Question about Amana ARB2557CSR / ARB2557CSL Bottom Freezer Refrigerator
Noisy refrigerator We have a six year old Amana bottom-freezer refrigerator. A few times per day we hear a "knocking" sound from the refrigerator. Just a single knock each time. Is this the compressor, and is it fixable? Thanks in advance for any advice. Doug
    President:
  • 1,304 Answers
Hi doug,
with the amana of that age there are several weird noises, be glad you have only one. that aside
ill tell you all of em...
a clear pop..... usually after defrost its the compressor starting cold as they say.
a knock ( very much like you should answer the door) is the plastic liner popping back into place in the freezer, after defrost.
Then ther is the knock of the water solonoid, but that would be more than once a day.
you might be able to remedy these, by changing the box postion a bit,,, i know sound stupid but i was the old lonely for 15 years and this one was always tough to diagnos it never happened whiles the service guy is there.... so i bought one....
Posted on Oct 04, 2009
Amana fridge stopped working for 2 days
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 03, 2012 | Amana AFF2534FE Bottom Freezer French...
We just bought a new house that came with this refrigerator. It works fine, but every once in a while, the fridge will knock loudly, and it almost sounds as if ice or something hard is clattering inside...
The noise is likely the defrost heater coming on. This melts the ice on the evaporator coil. The melting ice is the noise you hear and maybe the panel flexing from the heat of the heater. This is normal.
Oct 03, 2010 | Amana ARB1914C Bottom Freezer Refrigerator
Knocking noise in refrigerator section
This will be a loose mount on the electric motor (tighten)
May 05, 2010 | Amana ABB1927DE Bottom Freezer...
My refrigerator is six years old and for the past two months is making a loud buzzing noise. The frequency has increased over time. What could it be? It's an Amana side by side model ASD2626HE. Sounds like...
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Apr 12, 2010 | Amana ASD2626HE Side by Side Refrigerator
My Amana (bottom freezer) starts knocking every so often.
It could be unequal tightening of the mounting of the compressor. Also check the belt for uneven thickmess...........sodeep
Sep 04, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Knocking and humming only when freezer door is closed
It sounds like the fan, which would not run with the door open. Be sure it is clear of all obstructions then fake out the door switch and see if this resolves the problem. If it doesn't it will confirm that it is the fan or not. If it is just replace it.
Good Luck,
Gilshultz
Apr 12, 2009 | Amana 22 cu ft Bottom Mount Refrigerator,...
Amana refridgerator mdl abl2222fes knock noise
sounds like the compressor vibration dampers are wearing out. the dampers are the rubber washers that seperate the compressor from the chassis of the fridge. when they start to deteriorate, and the compressor kicks on, it will bounce against something in the chassis, causing a knocking noise.
Jan 22, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Amana refrigerator
Sounds like it has either a bad compressor relay or if the brand name of the compressor is Tecumseh, it will need to be retrofit to a more reliable longer lasting Embraco compressor.
Jan 10, 2008 | Amana ARB8057CSL Bottom Freezer...
ICE machine won't turn off!!
To turn off the icemaker, raise the metal arm all the way to the top so that it stays in the off position. You can remove it completely by taking out the screws that hold it to the cabinet and unplugging the wiring connector.
Post back if you have any questions.
Nov 21, 2007 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ARB2557CSR / ARB2557CSL Bottom Freezer Refrigerator Logo
457 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
