Question about Dryers
Motor bearings squealing at start up then quiet after 20-30 seconds. Motor drawing 24 amps with no load.
    Problem Solver:
  • 9 Answers
Do not use more greese bearings if not working then replace motor or bearing
Posted on Oct 03, 2009
What is causing my squealing belt?
I would check belt tension and then Idler pulley bearing..If still nothing check the A/C compressor clutch..
Jul 19, 2014 | 1991 Nissan 300ZX
What is era Code CI on a Calypso washer
A CI is an to high amp draw on the motor. In my experience it could mean your motor is bad, or motor control board is at issue. The only way to really check is to have an amp meter to see if the motor is drawing to many amps.
285917 MOTOR ABOUT $250
8571359 CONTROL BOARD ABOUT $200.
The biggest issue, is you may also have a transmission locking up, basket drive issues, bearing issues, etc causing the motor to pull the high amps.
May 29, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
The motor runs fine with the belt off but when the compressor is on line the motor hums and trips the house breaker.
Turn the compressor pump pulley by hand (with belt off) and air pressure in the tank. It should be very easy to turn. If it is hard to turn, evaluate the check valve for leak. If no leak examine crank bearings for damage. Repair as needed. If easy to turn fault is with motor. Check amp draw with belt removed. When the motor comes on, it should draw about 15 amps and drop lower. The motor should start and reach full rpm in a split second. It should start with a bang and run smoothly with-out getting hot and only pull low amount of amps. If slow start and high amp draw, check capacitor/s and or start winding switch inside of motor. Sometimes the start switch will burn the contacts and give trouble. If both capacitors test within 95% of value and start switch appears to be good, look for damaged copper windings. Windings will be discolored or burned and the tie strings binding the windings will be melted. Replace as needed. Good holidays
Dec 15, 2010 | Dewalt d55170 Electric powered air...
High oitch noise during wash
As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
May 04, 2010 | Frigidaire Professional Series 24 in....
Have a 24 volt dc motor. (34 amps) Supply is 24
Hi, you should not have to, the motor spec is max current draw, maybe when stalled, the supply is a theoretical maximum so you will be fine, in case of faults a breaker or fuse rated at 35 amps would be good.
Mar 12, 2010 | Cycling
Hi my old Honeywell 13520 has acquired a periodic squeal. I am sure it is a motor issue. Any way to tune up these little motors? (Brushes, etc..)
Usually if the motor is squealing, the bearings are dry no lubrication and worn. If you have oil ports you can oil it and quiet it down for a while. Most motors now have self lubricated or oil impregnated bearings, which you can't lubricate. It costs as much for somebody to replace the bearings, as it does for a new motor. Most people replace the motor.
Nov 17, 2009 | Honeywell Enviracaire 13520 Air Purifier
The outside unit is making a squealing noise. It's every now and then; not constant. Just started today. What's wrong? The fan is running fine. The air inside is cool. Just a high piercing squeal every now...
sounds like its more than likely the fan motor. the bearings in the motor are notoriuos for making a squeeling noise. there arent any other parts that would make this noise. unless youre a special case. i doubt it. if youre mechanically inclined there are ways of checking the motor. If you have an amp meter you can check the amp draw on the fan motor. if it reads higher than on the label of the motor then the motor needs to be replaced. if the amp draw is good the you can try to drop some oil in the motors lube port.
Jun 24, 2009 | GE Quiet-Aire Ductless Split System Air...
The inside unit makes a squealing noise when it first starts.
Is this a belt driven motor if it is you have a loose belt, if not, it sounds like the bearings in the motor are going bad, in that case you will probably have to replace the motor.
Apr 16, 2009 | GE Quiet-Aire Ductless Split System Air...
High amp start up draw
I don't care what kind of stories Craftsman tells, their numbers don't add up.
One horsepower is ~ = 740 watts of energy.
2.5 hp equates to a steady-state power consumption of  ~1850W and this could be 50% higher during the first second or two after turn-on.  Your 15 Amp circuit is pushed to the limit by that power level; 15 Amps X 120 VAC = 1800W And, motors aren't a breakeven game; part of the power they draw is wasted in heat.
9 amps steady-state would be a power consumption of over 6kw which cannot be right. Either your measurements or the motor is faulty.
Dec 13, 2008 | Square D Ehb24020pl 20 A Ehb4 Ehb Circuit...
Dryers Logo
107 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
