Question about LG DLE2532W Electric Dryer
LG Electric Front Load Dryer door whistles!
I just bought a new front load LG Dryer - electric - and there is an air whistle noise coming from the top of the door whenever it is in operation. When I push in on the top of the door, the whistling air noise stops. There doesn't seem to be any way to adjust this door to kill the noise. Any ideas on what to do?
  • 36 Answers
Under warrenty call serv tech they ussally know whats wrong from svc bullitans
Posted on Dec 28, 2007
LgWM2277HB washer will not drain and makes high freq whistle when trying
Open the access door door on the front lower left of the machine and clear the drain filter.
Nov 17, 2012 | LG WM2277HBW XL Front Load Stackable...
I have New LG F1203CDP washing machine. whenever I start my washing Machine and after 5 mins from the cycle, the electricity will shut down automatically. Electrical technician confirmed that their is no...
If the machine is new, as you stated, before messing with anything, call the store or dealer where you bought it, and address your concern, doing anything to the machine itself may void any warranty that they may have for you on it
Jul 08, 2011 | LG WM2233H Front Load Stacked Washer /...
My dryer is making a whistling noise
Hi markbid...
I have never heard a dryer whistle, but there is always something to learn, follow the directions below and you can solve your noise problem.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vasoline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
This is a FREE answer, Please take time to rate me
Jun 16, 2011 | Kenmore 64742 Electric Dryer
I have a 06 Freestar that makes a whistling noise. Very annoying and random. I can't associate it with anything. Sometimes it doesn't do it at all but mostly it does. Never when stopped or going below...
LOL , We had this issue arise before and it turned out to be that when the audio guys at American TV installed the car stereo speakers in our door , they tore the plastic sealing membrane on the inside of the door under the door panel.
To locate the leak you will need a passenger with good hearing .
drive into the wind until the noise starts and have the passenger guess which door the whistling is coming from... remove the door trim panel and be sure the membrane is intact and sealed... pay close attention to the mirror area... as they are prone to leak and cause a whistle...
Hope this helped!
Jul 05, 2010 | Cars & Trucks
Dtyer load and air not venting to outside vent
The blower motors on these dryers can be packed with lint. It is a fire hazard. The entire front of the dryer has to be removed.
Jul 04, 2010 | LG DLE2101 Electric Dryer
I am trying to open my lg tromm dlg 5988w dryer to install a propane conversion kit. How does it open?
Remove three screws on the back holding the top cover, then standing in front of machine, use the palms of your hands to sharply push back on the L and R edges to move the cover back about 1 and a half inches, then lift cover off. Top cotrol panel is held on by a screw at the top corners and tabs along the top edge. Watch out for sharp edges. Remove control panel and place on top or dryer drum with wires still attached. Open door and remove screws at 4 and 8 O'clock positions, the the four screws along the top of the front panel. Unplug the light and door switches and remove the front panel. That should get you most of the way there.
Nov 12, 2009 | LG WM-2277HW Front Load Washer
3 yr old LG TROMM DLE 5977W Dryer-loud rattling noise started about a month ago.If I press on the front of the dryer below the door it stops.Something has come loose that stopped the vibrating noise?How do...
Remove the bracket at the top rear of the dryer 6 screws
Tilt top up and forward to remove
Remove operator panel by unplugging connectors and removing screws.
Pull up and forward to remove front panel
Nov 06, 2009 | Dishwashers
LG DLE2532W Electric Dryer Logo
412 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
