Question about Samsung Eternity Cell Phone
MY ETERNITY HAS FROZEN UP ON ME.
MY PHONE IS FREEZING UP ON ME. NOT ONLY THE TOUCHSCREEN, BUT ALSO THE HARD KEYS. WHEN IT DOES WORK, IT SEEMS TO BE RUNNING SLOW. NO, IT HAS NEVER BEEN EXPOSED TO MOISTURE.
Phone freeze deactivate failed
Don't worry i will help to fix this Phone freeze problem.You can Unfreeze this SAMSUNG Eternity using the Unfreeze code.I would suggest the site MobileUnlockSolutions.com here you can get Unfreeze code and unfreeze it.If the Unlock code does not work ,it's a wrong code.So use correct unlock code and unlock it.Get Correct unlock code for Samsung Eternity phone from the site itself and unlock it easily.You can get Unfreeze code for South American network locked Samsung Eternity Phone .
May 15, 2013 | Samsung Eternity Cell Phone
LG GS290 touchscreen problem I have a LG GS290 and the touchscreen has partly frozen. It seems to shift everything to the right, so when you touch 1 it activates 3. Really really annoying as you can't...
Have same problem but only shifted 1 to right ie 2 = 3 and cant use left hand keys and cant re calibrate. Turning off for a while sometmes helps but problem returns
Dec 25, 2010 | LG Cell Phones
The touchscreen on my samsung eternity frooze./..can not access my phone because the screen is frozen
the touch screen of the phone you are using is weak and it is not responding properly again.
in other to resolve the problem,you will need to replace the touch screen with a new one.
For touch screen replacement , Contact a technician.
Take care.
Jul 06, 2010 | Samsung Eternity Cell Phone
My samsung a867 restarts I can do and when I connect to the computer does not see
As mentioned, the front of the Samsung SGH-a867 Eternity is mostly covered by the large 3.2" touchscreen display. There are, however, three buttons along the bottom edge of the phone, providing send, end, and back functions. The 'End' key pulls double duty as the power button, so you can easily turn the phone on and off. On the top edge of the Eternity, there is a single 'Hold' button, used to quickly lock the touchscreen from accidental keypresses. Along the right edge of the phone, towards the top, is the standard 3.5mm audio port, which is definitely a welcome feature. Below this is the application switcher button, and below that, the dedicated camera key.
The microphone is located along the bottom edge of the Samsung Eternity, and along the left edge is the proprietary power/data/headset multi-jack. Also, the volume rocker is located towards the top of the left edge. The 3 megapixel camera is located on the back of the Eternity, and the entire back panel slides down and out to offer access to the battery and SIM card slot. There is a microSD slot, though it is frustratingly located behind the back panel and requires removal of the battery to change the card.
Jun 19, 2010 | Samsung Eternity Cell Phone
Samsung A867 eternity unfreeze code.
I got my unlock code to my samsung a867 eternity and when i put it in the phone said that its in phone freeze.. What is this and how can i get it fix
Nov 17, 2009 | Samsung Eternity Cell Phone
Freezing when I install a micro sd card into my samsung eternity
i had the same problem. so i try whatever i can
- i remove battery, put it back on, turn the phone back on. seems like it works for 3-5 minutes and freeze again
- i remove sim (only ),memory card still in there, and turn the phone back on..let it sit with no sim. and 3 minutes later it freeze again
- i remove sim, remove micro sdhc, reset the phone , the phone automatic restart..it woks... it never freeze ( no sim+ no memory card )
- i put the sim back on, no memory card, turn the phone back on and it works!!!!!!! i try these 2-3 times without memory card. works normal!!!
so..i think its a memory card issue. may be the phone doesn't like it. i have 2gb. kingston. or i have to buy a new card again.
for now its still working without freeze up for shut down by itself.
hope it help :)
moo
Jul 16, 2009 | Samsung Eternity Cell Phone
I have an eternity that is in phone freeze mode. I have an unlock code but won't work while frozen. How can I unfreeze the phone?
i think you attempted to enter the code more than 3-5 times already, if you see phone freeze on the screen you need to send in the phone for a "reflash".
Jun 27, 2009 | Samsung Eternity Cell Phone
Numbers key have frozen
Have you tried soft reset ?? Or even Hard Reset (delete eveything from phone). Make sure that no keys are stuck.
May 14, 2008 | Palm Treo 650 Handheld
Samsung Eternity  Cell Phone Logo
208 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
