Question about Nokia 3110 Cellular Phone
Phone restart I have tried sol#1 many times,but it didnot work , when I insert the memory card , the phone restart many times till I remove memory card , what can I do , here my email : aa984zz@gmail.com
  • 217 Answers
Have you try to replace your memory card?or try to have a back up of your files then format the memory then put it back to your phone.if it is still not ok,replace your memory card..
Posted on Oct 03, 2009
My nokia 3110c is blinking n switch off after the logo appear
Those who still have this restarting problem on Nokia 3110c ... Im telling the solution again, step by step. It ll work . you dont need to go 4 the firmware v5.05 If ur phone restarted 3 or 4 times and switched off automatically. Try this method 1] Remove the battery and Micro SD card 2] wait about 5 minutes 3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu [default security code:12345] {i know most of people have done this thing,but remember u have 2 go with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD {Don t Format the memory card}
9] Switch On ur Nokia 3110c phone. 10] Now Keep ur free Phone memory space [Not the memory card's free space] between 470kb - 499kb.
Now surely ur 3110c working fine about 5 months.During these time u can 1] Send/receive any file via bluetooth. 2] Enjoy Music,video, GPRS,Yahoo Go .....etc 3] Also u can Update music library anytime.
Apr 19, 2011 | Nokia 3110 Cellular Phone
My 6300 restarts automatically when i insert any memory card why?
hi
there are some phone that will restart when memory card is inserted automatically for first time. but make sure that your phone will support the memory card that u use. if still problem arises kindly try your memory card in other phone if it works properly means the fault is in your mobile. kindly format the phone and try it. this will fix your problem..
thank you
Dec 19, 2010 | Nokia 6300 Cellular Phone
Deleting yahoo go from collecting software. Mobile immeatily switched off.3110c. Next time switched on only blinking immeadely getting switch off
try taking out the battery in mobile, then put it back in this might help.
(or)
Solution:-
1. Switch Off Phone (Remove Memory Car And SIM).
2. Star Phone Without Memory Card (But Now You Can Insert SIM)
3. Restore Your Phone (Factory Settings) Change Theme (Less Than 100KB In Size) Leave it Switch On For 10 Min.
4. Switch Off Phone And Leave it For 10 Min. (Remove SIM Card Also).
5. Insert Memory Card + SIM Card And Switch On Phone. 6. Enjoy.. :)
NOTE : -
1. Make Sure To Leave Free Space For Phone Memory Between 500KB +
2. This Will Effected For Next 4 - 5 Months … 3. If Phone Restarts, Then You Know What You Have To Do Now?
Sep 05, 2010 | Nokia 3110 Cellular Phone
I hv a nokia 7210 cellphone. bt the 1 gb memory card becomes password protected. how i can open it?
I suppose you didnt insert any password to your memory card.If you didnot put password then you can unlock the memory card by seeing the below youtube video
http://www.youtube.com/watch#!v=Be_aHSlDFCU&feature=related
Thank You
Aug 11, 2010 | Nokia 7210
Have a problem with start button
Im telling the solution step by step.It ll work . you dont need to go 4 the firmware v5.05 If ur phone restarted 3 or 4 times and switched off automatically.
Try this Remove the battery and Micro SD card
3] Then switch On the phone WITHOUT the memory card Now ur phone working well without restarting
10] Now Keep ur free Phone memory space [Not the memory card's free space]between 470kb - 499kb.
Now surely ur 3110c working fine about 5 months. During these time u can1
3] Also u can Update music library anytime. but remember below
DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times and automatically swiched off.}
Jan 14, 2010 | Nokia 3110 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
method
but remember below DONTs
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
O2 sim card says insert sim
Take the sim card out and then re-insert the sim but give it a little push then it might work again
i hope this helped you
Jessica xx
Aug 22, 2009 | O2 Samsung SGH-E250 Cellular Phone
Problem for memory card
memory card is currupted. or remove memory card clean contacts with pencil eraser and insert it again. if it works good or replace memory card
Jul 11, 2009 | Nokia 3110 Cellular Phone
NOKIA 3110 CLASSIC RESTART PROBLEM
hi i am imran in kota (borkheda) my mobile Nokia 3110 c is 7 time problem in restart it is very serious and ptt problem. pleas help me. ok
May 17, 2008 | Nokia 3110 Cellular Phone
I forgot my unlock code, i entered 5 wrong
Steps to unlock ur sec code.
1. Off Ur mobile.
2. remove battry
3. remove memory card
4. On ur computer and plug in ur memory card.
5. insert ur memory card.
6. unzip the attachment file and place it to ur memory card
e:\system\recog
7. now insert ur memory card into ur mobile and switch on the fone.
8. now if it ask for code type 12345 and ur mobile unlocks.
9. Every times u restart ur mobile it will unlock ur mobiles security code.
down load .mdl file @ www.MegaShare.com/218723..just select free download
Mar 24, 2008 | Nokia 6600
Nokia 3110 Cellular Phone Logo
37 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
