Question about Napoleon Heating & Cooling
Need to light the pilot light - Napoleon Heating & Cooling
  • 80 Answers
I am not familiar with this particular brand. What type of heater is it? Normal pilot lighting is done by setting the gas valve to the "Pilot" position and then pushing on the valve to manually open the pilot. After this, light the pilot and continue holding the valve for 30sec to give the thermocouple a chance to heat up. Release the valve and it should stay lit. Turn the gas valve to "On" and you're done. If it doesn't stay lit after releasing the valve, replace the thermocouple. If it doesn't light at all, call a technician out to check gas pressure, orifice, and pilot assembly.
Posted on Oct 04, 2009
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
Pilot light stays lit but burner on gas logs goes out
You may need a new pilot assembly. Typically one of two issues result from a bad pilot assembly:
1. The pilot won't stay on after lighting it
2. Pilot stays on but logs won't light.
Depending on the unit, you may need a new thermopile or a whole new pilot assembly.
Feb 02, 2014 | Home
Pilot light will not ignite water heater
the pilot light serves to purposes. it is the source of ignition for the main burner and is a safety device that detects wether there is a flame or not. if the pilot light stays on when you stop pressing the pilot light button then you need to turn the knob to the on position to light the main burner. the pilot light is not the on position. if the pilot light goes out when you stop pressing the pilot light button then the thermocouple or flame sensor needs replacing. good luck
Nov 30, 2013 | Raypak Pool & Spa
How do you clean the pilot light needle valve on a furnace?
you need to the pilot orffice out is blocked .
Mar 21, 2012 | Heating & Cooling
Gas is on pilot won t light
Hello there: The problem you mention is not that clear. The pilot won't light or the pilot lighted but won't stay on is two different problems. If the pilot won't even light or no gas coming out off the pilot when you push down the pilot button it means the pilot orfice is blocked and what it need is cleaning the pilot orfice. If the pilot light is on but goes off when you release the button then the thermopile need to be changed. Hope this can help.
Sep 23, 2010 | Frymaster Dean Kitchen Appliances - Others
Pilot wont light
If the pilot light goes out when you release the primer,then the thermocouple is bad.You can try to adjust the thermocouple,if it can be.It needs to be in the pilot flame.If the thermocouple is not in the flame,it will not stay lit.If you can not get the pilot to light at all,with the primer pushed down,then replace the regulator.To light the pilot light,you need to turn the dial to pilot.Then press the primer button down and hold it.The primer is either built into the turn knob,or it is a res button.Hold the primer down,and light the pilot,continue holding the primer down for at least 40 seconds.Then release the primer slowly,and if the pilot light starts to get weak,and try to go out,then push back down,and hold 30 seconds more.After the pilot stays lit,turn the knob to furnace or low,or whatever the directions say.
Oct 19, 2009 | Heating & Cooling
How do you light the pilot light
turn gas valve to pilot position, hold button continuously, light pilot gas at orifice, keep holding button down for 1 more minute as Thermo-coupling heats up. pilot should remain lite.
Oct 18, 2009 | Heating & Cooling
Light pilot light
Turn control knob to "Pilot" and press it down. While holding knob down, light pilot with a match. After pilot lights continue to hold knob down for about one minute. When you release the knob the pilot should remain on. If it goes out then the thermocouple needs to be replaced.
Jul 18, 2009 | Pool & Spa
Pilot went out and don't know how to lite it
YES YOU DO NEED MATCHES TO LIGHT THE PILOT IT IT DONT HAVE A AUTO PILOT AND IF IT DOES THEN YOU'LD HEAR IT CLICKING OR TRYING TO LIGHT IF NO CLICK THEN YES MATCHES WILL WORK TO LIGHT THE PILOT
Apr 11, 2009 | Williams 1403622 Gas Compact Heater
Heating & Cooling Logo
142 people viewed this question
Top Napoleon Heating & Cooling Experts
paulcarew
Bill Long
Rick12345678
Level 1 Expert
Are you a Napoleon Heating and Cooling Expert? Answer questions, earn points and help others
