Question about Pasquini Livia 90 Espresso Machine
Our Livia 90 would need a service + the pressure steam valve is leaking. Thanks in advance ! Thilo
    New Friend:
  • 16 Answers
If you are local to us perhaps in Orange County, CA we can provide service. If not you may contact Pasquini to get a local certified repair location near you.
As far as the pressure steam valve goes, you most likely simply need a new o-ring kit... we offer kits for new and older units. Older machines would use Part# KSWV-2 for $5.40, newer units would use Part# KSWV-2 for $4.30. I could explain how you could do this service yourself.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Posted on Apr 15, 2010
I have an older Pasquini Livia purchased in the early 90s. It continues to heat up and then the relief valve goes off. Is there a thermostat to replace?
Yes, remove the top panel on the right side is a p. stat with a microswitch on top, either that has to be replaced or the tube is blocked and it cannot read the steam pressure.
Nov 10, 2011 | Pasquini Livia 90 Espresso Machine
This Livia 90 has been working beautifully for the last 5 years. Suddenly, the water does not heat up. The needle on the temperature gage reaches the point just before the red marking and then gradually...
Hi
If you open the steam knob before you turn the machine on and it heats up normaly, you need to replace the vacuum breaker valve on top of the boiler. Its the 3/4 hex nut with the little brass pin in the center. If its is stuck closed when the machine is turned off, its holds pressure in the boiler, so when you turn the machine on again it starts to heat up but reaches pressure fast and turns the element off before it heats up all the way.
Apr 25, 2011 | Pasquini Livia 90 Espresso Machine
Pasquini livia 90 will power up for only few seconds and then shut down you know what iy maybe?
Try this open the steam valve when turning the machine on, if that works then the vent valve needs to be replaced, or the p.stat is damaged.
Feb 18, 2011 | Pasquini Livia 90 Espresso Machine
My husband removed the steam wand from our Pasquini Livia because I am running out of steam too soon and I thought the wand needed to be tightened. Now we need to know exactly how the springs go back when...
There should be a brass disk also. The spring goes in first, then the brass disk with the curved side down, then the wand, and then the nut.
Low steam pressure, could be a sign of scale build up, or the heater is getting covered with sediment. The heating element is on the bottom of the boiler on a Pasquini. Also check you pressure gauge. It should b shutting off at 1.1bar of pressure. If it is lower that could be another cause of low pressure. It can be turned up by the pressurestat.
Aug 24, 2010 | Pasquini Livia 90 Espresso Machine
The machine does not produce water and makes loud ticking noise- pressure gauge spikes and release valve blows. What do you think is causing that-
Hi
That sounds like a couple of problems. For one the pressurestat is sticking and causing the pressure relief valve to release steam pressure. The second one is your probes are getting scaled and causing eratic water level senseing. They need to be cleaned. Replace the pressurestat first.
Jun 15, 2010 | Pasquini Livia 90 Espresso Machine
I have a six plus year old Livia 90 Semi Automatic. It builds up pressure and then releases through the release valve, sometimes every 10 minutes, sometimes not for a couple of hours. Always quite a...
This is a simple fix. This has been fixed on newer units with a rewire kit. This rewire kit is for Pasquini Livia 90’s with serial numbers PRIOR to #49000. We have them listed on our website Part# 90000 for $30.00.
You can contact me for this part - If you are local we could install it for you. If you do not fix this problem soon, you will need a new pressure release valve. It would also be advised you get a microswitch #7633905 for $13 at same time as the rewire kit. If you still require a manual we could provide you with a digital version.
Jan 16, 2010 | Pasquini Livia 90 Espresso Machine
Pasquini. Livia 90 intermittently building up too much pressure
The part that will solve your problem is an upgraded heating rewire kit which will control pressure electronically, not manually. The rewire kit is Part #90000, $28
You may also need a new micro switch which is connected to your PStat with the rewire kit. The micro switch part #7633905, $13
These parts are in stock. I can send you these parts and instructions to install these parts in your machine.
May 21, 2009 | Pasquini Livia 90 Espresso Machine
Tooo much pressure
If you remove the top panel on the machine there is a pressure stat on the right side, with 2 wire connections going to it. That P.stat could be damaged and needs to be replaced, or the pipe to the P.stat is clogged and it cannot read the boiler pressure.
May 13, 2009 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90 - No water from the group head
The problem could be calcium built up blocking the jet and stopping the flow of water through your 3 way solenoid valve.
Otherwise the 3 way solenoid has stopped working. The 3 way valve part #91004 is $105 + shipping.
If you capable of removing the top and 3 body side of the machine, you can contact me and I can walk you through diagnosing if this is the problem with the jet or the valve. Before you call, make sure you have a philips screwdriver, 14 and 15mm open ended wrench or crescent wrench, flashlight, and paper clip.
Oct 18, 2008 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90 Espresso Machine Logo
384 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
De Brewerz
De Brewerz
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
