Question about Garden
I have a Karcher G2600 OR Pressure Washer, 2600 psi, 2.5 gpm. PN 1.194 506 0. gas engine works fine and water flows fine but pump is not adding pressure to stream. Checked and cleaned inlet water filter.
  • 2692 Answers
SOURCE: karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Posted on Apr 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 31, 2009
  • 548 Answers
SOURCE: I have a 3000 psi karcher pressure washer with
sounds like you need a seal and bladder rebuild < if you liver in a cold environmet for winters please dont forget to winterize your washres every year before winter
Posted on Sep 15, 2009
SOURCE: i have a 2300 psi
If you no longer have High Pressure coming out while machine is running, it's a pump issue.
Posted on Mar 19, 2011
cool78259
  • 228 Answers
SOURCE: I don't get a constant
Make sure that while you are running your pressure washer, other machines that pull
large volumes of water like a dishwasher or washing machine are not running. check and make sure
the hose you have tied to the pressure washer is not collapsing or has any kinks in it.
check the filter where your water hose ties in to your pressure washer, make sure it
is clean and does not have any debris or hardwater buildup, clean the tip at the tip of
the wand. if it is reduced in size by hardwater buildup, will not work properly, good luck!
Posted on Jul 12, 2011
Grey oil leak and no water pessure
depends on where the oil leaks from , normally a cloudy or "grey" oil sheen ,oozing out from here and there doesnt consern me too much , but now the oil running from the big hole or crack in the housing now that conserns me , make sure unit is "primed" with water (small flow from tip with motor off but hose turned on) if still no good then cycle your unloader a few times by tunring the pressure adjustment all the way up and all the way down with water on and motor runninng , this should work unless you have a larger problem
Feb 20, 2015 | Karcher G 2600 VH 2600 PSI 2.3 GPM 161cc...
No pressure...new pump
Gun could be the problem if you hear the engine pick up speed and you can feel the pressure on the hose.if engine speed doesn't increase than there is a governor issue with the engine.
Oct 03, 2014 | Karcher G 2600 VH 2,600 PSI Gas Pressure...
How do I fix a Karcher 2600 PSI pressure washer has water in oil..
you mean water in the pump oil ??? or engine oil ???
im suspecting pump oil... you didn\'t seal it properly or you have a crack somewhere in the main housing. rarely is it viable to repair these pumps... if you search a little you can find replacements pretty damn cheap !!!
Aug 09, 2014 | Karcher G 2600 VH Gas Pressure Washer
Why won't my pressure washer start?
Im currious what on a pressure washer required "cleaning" what were you running thru it other than water ?
do you think you might have dissasembled something on engine part and might not have assembled it back quite right?
May 03, 2014 | Stanley 2350 PSI 2.3 GPM Gas Pressure...
2600 PSI Pressure washer will not draw detergent up
I posted an answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR. Same machine I suppose, but use the black 65 l degree low pressure nozzle.
It's in the manual , I missed it and had a hell of a time trying to figure it out. If that doesn't work check the check valve on the pump(Where the soap hose is) , see if it's gummed up.
Be careful taking it off there's a spring and ball bearing in there.
Apr 09, 2013 | Karcher Garden
Karcher G2600 VH - low water pressure
If the spill valve activates is "spills" water under the washer. There is a restriction or the pump has become inefficient and will not pump the volume and pressure it should at full RPM.
Jul 20, 2010 | Karcher G 2000 MK 2000 PSI 20 GPM 87cc Gas...
No peessure
if you have good water flow to it and you have water coming out of the lance when you pull the trigger but its not under presure then it will most likely be bad valves in the pump head or worst case a fault in the pump. any questions just ask away
Feb 20, 2010 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
OUR KARCHER 2600 PSI PRESSURE WASHER W/ HONDA ENGINE WON'T START. WE BOUGHT IT A SAM'S CLUB LAST YEAR AND PROBABLY HAS ONLY BEEN USED ABOUT 4 TIMES. PLEASE ADVISE.
Hello:
Have you tried changing the gas, Especially, if it has been in the machine of a while. Also some Honda engines will not start if the oil is low. Also try removing the high pressure hose before you start it? Do not run it very long without water flowing through the pump, though.
Sep 20, 2009 | Karcher Garden
Karcher G 3050 OH the pressure is not constant, I think that is the pumps pressure regulator but I'm not sure
Check the suction line for leaks. It needs constant water
supply to build a constant water pressure. You may also
check the pressure regulator for leaks. You may also
check the carbide or ceramic pistons for breaks. Send you e-mail for further assistance.
Sep 06, 2009 | Karcher G2500PHR Factory Refurbished 2,500...
Karcher 2600 psi pressure washer wont stay running
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
