Question about Fisher Paykel EcoSmart GWL15
Water leaking from the bottom of the machine
At the start of the wash cycle I noticed all the water coming out of the bottom of my machine.I checked all the hoses and they seem to be tight..
    Problem Solver:
  • 9 Answers
Some times there my be minor loose and also check at hose which is connected to wash tub meant for switchin washin machine
Posted on Oct 03, 2009
5 Suggested Answers
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
SOURCE: water leaking from bottom of machine
Question is too broad. We need to know the brand and model.
Posted on Jan 04, 2008
JULIANFIX
  • 975 Answers
SOURCE: Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Posted on Apr 22, 2008
SOURCE: There is water draining from underneath the machine?
I have the same unit, I had to replace my drain pump and clean the entire machine out. THis unit has many design flaws however once they are corrected with new parts it is a good machine.
Posted on Mar 07, 2009
I have a HotPoint washing machine, and it is leaking water bad. It leaks whenever the spin cycle starts, and the washing machine shakes pretty bad in that cycle. It's my ex girlfriends washing
The leaking could be coming from the exit port on the washing machine. Check the hoses leading from the washer to the drainage port in the wall. As for the shaking, check that the level adjustments at the bottom of the machine are level.
Apr 12, 2013 | Maytag Ensignia 3.3 cu. ft. Top Load...
WATER IS COMING OUT FROM THE BOTTOM OF THE WASHING MACHINE ONCE THE WASHING HAS STOPPED, IT DOES NOT LEAK DURING CYCLE AND IT SPINS AND DRAINS FINE..
i would inspect both the hoses on the pump
no leak during cycle is explained because water is moving through them to fast to leak when the machine settles it starts to leak
Oct 15, 2009 | Hotpoint Aquarius WD63 Front Load...
I've got a Fisher and Paykel MW051-U washing machine. Everything seems to work fine, but after each wash cycle i notice that it is leaking water, i've tilted it and confirmed that the water is coming from...
access through the back panel to have a look at the drain pump which is likely your fault. Run a cycle and watch it when it drains you will likely see water leaking from the pump (about $25 and easy to change)
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Water leaked from bottom of washer
Check the pump right where the motor shaft goes into it. The pump seal can leak right there and the water drips directly onto the floor. It will continue to run out after the cycle till the remaining water drains out of the tub and drain hose.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Mar 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Water leaking from the bottom of the washer at the rear right corner!
firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Oct 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Water leaks during rinse cycle
MAKE SURE TO FLUSH-OUT DRAIN LINE. WATER IF IT IS DRAINING TO SLOW WILL START LEAKING AROUND THE LOWER PART OF THE WASHER WHERE THERE IS A SAFTEY OVER FLOW ... IF YOURS IS A FREE STANDING TOP LOADER THE DRAIN HOSE IS IETHER SEPERATE OR FLOWS WITH A CHECK VALVE THAT HOOHS RIGHT TO YOUR FAUCET. MAKE SURE THE CHECK VALVE AT THE FAUCET CONNECTION IS FREE AND NOT STUCK.
May 07, 2007 | Kenmore Elite 20972
Fisher Paykel EcoSmart GWL15 Logo
165 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
