Question about Craftsman Garden
HOW DO I CLEAN THE CARBERATOR ON A CRAFTSMAN 6.0 HP LAWN MOWER?
ccrozier_agr
  • 36 Answers
SOURCE: broken starter cord lawn mower #944.368300/craftsman
Please note ! patients is required with this one !
Hi, remove the recoil top cover with the recoil attached. ( DO NOT TAKE OUT THE SPOOL OR YOU COULD HAVE THE SPRING GET YOU IN THE FACE)
Remove old cord.
With your new cord lace it through the recoil spool centre hole with a knott on the end.
now depending if the recoil winds in clockwise when spool is facing you wind the cord around it a few times by turning the spool clockwise,
Then put the cord in the notch at the side of the spool & wind the spool & cord anticlockwise about twice the number of turns of cord (this should tension the spring).
Take your end of the cord & lace it through the hole outside of the casing & fit you pull handle.
But hold the spool firmly untill the cord has a good knott on the end of it.
(Sometimes I see the guys here putting a loop in the cord to stop it sliping in while they tie a knott on the end of the handle.)
Posted on Nov 29, 2008
SOURCE: I need the owners manual for this lawn mower Craftsman 917.377220 6.75 HP
Here a website that gives a list of Craftman Lawn Mowers and it owner manuals. Hope it help, its were I found my manual.
http://www.craftsmanlawn.com/Walk-Behind-Mowers/
Posted on Jun 22, 2009
SOURCE: my craftsman rotory lawn mower 6.5 hp self
You have water in in the carborator, I'll bet. I had this same problem. Here's what I did.
I emptied the gas tank, put in a new spark plug, changed the oil and then unscrewed thd big nut on the bottom of the float container (attached to the carborator near the rubber gas injector button) and emptied and cleand the float container. Then i put it all back together, pulled the cord and the same thing happened, but this time i could keep it going by having my daughter constantly pushing the rubber gas injector button. After it had run for a minute with this constant pushing of the button, all the water was gone from everytwhere and it worked.
Posted on Aug 13, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
SOURCE: Craftsman lawn mower running bad with Tecumseh
http://www.tecumseh-parts.com/Tecumseh-Parts/tecumseh-vector-engine-and-parts
Posted on Oct 12, 2010
Craftsman tractor how do I engage freewheel control rod?
Craftsman Lawn Mower manuals - ManualsLib
www.manualslib.com/brand/craftsman/lawn-mower.html
. PDF manuals. User manuals, Craftsman Lawn mower Operating guides and Service manuals. ... 28910 - Lt 2000 20 HP 42" Lawn Tractor ยท Operation Manual.โ€ŽCraftsman Lawn Mower manuals - โ€ŽCraftsman 247.370310 - โ€ŽCraftsman 247.37030
Aug 02, 2015 | Craftsman Garden
My craftsman lawn mower model 917.371940 will start, but will not stay running. It will dye out 5-15 seconds after it starts
Hi, your carberator is plugged up. Take it off and do a good cleaning job on it and be sure the main jet is open.
Sep 17, 2010 | Garden
I have a Craftsman 6.5 hp Honda engine push mower. Every time the mower warms up it will rev up and down and stall. I have cleaned the carberator, but I cannot adjust the float because its plastic. The...
my experience with revving up and down like you describe is usually caused by fuel starvation..if it still has good compression and spark when it quits then it must have a fuel restriction.....usually when this only happens after using it a bit its because of a faulty fuel vent...try leaving the cap loose and if it doesnt act up loose go buy a new cap
May 22, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
I can not keep my mower running. It ran great before winter, now it acts like it is going to run.. but dies. I have new gas in it, new oil, and changed the spark plug. What else could it be? craftsman...
Hi, I would suggest taking the main jet out of the carberator and cleaning it with carb cleaner. If you did'nt drain the gas out of it before winter, the gas has gotten old and has plugged up your main jet in the carberator. It could also be that the needle has got **** on it and is stuck, I'd clean that also. Your problem is all in the carberator, and old stale gas sitting in it all winter is the reason.
May 08, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
Over heating minutes after starting
remove engine "covers" clean debris from cylinder fins
Mar 26, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Think carberator is clogged up dont know how to clean
now days some of these carbs prices are reasonable enough to just replace it and be done with it. i would get my model, type, and code #s or whatever is on the motor, then call and price the carb
Oct 08, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engine wont fire has spark gas not getting thruogh
pour alittle bit in carb & if it starts then it could be the fuel pump or the fuel lines
Jul 19, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Putting the carberator back together.
one end to the govenor other end to the throttle on carb
Jun 30, 2009 | Craftsman Garden
Garden Logo
61 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
