Question about Garden
Troy-bilt bronco goes backward when put in forward and forward when put in reverse. this started when it got bound up between trees. whats going on. im 90
  • 472 Answers
You have bent the rod that hooks to the trans let me know if this helps or i need to tell ya more
Posted on Oct 04, 2009
Troy bilt Bronco, brake stuck. Won't allow it to move either forward or reverse
Brake caliper pins are frozen in place. Requires dis-assembly, cleaning, new pins as old ones are probably rusted, and re-assembly. Don't lose or forget to put the flat metal plate between the pins and the brake pad. If corrode beyond repair replace it.
Apr 15, 2015 | Troy Garden
What is the spark plug gap for the engine of a troy bilt super bronco crt tiller
go to troy blit and input model number, this will tell you what you need to know
Jan 22, 2015 | Troy-Bilt Super Bronco 16-inch 208cc...
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Tiller works in reverce won't go in forward drive tines will engage but does not have power in forward .
Go to smalleng.com and watch vid on how to adjust valves. It's a great place to start. Good Luck...
Aug 16, 2011 | Mtd Troy-Bilt Bronco OHV Tiller
When going forward the tines are going in reverse
I've never seen one of these so excuse my ignorance. Is it possible that the cable to change from forward to reverse is out of adjustment? Can you go to where the cable attaches to the shifting mechanism, detach it and manually try to change from reverse to forward? Hope this helps. Good luck!
Mar 13, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I have Troy-Bilt storm 7524 snow blower which normally works fine, however, it has started to have problems shifting back into forward gear after being reversed. I'll put the snow-blower into reverse gear...
Try lubing the linkage where it shifts from forward and to reverse the linkage is most likely freezing up or has snow or ice build up causing it not to shift, My thought is your shoving it hard enough that it finally engages when you get the snow or ice to break off.
Jan 05, 2010 | Garden
Troy bilt pony riding mower will go in reverse but grinds in forward where do i start
have a troy-bilt riding mower. place a gear in neutral and park it.
it dies instead idling. want to know why?
Jul 17, 2009 | Garden
I was cutting the lawn, went over a small ***** off dirt and the tractor will not go forward or backward any more. Engine stalled. Upon resarting it stall when put into gear and the throttle applied. ...
lift the seat and see if the pulley on the transmission turns, if it does then its probably a belt problem. Many of them have a 2 belt system that operates very much like a qurque converter, Find where the 2 belts meet and see if the pulley has anything lodged in it
Jun 26, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
How to install belt on Troy bilt tiller:
With engine OFF If you put belt on engine pully and driven pulley then work the clutch handle you should be able to see how belt goes so it tightens when clutch is worked.
Jun 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Troy Bilt Horse Lawn Tractor Transmission problems
you need to screw the transmision adjustment in so that it is push all the way in to gear.
Apr 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
140 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
