Question about Sceptre x22wg Gamer Monitor
Openin case for sceptre monitor to try and fix (no screws?
    Problem Solver:
  • 13 Answers
The only tools you'll need to open up the X22's case are your hands and something like a plastic putty knife. First use your hands to pry the face plate away from the housing along one of the four sides, that is, working from the middle where resistance is lowest. After you create a gap, insert the the edge of the putty knife and forcibly slide it toward one of the corners. This will separate that portion of the face plate. Do the same for the second corner. Now one side is free. Do the same for the other three sides. After you remove the face plate you'll see 4 screws that pin the lcd panel to the housing. After you remove them, be careful not to allow too much force to pull on the cable assembly that connects the panel to the mobo. Just reach in and squeeze the little metal clamps that fasten the connector to the panel. Do not try to disconnect it from the mobo from this angle. Disconnect it from the panel. Good luck.
Tom Raywood
Posted on Feb 16, 2010
How do you disassemble the case to repair light?
You remove all the screws and the stand, then use a thin flat blade screw driver to crack open the case starting at the bottom edge of the monitor first and work your way around, it is kind of hard to explain in words, just be real careful on the switch assembly in the front bezel.
You can also look a YOUTUBE on how to disassemble LCD monitors.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Sep 07, 2010 | Sceptre X9G-NagaIV 19" LCD Monitor
Occasionally, when I turn on my computer, my Sceptre X9G-NagaIV (Black) 19" LCD Monitor screen has a dark pinkish hue to it. Adjusting the monitor's controls don't help. If I unplug the monitor from the...
This could be as simple as the video cable isn't connecting securely. You could try replacing the cable or screwing it tighter. We recently had a red tint on an external monitor for a laptop because the cable was loose; since the laptop moved regularly, screwing the connector to the port on the machine wasn't a convenient solution. The other reasons for an odd tint like that is the video card or the monitor starting to fail. Attaching the monitor to a different computer and seeing if the problem repeats will check if it is the monitor and not the video of the computer.
I hope this helps.
Feb 17, 2010 | Sceptre X9G-NagaIV 19" LCD Monitor
I've got a Sceptre 19 in monitor with the typical "on for a sec and goes dark". I removed the 6 screws on the back of the case but obviously there is a further step thats alluding me...how to you crack the...
You need to use a plastic scribe to run around the edge of the monitor seam. A plastic scribe is a tool that looks like a knife, but it is not really sharp. Pry into the seam on the monitor and gently but firmly work around the edge until it pops apart.
Nov 06, 2009 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre x20wg 1080p monitor
In case you know very well electronics, you must open the cover of your monitor and find a fuse burned. You change this. You must repair power supply which supports voltage to work light on your screen. You must be expert to repair this.
Oct 29, 2009 | Computers & Internet
When im gaming, about every 5 minutes, the screen just turns off
What type of video card do you have, sounds like it could be several things at this point. I recommend checking you have the latest video card drivers, and that your video card is being kept cool, as well as the inside of your PC case.
Jun 18, 2009 | Sceptre X20g-Naga III 20.1" LCD Monitor
Problem with sceptre monitor
I have repaired a few of this model by replacing the failed capacitors in the power supply.
Monitor Mike
Dec 23, 2008 | Sceptre S1902D-4 Monitor
Dead scepter x22 monitor
Had a Sceptre DCL9A model for mine. There are plastic snaps which hold the back and front covers together. After I took off the screws and detach the monitor stand, I slid a very small flat head screw driver along the sides until I found each snap. They should come loose easily with a slight twist of the screwdriver. There are about 5 on each side of the monitor (not counting the monitor). Do not try to force it as you can warp or crack the plastic.
Jun 22, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
No picture
I fixed mine. Had to replace one bulging capacitor in the power supply. Yours may need more or less but it was pretty easy if you do any electronics. The specifics can be found under some of the other problem posts, especially for one of the 19" sceptres.
May 04, 2008 | Sceptre 17" LCD Monitor
Sceptre monitor will not return from idle.
The only workaround was to not use the DVI cable but to use the old VGA cable. You still get the same resolution.
I have a different ATI board, so I'm thinking it's an ATI+Sceptre on DVI input bug. Anyway, use the VGA cable, it'll work.
May 22, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre x22wg Gamer Monitor Logo
584 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
