Question about Refrigerators
Not cooling Frost buildup in freezer, not making ice today, now refrigerator part is starting to not keep cool...we have vacuumed underneath and unkinked the coil in back. Only 3 years old.
  • 1 more comment
  • jarrobjen Oct 03, 2009
    Where would I find the compressor?
  • man_dipa May 11, 2010
    Check compressor is working or not, And how hot it is ? If it becoming hot then it there is leakage in Gas,but some gas get chocked.
    There is filter near compressor heat it with some hair dryer if it can open.Otherwise refueled gas
    Can you tell me that you compressor is working and become hot?
    President:
  • 1,304 Answers
Side by side its an adaptive defrost or a evap fan
open the freezer, push the door button, if you can hear the fan, its the adap,,,
but you would want to inspect the defrost terminator as well.... but you can do that after you melt away the frost
Posted on Oct 04, 2009
Model 253.7031*. Why does it keep geting ice buildup in the freezer and not cooling in the fridge area?
Why are my fridge and freezer not cooling? - Refrigerator - iFixit
https://www.ifixit.com > Answers > View
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the ... the make an model of myfridge, so now i have that so can you please give me a ... and freezer, turn the thermostat in the refrigerator to Off, and leave the doors ...
Dec 04, 2015 | Kenmore Refrigerators
Side by Side Can't find model # Not cooling enough
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Jul 06, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
How do I fix ice build up at the back of the fridge compartment?
make sure door is closing properly,and turn temp down,or should I say up,warmer
Feb 17, 2015 | Refrigerators
Fan housing has frost buildup and fan blade is hitting the ice. I removed the ice about 6 weeks ago and it's doing it again?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator Fan Noise
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 29, 2011 | Refrigerators
On June 5 had ice and frost buildup in the back of the freezer - that caused the refrigerator not to cool the food. Shut off and melted all the ice. Turned back on and has worked. Now just noticed ice...
Have you cleaned to condensor coil on the back of the box at the bottom where the compressor is at take a vacuum cleaner and clean the coils see if this helps sounds like you have an airflow problem.
Jun 29, 2010 | Maytag 22 cu. ft. Bottom Freezer...
AMANA BC20JL FROST/ICE BUILD-UP IN FREEZER, REFRIGERATOR WILL NOT COOL BELOW @46. COILS ARE VACUUMED REGULARLY, MANUAL DEFROST OFFERS NO IMPROVEMENT. EVERY SO OFTEN A LARGE PUDDLE APPEARS FROM UNDER THE...
Make sure defroster heater, temperature switch, and defroster timer and/or circuits are working.
Ice buildup will stop airflow from freezer to fridge, so fridge will be too warm.
My guess would be that the defroster is working half the time, allowing ice to build up. When it does work, it's got way too much ice/water to deal with, so it overflows the pan underneath.
Oct 23, 2009 | Refrigerators
MAGIC CHEF CTF1920ARA - Freezer works, Refrig. portion does not.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 04, 2008 | Magic Chef Refrigerators
Amana not cooling
Take the back cover off and look at the frost. If the frost is only at the bottom of the coils then you are low on R-12 or R-134 and the defrost t-stat is cutting out to quick. If the coils are well frosted then you have a bad t-stat.
Dec 09, 2007 | Refrigerators
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
