You can click on “don’t ask again”. (That is if your Free Agent drive is showing in the device manager as a disk…and in windows explorer….along with your other drive or drives.)
If at some later time….your Free Agent drive does not appear….repeat the steps as listed above.
(You may think it is not working….or that it has gone bad. Try this before you try to return.)
Seagate Tools…the new version….does not recognize to diagnose the Free Agent….
I have not tried Seagate Tools after getting the computer to recognize the drive.
I am surprised Seagate does not provide a Tool to recognize their own drives…and install and/or test Free Agent.
This does work for me with Vista. Thought I had lost the drive…. Seagate should provide a patch or a drive that Windows will recognize when you get the “found new hardware” and Windows asks you to insert manufacturer’s installation disk. I do not understand why that is not already there….a driver file for Free Agent...that Windows would install.
I did not buy Pro….because I did not need the backup software. I wonder if those who bought Pro are having these problems.
Oct 30, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Computer not recognizing my Maxtor hard drive
Andrew, That Maxtor drive sounds like it has finally died on you and being just an 80 gig drive means its really old. The systems failure to read the drive as your booting up is what's causing the long boot delay as the system will see the controller board of the drive, but your spindle motor on that drive is most likely dead and there fore you will not be able to access or read any of your data stored on that drive. Hope you had backups of important files.
Apr 15, 2017 | Maxtor OneTouch A01B080 80 GB Hard Drive
120 gig Western Digital black no longer mounts on LEOPARD osx 10.5 grrrr
i have the same problem.
macbook doesn't see anymore my hdd western digital 2,5'' white 250 GB.
tried disk warrior, disk utility but nothing.
it's just seem disappeared, even if i hear it works inside (and the led light is on)
what can i do?
May 10, 2008 | Western Digital Passport WDXML800UE...
Seagate FreeAgent  Go 80 GB USB 2.0 Hard Drive Logo
113 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
