Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie DGS160 Game Camera Error 20000
My Moultrie DGS160 camera worked fine until a month ago. Its internal diagnostic system reports a "System Error 20000." I have no idea what that means. It has new batteries and I've gotten this error with several SD cards AND its built-in RAM. After being on hold with their "support" service for almost an hour, I gave up and wrote them an EMAIL which has so far gone unanswered.
Does ANYONE out there know what "Error 20000" means?
  • Moultrie Expert
  • 296 Answers
Forget calling Moultrie...I think their answering system is permantly set for "off-hour" times...you may have to e-mail them several times be fore (after4-5 days they get back to you.
You're error should read error"0200000"...flash error or flash charging...getting this during system diagnosis probably is that you failed to cover sensor during ck.
I f this is a constant error...turn cam on; remove batteries; turn system off; insert batteries and try again. .
Posted on Feb 17, 2010
  • rphillips996 Dec 08, 2010
    I have a gamespy 5.0 with no flash as I speak but I am going to give your suggestion a try right now . Thanks!!!!!!!!!!!
  • 448 Answers
I don't know the particular camera, but Moultrie code 20000 means that your flash is not working. Moultrie will advise you to cover the day/nite sensor while running the diagnostic test, and that that will fix it, but it may not do so. A friend had the problem with his camera (not your model) and they next told him to go to their webpage and to find his camera and find the download link, and to download the most current software update and run it, even if he already had it on the camera. That fixed the problem.
Good luck
Posted on Oct 05, 2009
Sd card keep reading ureconized file format
FAQ Proper Use of SD Cards with Moultrie Game Cameras
Question appears to be from some months ago, but Moultrie web site shown here suggests copying photos to a computer if possible directly without using the camera itself. Then it suggests reformatting the SD Card itself.
Feb 08, 2016 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Diagnostic error 2000
Moultrie liebherr diagnostic Digital Cameras Questions ...
www.fixya.com > Forum > Tags > liebherr diagnostic > Digital Cameras
Moultrie digital cameras liebherr diagnostic related questions and answers. Ask your Moultrie ... 6.0 moultrie says error 2000 ACTUALLY IT SAYS...ERROR ...
moultrie diagnostic test error 000480 Digital Cameras ...
www.fixya.com > Forum > Tags > moultrie diagnostic test error 000480
Digital Cameras moultrie diagnostic test error 000480 questions and answers. Ask your moultrie ... ...moultrie says error 2000 ACTUALLY IT SAYS...ERROR ...
Moultrie diagnostic code 12 Digital Cameras Questions ...
www.fixya.com > Forum > Tags > diagnostic code 12 > Digital Cameras
Moultrie digital cameras diagnostic code 12 related questions and answers. Ask your Moultrie ... 6.0 moultrie says error 2000 ACTUALLY IT SAYS...ERROR ...
Jan 20, 2016 | Cameras
Everything seems to be working fine. timer, flas etc and it seems to be taking pics but when you check it there are none. have tried two different cards no luck any ideas
Remove card go to setup scroll until you get delete all images;select;up or down button to change no to yes;select..turn off and try card again.Have to delete internal memory to use SD card.
Sep 17, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I have a MFH-I-40 camera. The camera stopped taking images and is reporting Error # 20000. What is the problem?
Hi.
Moultrie error code 20000 means that your flash is not working. Moultrie will advise you to cover the day/nite sensor while running the diagnostic test.
Some people have fixed the error by removing the batteries while the camera is switched on and then reinserting them.
Regards.
Jun 08, 2011 | Moultrie Cameras
SD card Locked
The error code 000060 means SD card locked. The switch on your card may be unattached internally. Try a different card.
May 17, 2010 | Moultrie MFH-DGS-200 Digital Camera
Moultrie I40 getting error code 480 and wont go into auto mode
ERROR CODE 000480 ?
If this is correct,it relates to: Camera Mod test failed;(4); and under Memory Test, 8= Comms Error.New batteries(good ones) may fix it...
It' not communicating with memory card..ck it's inserted good..press down until it stays down(press again and it will pop up.
Follow instructions on deleting internal memory before installing SDcard.
Also, make sure cam supports kind of card you're using..at 4gb and larger, they become confusing;i.e., 4/8/16mb...older cams won't support some of these. Also there are HC(high capacity); HD(high definition)don't work in these cams..
I posted this for a fix a few days ago, and it turned out to be brand new bad batteries.
Dec 23, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My Moultrie 140 Camera does not take pictures in the field. When I run diagnostics I get the error code 020000. Can you tell me what is wrong?
Flash error....try removing bats with power on; turn power off; reinstall bats; turn power back on...run system diagnosis...FOLLOW SCREEN INSTUCTIONS
Sep 27, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Diagnostic test Error 000480
IT HAS FAILED THE CAMERA MOD TEST(4) COMMS ERROR UNDER MEMORY TEST(8)...THE ZEROS INDICATE ALL OTHER SYSTEMS OK
..but, other than deleting memory;opening battery swing-out door with cam on;turn off;close door; turn cam back on...this may or may not solve prob.
Ron L
Apr 12, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie I450 Game Spy
Before installing a sd card, internal memory MUST be erased. From setup,use the up/down buttons near the select button until the display reads "ERASE ALL PICS(MEMORY)? NO" toggle up or down button to get"YES", press the select button and wait until until it says "DONE".
Go to setup screen, power off, intall sd card...should be good to go.
Oct 05, 2008 | Moultrie MFH-DGS-200 Digital Camera
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
1,701 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
