Question about HP Officejet J5780 All-In-One InkJet Printer
When I print a document, the printer prints multiple copies of each page even when the print window says "Copies: 1". Please help. Also, I have the "mirror image" problem too, but I have to click it off every time I want to print something.
    Sergeant:
  • 233 Answers
1. Have you rebooted the Printer and PC?
2. Have you loaded the correct drivers and software?
(Seen many instances of the wrong CD shipping with HP printers.)
3. When you say, "the print window says "Copies 1". Is this:
a. the Printer digital window?
or
b. the Print window dialog box on the monitor?
IF a. "the printer digital window" ignore it and check the print window dialog box on the monitor. Many applications remember what you input last and will repeat the last entry. Say you printed your Resume 10 times. Now your printing the grocery list and it prints 10 times.
If b. "the Print window dialog box on the monitor" Make sure the copies are indeed 1 only. Then check to make sure none of the numeric buttons on the printer has been pushed.
Is this a Network printer?
Make sure you have cleared the printer cache!
Shut down the computer then the printer.
UNPLUG both for at least 10 sec.
Restart PC and allow it to boot up completely BEFORE turning on the printer.
Mirror image sounds like a default setting has been changed.
Go into you HP software and go to configuration.
There should be a button there that says: "Use Default settings"
If this does not return things to normal. It is could be driver issue.
Meaning if you have the wrong one installed. The printer/scanner could do most anything as it is receiving the wrong code instructions for that model.
Posted on Oct 03, 2009
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
My printer prints multiple pages even though number of copies in setting shows 1
Try looking here: open your printers fax folder. Your printer should be listed here, right click on it and select properties. Now click on the advance tab. There should be a printer defaults button, click on it. Make sure your copies number is set to 1. Then click ok on each window and close.
Hope this helps
Feb 13, 2012 | Dell 1320c Laser Printer
How can i print multiple copies of the same document with 3 pages and have the printer staple the copies in the correct groups?
In the print driver you should have the option to collate, you need to make sure that that option is on, and when you go to send the print job, you need to make sure that you adjust the finishing options in the driver to tell it to staple.
May 11, 2011 | HP LaserJet 4250 Printer
When I print a one page document, tray 1 prints on multiple papers at a time. 1 page prints on 5 pages.
If you don't have a manual, you can find one here
My guess is either on the printer or the driver. Skimming the manual, it doesn't seem that you can set the default number of pages printed per sent print job on the printer, but that is something I would look into. This is a nice office printer, perhaps the printer is set to print multiple copies of everything it is sent. You could determine if it is the printer or driver/computer by printing to it from another computer.
If it is the computer, go into the control panel and select the properties for this printer. In there, check if the number of copies is improperly set to 5. This would happen for every print job sent from this system.
Does it print 5 copies of documents sent from different programs (i.e. Web Page, Word, Excel)? Quite possibly, one time you set it to print 5 copies and that application retained that as default. In that application, rather than clicking "print" click "printer setup" and look through the settings to see if it is requesting multiple copies.
I am 95% sure one of these three solutions will solve your problem.
May 05, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
My HP printer is printing multiple copies of the same document every time I print. The only way to stop it is to cancel the printing job.
it sounds like in your printer driver, the number of copies is set to more than 1 page.
go to printer drivers, and look under printing preferences, and look for what themultiple copies are set to.
Aug 30, 2010 | HP Office Equipment & Supplies
HP Photosmart C6350 prints more copies then asked for
How do I turn off the ink level system on my HP all in one C6350 printer?
Jul 15, 2009 | HP Photosmart C6380 All-In-One InkJet...
Unable to store job at printer, printer not configured to collate
Problem -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
Error “Unable to store Job at Printer”
Reason “Printer not configured to collate”
Solution “Install an EIO hard disk”
Usually when trying to print a multi page document.
Solution 1. Start > Control Panel > Printers
2. Locate the printer > Right Click > Properties.
3. Device Settings > Mopier Mode > Set to Disabled.
4. Apply OK
Feb 25, 2009 | HP LaserJet 2300L Printer
Why do all pages print onto one page when i hit the print button in a multipage document
I guess you are using word. In that case the default driver you use and comes standard with windows is flawed. Download a new one from HP.
Oct 24, 2007 | HP LaserJet 1150 Printer
HP 4650N Will not print more than one copy of a job
make sure when printing it has all checked off in the page range box instead of pages
Aug 28, 2007 | HP LaserJet 4650n Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
75 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
