Question about Intel D845GVSR Motherboard
Was dwnloading updates for an emach. t1842 and power went out ...now when i turn it on the light is flashing repeatedly and nothing on the monitor
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 166 Answers
YOUR MOTHERBOARD PROBLABLY IS GONE YOU GOING NEED TO REPLACED
Posted on Oct 04, 2009
Popup keeps flashing - "processing auto configuration" how do I get rid of it?
joking, buy a real computer at best buy?
I\'M not sure if it is just? the monitor, (i dont thinks, so or the PC)
you can plug the monitor in to another PC to sort that question easy.
test the monitor if it is good, great, if not get a new one.
good monitor, read on.
that is my pet peeve too, pop ups. that don\'t say WHO DID THE POP UP. bad programmers do that, even MS.
frustrating it is....
the question is, who is processing.?.... dang"
my guess ?is windoz. (or APPS)
if it is windows, and not some APP.?
then set MS updates to off. see if that makes it stop.
if not , then it must be an APP, or Antivirus software running.
each APP or A/V can be configured to shut up. It is true.
most lap tops or emach, are set up with full nags.,etc.
No one ive seen that do this, bad act, can I STAND.!
the first thing i do on them, is remove all that junk.
I build my own systems. to avoid that. but....
I\'d slick the drive and put on W8 , fresh.
but what to do baring , that... idea...
let me give an example of my silly HP. net book (all HP puters have this)
they all have HP software loaded. (some good, some bad, some ugly)
I go in and remove all the HP agents and all nagware, and all HP
scanners, and other junk, leaving only legit , full version needed software.
I remove office as it is crippleware; as most are.
This is not HP only tricks, all other makers,do this junk.
after you get all this working, then turn on only, MS critical updates
but do have it , ask ME , first. option, in control panel.
then and only then, can you do work and stop the side tracking.....
join a forum for your lap top or emach.
do not turn off , HP recovery service or its special partition or support. this takes skill to do all this.
the maker of your PC has a forum, ive never seen one that does
not cover this topic, most have a nice list.(what to kill)
we call this bloatware and is hated by all.
good luck to you.
dont forget, you can barrow a spark monitor and connect
it to the emach , to see if it is :
windows
Apps (A.V)
or the monitor.
Sep 27, 2013 | E-Machines eMachines Monitor E15T4
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Dell LCD TV won't turn on
check the cable who comes from the cpu
May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
When the machine is turned on the tower doesn't turn on,
plz try by resitting the ram, if the problem is not solved then try with a good power supply unit
Feb 20, 2009 | E-Machines -T1842-CELERON-1.8GHz,40GB...
EMACHINE T1842
I had the same issue. I know the problem. Your power source is not working proprietly and you need to change it.
Dec 24, 2008 | E-Machines T1842 PC Desktop
Power light flashes
I have an older 20" display. I have had this same problem on occasion, and coincidentally, just experienced it again this morning. It seems to occur after I do an OS update. I powered down the computer, disconnected the display, reconnected by pushing firmly into place, then powered up. The flashing stopped and the display works fine. You might have a different problem, but that simple solution worked for me.
Jun 11, 2008 | Apple 20" Flat-Panel TFT LCD Cinema...
Pop goes the weasel
I agree. The monitor probably blew a capacitor.
Time for a nice new LCD monitor.
Dec 14, 2007 | Computers & Internet
Monitor flashes image for split second then goes blank but green LED flashes as well
while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
May 02, 2007 | ViewSonic VX924 19" LCD Monitor
Blank screen
Similar monitor, similar problem. I actually had to dismantle the thing and replace a transistor on the mainboard.
If you're not into soldering and such, good luck.
Oct 03, 2006 | Mag Innovision LT776s 17" LCD Monitor
Intel D845GVSR Motherboard Logo
48 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
