Question about Cameras
Wont turn on without being plugged into the charger
My fujitsu wont work without its charger and when the charger is plugged in it wont actually charge the battery itself.
Probably your battery is dead because if there would have been any problem with your charger port, you cant be able to use it on plugged mode. Buy a new battery ASAP.
Dec 29, 2014 | Fujitsu LifeBook AH532 Notebook
I have a problem getting my phone on. i have a motorola electricify. it wont turn on even when i try to reset it hold the volume down button. it wont do a thing. it wont charge. everytime i plug the c
Kyle
let it set on the charger for a couple hours without attempting to turn it on. See if the battery icon appears.
If that doesn't work you can try MOTOROLA ELECTRIFY Master Reset Factory Data Reset
Mark
Motorola Support
Sep 14, 2014 | Motorola Mobility MB853 Electrify US...
My compaq presario 2200 wont boot up...when i press the on/off switch without the a/c charger (battery alone), the amber led flashes twice....if i plug the charger in with the battery, the led blinks once...
If the computer is not turning on, there is a big chance of hardware failure and normally there is no easy fix for this rather than a motherboard replacement.
May 03, 2011 | HP Compaq Presario 2200 Notebook
Hi my sony psp wont charge but if the charger is plug in i can turn it on and play but i cant turn on without the charger? can any one help
It sounds like the battery is completely dead. The battery is easily replaceable and I would recommend trying that.
Apr 07, 2010 | Sony Battery Charger for PSP
Cut off by itself and wont cut back on
After charging it up fully, attempt to turn it on without being plugged into the charger. If it will not turn on, try turning it on while on the charger. If it does not power up and there is nothing wrong with the charger you have a phone issue. If it does power on, you need a new battery.
Mar 27, 2010 | Sprint BlackBerry 8703e Phone
It wont turn on dont know if i is charging
If it will not turn on, even when plugged into the wall (can be done without the battery installed) it is a faulty connection/piece where the charger plugs into the phone. A good way to check would be to go to a cell phone store with those types of batteries and if one of their batteries works & your phone turns on, it is definitely the port the charger plugs into on your phone.
Mar 15, 2010 | Audiovox PPC 6700
My iphone 2g wont turn on, i replaced the lcd, it worked ok, my batter was low. so it died and i was trying to turn it on, but it wont turn on. when i plug in the wall charger nothing happens,but when i...
I have a feeling that when you ran the battery down it is now struggling to get and hold a charge.
If you have a friend with a similar battery perhaps try that, or go to a mobile store and ask them to try a new battery for you.
Nov 09, 2009 | Apple iPhone 3G
Sansa E250 won't turn on after trying to plug it into an an ipod docking station my sansa mp3 player wont turn on or off the only way i can get it on is to plug it in to charge. and i cant take it to work...
my sansa e250 wont turn on only when i plug it into the charger...and when i try to turn it on without plugging it into the charger it says battery is low and turns off..when actually the battery is full...?
Jun 27, 2008 | SanDisk Sansa c240 MP3 Player
Cameras Logo
96 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
