Question about HP PSC 1315 All-In-One InkJet Printer
I have a hp psc 1517 and there is a thin strip of plastic behind the ink cartridges, my daughter pulled it out can it be put back in and if so how
    Scholar:
  • 40 Answers
Sounds like you are refering to the encoder strip. It is a thin clear piece of plastic with little black lines all the way accross the length of it. The printer has a sensor on it that reads these lines so that the carriage assembly knows where it is inside the machine. It is usually spring loaded on one end of it. Both ends of the encoder strip have a notch on it. One side of the encoder strip hooks onto a fixed mount through one of the notches, the other side hooks onto a spring loaded mount. If your daughter didn't pull it all the way out of the machine it is a bit easier to reinstall because all you need is something skiny and long like a pair of needle nose pliers to reattatch it to both of the mounts. If it is all the way out the strip needs to be threaded back through the sensor on the back of the carriage assembly(the thing you intall the ink cartridges into). Hope that helps a bit. It is a simple problem for a tech to fix but could be more difficult if you are trying to do this without removing any of the covers.
Posted on Oct 04, 2009
I have a HP psc 2175v printer and it says i have a carriage jam. There is no paper in the printer all at this point and the ink carriage moves back and forth fine, the ink was removed adn replaced but...
The cartridges might not be moving back to there rest stop correctly, check the sponge to the far right Also The clear plastic strip running behind the carriage could be damaged or dirty. this strip tells the printer where the carriage is and if it can not read it, it will cause that message.
Hope this helps
Regards GM
Apr 09, 2011 | HP PSC 2175 All-In-One InkJet Printer
Printer locking up. Print cartridge hanging up on left side creating error message
Check the thin plastic strip inside the printer. Take a soft cloth dampened with water and gently rub both sides of the strip back and forth. Move the carriage to clean the entire strip. It has real fine lines on it which are used to position the carriage. When ink or some other debris covers some of the lines, the carriage won't know where it is and it generates an error message. Be gentle when you clean the strip as it is delicate.
Mar 05, 2011 | HP PSC 1209 All-in-One InkJet Printer
A plastic strip that runs behind the ink cartridges has fallen off. its a quarter inch wide and about 12 inches long. each end has a slot cut at a 45 degree angle and an eigth of an inch from the end. I...
That is the ink guide. If the plastic strip connector (the slot cut on both sides) is not damaged/broken, the other metal tab may have fallen making the plastic strip to fall. It is usually soldered on the metal frame of your printer, find the missing tab and solder it back in. You should find a trace of the tab's original location.
Apr 17, 2010 | HP PSC 750 All-In-One InkJet Printer
First two letters on the left are blurry. The
Look inside behind where the carriage is, the plastic strip behind the carriage probably has an ink or grease spot right where you see the blurred letters. Wipe that strip carefully with a Q-tip moist with alcohol, and the blurs should go away...
Dec 13, 2009 | HP PSC 1210 All-In-One InkJet Printer
My daughter pulled this long plastic strip out HP PSC 1210
Sounds like it is the guide strip that pushes/pulls the print carriage back and forth?
Sorry but it is not a repair easily carried out at home, if at all. If in one piece and not broken it might be re-introduced but the bottom line is you will most likely have to purchase new? Sorry. it might cost just as much if taken to a repairs?
Nov 15, 2009 | HP PSC 1210 All-In-One InkJet Printer
Plastic thin strip about 15" long has came off my HP1410
That sounds like the belt that moves the printer cartridge carriage back and forth. Unfortunately, you will most likely have to purchase a new printer, because repairs for that will be prohibitively expensive.
Sep 02, 2009 | HP PSC 1410v All-in-One Printer
Where is the encoder strip on brother fax machines?
I am familiar wih some inkjet models. The encoder strip would usually be behind the ink cartridge carriage. It is a thin clear plastic strip across the length of the carriage. The ink cartridge housing glides back and forth along the encoder strip.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Aug 25, 2009 | Brother MFC-685cw InkJet Printer
Plastic strip fallen off from the ink slide
You are referring to the encoder strip. They can be reinstalled. They must be threaded through a sensor on the back of the carriage.
The mount at the left side has probably been pulled out of position. If the mount is not sitting properly the strip will be loose and will cause problems. The tension mount has two flanges that must be behind the plate it is mounted on. Good luck.
Jun 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
A thin strip came out of my hp psc 2210 all-in-1 (printer)
This is a tough one! It's called the ENCODER strip. The covers must come off. It goes in back of the ink cartridges.
It has to be threaded in betwwen the ink carrier and the carriage ribbon cable assembly, then hooked to the frame.
Jan 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
Child damaged HP6110 - Help
It stretches from left to right behind the cartrige assembly and the assembly slides on it. It's a sensor strip for positioning the cart. asm. I'm not sure how it attaches, but you'd have to take the unit apart to do it.
Good luck...
Geno
Mar 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 1315 All-In-One InkJet Printer Logo
116 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
