Question about JVC TH-M303 System
No power to speakers
Subwoofer light does not come on. Everything is connected like it should be. Silver to negative, copper to positive. The power cord is in the socket. The cord coneecting th subwoofer to the main box is connected. I donlt get it.
  • abczyx Dec 22, 2007
    subwoofer light does not come on. Everything is connected like it should be. Silver to negative, copper to positive. The power cord is in the socket. The cord coneecting th subwoofer to the main box is connected. I donlt get it.
  • jamesray33 Aug 21, 2008
    No sound. speakers are plugged up. i cant figured it out.
    Sergeant:
    Champion:
  • 322 Answers
Sounds as if the internal fuse as gone look and replace ?
Posted on Jan 28, 2008
Ford BA XR6 what is the colours negative and positive for the rear speakers
Most speakers have copper wire for positive and silver for negative. The connection will have red + for positive and black- for negative for both speakers.
Aug 04, 2012 | Cars & Trucks
2004 ford explorer sport track radio wire colors
Hi there:
Check this on 2004 Ford Explorer Sport Trac Audio Wiring Schematic:
Car Radio Battery Constant 12v+ Wire: Light Green
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Power Antenna Trigger Wire: N/A
Car Stereo Amp Turn-On Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: N/A
Car Audio Front Tweeter Depth: N/A
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): Dark Green/Orange
Right Front Speaker Negative Wire (-): White/Light Green
Car Audio Front Speakers Size: 6" x 8" Speakers
Car Audio Front Speakers Depth: 2 1/2"
Car Audio Front Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Car Audio Rear Speakers Size: 6" x 8" Speakers
Car Audio Rear Speakers Depth: 3"
Car Audio Rear Speakers Location: N/A
Car Subwoofer Speaker Size: 8" Subwoofer
Car Subwoofer Speaker Depth: 4"
Car Subwoofer Speaker Location: N/A
Car Subwoofer Speaker Positive Wire (+): N/A
Car Subwoofer Speaker Negative Wire (-): N/A
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 28, 2012 | 2004 Ford Explorer Sport Trac
Negative and positive termanals not marked on speaker for instqllation does it matter?
It matters. Get a 9-volt battery and touch it to the terminals. When the positive side of the 9-volt is connected to the positive speaker terminal, the cone will pop out. If it pops in, then the positive side of the battery is touching the negative speaker terminal.
NOTE: A subwoofer should be strong enough to handle this. If you try this with a small speaker you can damage it!
Nov 08, 2010 | Pyle (PLBW124) Car Subwoofer
I have a 2001 dodge ram, when I connect either the ground wire, power wire, or both from the cd player I am installing, all of the dash gauges quit working.
make sure your not connecting the power wire to the power for the gauges here is the wiring diagram
2001 Dodge Ram 2500 Truck Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Size: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
pls rate
Aug 16, 2010 | Car Audio & Video
What is the best way to connect two 4 ohm type-r
Connecting the speakers in parallel is the best route here. Parallel wiring is simply connecting the positive wires together and connecting the negative wires together. Then connect both positive wires to the positive output of the amp and both negative wires to the negative output of the amp. When both 4ohm speaker are connected in parallel the combined impedance is 2ohms. This particular amplifier has a damping ratio of >250 at 2 ohms compared to a damping ratio of >1000 if you connected them in series at 8 ohms. the damping ratio is simply the reduction of power transferred. (For future reference in order to get the maximum power transfer input impedance must match the output impedance.)
Jul 24, 2010 | Alpine Type-R SWR-1242D Car Subwoofer
Which connections is the negative on these
most car stereo speakers have two connectors, one thinner and one wider. the wider one is typically the positive connection. to verify this, take a small 1.5v battery, and hold a wire to the negative and positive sides (it's easiest to use a battery case available at many electronic stores), connect the negative wire to the smaller connector, and tap the positive wire to the wider connector. if the speaker pops outward, then the thinner connector is the negative connector.
Jan 17, 2010 | Alpine SPS-609 Car Subwoofer
Speaker wire leads
i simply used my brain and hooked the copper wire to positive(red), and the silver wire to negative(black), being that the colors are similar. works fine.
Dec 13, 2009 | Power Acoustik NB-2 Car Tweeter
How to hook up led lights for phoenix gold x10d4 speakers
THERE ARE 2 WAYS:
1. (STEADY ON) - RUN THE POWER FROM THE AMP TO THE POSITIVE LED TERMINAL THE NEGATIVE CAN BE RAN FROM THE NEGATIVE SPEAKER TERMINAL.
2. (INTERMITTENT; COMES ONE EVERY TIME THE BASS HITS) - RUN THE POSITIVE AND NEGATIVE WIRES FROM THE + AND - TERMINALS TO THE POSITIVE AND NEGATIVE TERMINALS OF THE LED LIGHTS.
LET ME KNOW IF THIS WORKS FOR YOU -- CADILAC00@HOTMAIL.COM
Mar 15, 2009 | Phoenix Gold Xenon X10D4 - 10" D4...
Alpine type-r 2ohm dual voice coil help
try reconnecting your rca's from the deck to the amp when finished wire one speaker positive to positive on left channel and negative to negative on right channel then connect the 1st subwoofer. if all power and sound is fine and working turn off power to amp and connect negative terminal of 1st sub to positive on 2nd sub and positive from first sub to negative on second crossing the wires runs the speakers in series another way to try is parralel the speakers wiring by connecting positive left channel output of amp to positive on 1st sub same with the negative then splice positive to positive on second sub and same with negative.
Feb 09, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
JVC TH-M303 System Logo
171 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
