Question about Sewing Machines
Top looping underneath and does not appear to be picking up bobbing tread
  • Sewing Machines Master
  • 1,388 Answers
Take a look through this comprehensive list of
TROUBLESHOOTING
symptoms and possible solutions, it may also be useful for further reference in other times of need.
Check the timing of the needle to the hook. HERE is a guide to generic principles of Timing
Now also take a more specific look at tension issues....
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
top looping underneath and does not appear to be - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Best Wishes
Martyn
Bargain Box in Australia
Posted on Oct 04, 2009
My Pfaff 145 is picking up the tread and looping it around but not making a stitch
Could be a needle/hook timing problem. May need professional service.
May 09, 2016 | PfaFF Sewing Machines
How do I fix tention on brother Ls-2B837 loops underneath material
1. Always make sure you are treading the sewing machine with the foot in the UP position.
2. Loops on bottom mean the top tension is too loose... tighten it.
Mar 19, 2013 | Sewing Machines
The top stitch is perfect but underneath the material there are many loops. I am assuming this is from the bobbin. How do I correct this?
no, more likely your top tension is too loose causing the loops on the underside of your fabric, loops on top would be bobbin too loose. raise presser foot and rethread top thdead pulling thread into tension fully. set top tension dial to 5 and test sew. if still looping underneath try tightening top tension by turning dial up to 6. but usually top tension should only need minor adjustment tweeks. you can test top tension by lowering pressure foot to engage tension and holding thread just above needle thread guide, pulling thread downwards . there should be resistence on it to your pull. if you cant feel any then tension device may be faulty, and require service.
Jun 25, 2011 | Sewing Machines
The tread is "looping" on
Loops on the top of the fabric are signs of the bobbin thread being too loose. Linda at Relics
Jun 18, 2011 | Kenmore Sewing Machines
My overlock is not looping, I have rethreaded 3 times, no loops
You still are not treading it right...don't let it intimidate you, if you follow the manual and make sure that the thread is locked in the the top tension discs you should be fine.
May 04, 2010 | Husqvarna Huskylock Computerized 905
My Pfaff sewing machine has started to loop the top thread underneath. Tried fixing the tension on the bobbin thread as they state in the manual, but the problem still persists. Any suggestions?
If the thread is looping underneath, you're top tension may be too loose or the thread may not be in the take-up lever. If it's looping on top, double check that the thread is in the bobbin tension or that the bobbin tension isn't too loose.
Oct 02, 2009 | PfaFF Creative 7570
BOBBIN TREAD LOOPING UNDERNEATH
looping thread on the bobbin side means that the upper tension is too loose... make sure it's threaded correctly.
Jun 14, 2009 | Feiyue FS288
Thread getting caught in machine underneath
Try rethreading the top of the machine making sure you get it thru the tension wheel correctly.. General rule of thumb.
If it loops on the bottom, the problem in on the top.. Loops on the top, problem is with the bobbin.
Apr 14, 2009 | Sewing Machines
Sewing Machines Logo
103 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
