Question about Bosch Washing Machines
Our Bosch Front Loader washing machine WAE24271AU want turn on,
Our Bosch Front Loader WAE24271AU want turn on, the control panel does not illuminate even though there is power, the machine is 1 month old and has worked satisfactory until today.
SOURCE: unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
Posted on Apr 12, 2008
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
SOURCE: Bosch classic 6 1400 express washing machine - key
This is symbol shows that the child lock has been activated. This can only be turned on/off at the beginning or end of washing programme. To activate/de-activate this, just press and hold the Start/Pause button in for 5 seconds. The time settings will then re-appear and then you can proceed as normal
Posted on Oct 19, 2009
  • 662 Answers
SOURCE: Got the Bosch Classixx 6 Express 1400 washing machine cant
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Pl rate me 'very helpful' for the free help, thanks
Posted on Jun 17, 2010
  • 662 Answers
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
How do i get the bottom filter out off my bosch front loader washing machine WAE22460AU. it will turn one quarter of the way but will not come out.
plenty of you tube videos on how to remove filter on a bosch front loader either go to www.youtube.com and search for bosch washing machine changing filter.
Dec 30, 2014 | Bosch Washing Machines
I NEED TO FIND MANUAL FOR WAE24271AU Bosh 6.5 KGwashing machine
Open this page
http://www.bosch-home.com.au/WAE24271AU.html
On the bottom you have tabs click on additional documents and then on download manual...
It will open new search window...
In search type WAE24271AUsearch it and download it
Sep 13, 2013 | Washing Machines
Bosch maxx clasic front loader Wkm41 the control panel has just died. what can I do to fix this?
I had the same issue this morning. I turned on the washing machine change a few settings, but didn't want these setting so i turned off and on again. When i turned it back on the panel was blank, but what had happen was the spin button was stuck in. Once i free the button the panel came back on.
Regards
Sep 10, 2010 | Bosch Washing Machines
I want to replace the door seal
This video will show you how to change a door seal on this Bosch front loader washing machine
Jun 01, 2009 | Bosch Washing Machines
Bosch front loader washing machine water pump?
Jul 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
BOSCH WASHING MACHINE RETAINING SPRING FOR FRONT DOOR GASKET
it is very hard to get the ring on front load washers,
it is much easier to remove the top. bottom and the front control panel
then the door and support panel.
now you have access.
some times you have to remove the counter weight in some models before putting on the ring.
if you can do it without removing these items you are very very good.
May 01, 2008 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
48 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
