Question about Delta T17430 Chrome Innovations Monitor Double Handle Pressure Balanced Tub
The tub faucet drips for a long time after the shower is shut off unless I turn the temperature down to as cold as it can go. Then it will usually stop dripping a few minutes after I adjust the temperature to cold. If I do not turn the temperature to cold it will continue dripping until I turn it to cold.
  • 129 Answers
You will need to replace cartidge assembly with spring and washers part number "RP46463"
Posted on Oct 04, 2009
How to adjust Banner M580 Series faucet to provide a better hot/cold balance?
Could be a defective mixing valve or blockage in the cold water input line to the valve
Jul 26, 2016 | Banner Faucets Pro Series M580 Single...
Glacier bay faucet manual
Contact glacier bay to get a replacement control/handle assembly. Usually their customer service department is good at replacing the parts under warranty
You should have individual cold & hot water supply shut-offs in your basement for your tub/shower; if not, now's the time to install them.
If I could be of further assistance, please don't hesitate to ask.
Jul 28, 2014 | Pegasus 873-0127H2 Lyndhurst Single Handle...
I have Danze, single handle shower faucets that were professionally installed in 2005. One shower faucet has not hot water, just cold and when the handle is turned on all the way to hot, there is an itty...
Replace valve canister- no construction- just remove after taking time to shut off water- a few screws and the job takes 15 minutes. I take for granted you have good water hot/cold to the fixture. This fix will cure most temperature balance problems.
The single lever system is a EZ care system. Note the canister can malfunction faster when exposed to untreated hard water.
Nov 17, 2010 | Danze & Single Handle Tub And Shower...
On new Moen shower faucet, when I turn on faucet, water drips from shower also.
The faucet was installed upside down.
The shower riser pipe in the wall is to short( the distance between the faucet and shower head).
One of the biggest problems is if your shower faucet was installed with Pex pipe to the tub spout. Pex pipe will restrict the flow and force the water back up and out of the shower head.
The tub spout must be piped with at least 1/2 brass pipe nipples and fittings, or 5/8 OD. copper pipe and fittings.
Hope this helps, if you further questions please let us know.
Sep 08, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
When I push the faucet to off I get med fast
push down the tub-spout lift rod and it will empty the remaining water that is between the shower valve and the tub spout
Mar 10, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Been using shower for a couple of years .when fifished showering it will not shut water off all the way felt like stem was stuck not going back to close of water supply.After forcing it back all the way it...
First determind what side is dripping(hot/cold) then turn off water to entire house unless you have separate shutoff for shower behind wall. take a screw driver remove handle then use channel lock pliers to remove stem on the bottom side of the stem there will be a screw with a rubber washer on it you must remove the screw and replace the washer them re assemble Oh go to home depot and buy a the assorted pack of washer for faucets and stems find one that fits the pack cost about 4.99 best to change both rubber seal washer on hot and cold sinc e you have the water off
Jul 02, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Tub faucet drip
Hi, You have to replace the two rubber cups in the hot&cold faucet lever. Let me know if you need more info.
Nov 09, 2008 | Banner Faucets Pro Series M580 Single...
Delta T17430 Chrome Innovations Monitor Double Handle Pressure Balanced Tub Logo
296 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
