Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
MFC-440CN ink purge
How do I instigate a purge cycle on the MFC-440CN? My magenta ink capillary has bubbles - new cartridge and multiple cleaning cycles haven't helped.
  • Anonymous Mar 12, 2014
    mfc-440cn low temperature
  • Brother Master
  • 1,113 Answers
Menu/Set, Black Start, Menu/Set, and Black Start keys very quick thats maintence mode now enter in or arrow to 76 set then purge area and type need to be sected set... 99 to exit
Posted on Dec 22, 2007
Hp 3210 not printing magenta and leaving large quantities of magenta ink in printer blobs on right side of paper
defective cartridge; make sure you buy ANY cartridge from a REPUTABLE, not cheap, cartridge company.
Dec 24, 2012 | HP Photosmart 3210 Printer
Brother mfc-490cw maintenance mode
Is it a new Ink Cart? If not they have a bad tendency to dry out very quickly (even when not used) Some printers will use a combination of all their ink to create black when it runs low. Usually the first color to dry out is the Magenta. I would start by running a cleaning cycle 5-6 times and hope it can pull some ink through the ink head. Otherwise, go get a new cartridge and try it again. Ink Jets are a pain and the Carts are quite expensive, that why the machines price point is so low.
One other thought, you might try a Q-tip very lightly soaked in alcohol and gently rub it on the bottom of the Magenta Cartridge, it will remove any dried out in on the bottom of the cartridge and might make it work. But, WARNING....to much alcohol is a BAD thing and will cause a terrible mess with ink everywhere and could possible cause printer problems.
Good Luck.
Jun 03, 2012 | Brother MFC-490cw Color Inkjet Wireless...
Brother MFC-440CN printer will not see new cartridge
Your print-heads, which take the ink, and spray it onto the paper, have become "clogged". Run a "print-head-cleaning-cycle" to try to unclog those jets.
Nov 26, 2010 | Brother MFC-440CN InkJet Printer
The printer is not printing magenta, I've tried different ink cartridges and multiple cleaning to no avail. What now?
Were the new ink cartridges, Genuine Brother Cartridges?
Brother does not like gereric !!!!!!!!!!!!1
Good Luck
Feb 05, 2010 | Brother MFC 210C All-In-One InkJet Printer
Wrong ink in slot
my brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Sep 13, 2009 | Brother MFC 6490CW InkJet Printer
Brother MFC 5840 won't print red. ink is full. printer head clean
If the regular cleaning does not work, you can try the power purge. Perform it by doing the following:
  • Press Menu, 2, 8, 6, 4 quickly (within about 1-2 seconds from the menu-press, all five buttons should been placed, in order).
  • The display and some buttons should start flashing, and it should say "Maintenance".
  • Press 7, 6.
  • It should say "CLEANING ALL", press right arrow key until you get "CLEANING MAGENTA" or similar.
  • Press 3, it should now change to POWER_P or P_PURGE. Press Mono/Black Start.
  • The display should say "Cleaning", when it's done, it will say Maintenance again.
  • Press 99 and you will leave Maintenance mode, you can now try and see if magenta works again.
If it doesn't work, you'd probably need chemicals to clean the ink tubes. But, this power purge should work.
Jun 05, 2009 | Brother MultiFunction Center MFC-440CN...
MFC 210c problem with Magenta ink
I had a similar problem with my black ink. The printer had indicated that it was out of black ink. I didn't have one on hand, so, for more than a week I couldn't print anything, because if you are out of any one of the four ink cartridges, it won't print at all. That delay in replacing the black ink cartridge apparently was enough time for the printhead to dry out. Big Mistake! I contacted Brother's Tech Support and they suggested I run the cleaning cycle and try to print a test page. Still nothing printed. They had me run another cleaning cycle, and another, and another. Finally, after the fourth cleaning cycle, something started to show up on the paper. They had me clean it two more times, six in all, and it was back to normal. From now on, if it says one of the ink cartridges is empty, I change it yesterday. The major disadvantage of all of this, other than not being able to print for awhile, is that this procedure used up about 1/2 of a brand new black ink cartridge.
Oct 06, 2008 | Brother MFC 210C All-In-One InkJet Printer
No magenta
do you use generic ink? If yes, use an original brother ink cart! Because of the additives within the brother ink, cleaning substances will keep the ph clean.
If you still have trouble please post again here
Apr 11, 2008 | Brother MultiFunction Center MFC-440CN...
Brother Printer Cannot Print in Black
This could be because of several probs: 1. The ink cart is not original and wont let the ink flow, because the valve is not open. 2. There might be air bubbles within the capillaries. 3. The ink is not genuine ink and has pigments in it. Solution: see here, too: http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=dcp110c_us Insert another ink cart. Use, if possible, the genuine ink cart from brother. Do the cleaning cycle twice. This will extract the air bubbles out of the caps after the second time. If you dont have any success the printhead is clogged and cant be cleaned anymore!
Sep 17, 2007 | Brother DCP 115C All-In-One InkJet Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
435 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
