Question about Apex Digital GT2015DV 20 in. TV/DVD Combo
APEX Tv/DVD has a parental control password and I don't know what it is. how do I clear it or set a new one?
This site provided the original user guide and I was able to find the factory codes in there and that allowed me to remove the parental control codes, plus now I can put in my own. Thank you!
Posted on Oct 05, 2009
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
Jul 07, 2013 | Televison & Video
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
I have a RCR universal remote. It turn the tv on/off but the red lock remains on my apex 2011s. What do I do?
The Apex prompts you to
enter a 4-digit code when you set up parental controls. You can block programs
according to their MPAA ratings or their content designations, such as V for
violence or S for sexual situations. You can override parental
controls on most Apex models by simultaneously pressing the F and mute buttons
on the remote control. If you own Apex models GT2011J or GT2011S, hold the
remote\'s display button for ten seconds. The red key will vanish and the V-chip
will unblock your program.
Apex\'s default parental
lock control code is 6688, so if you haven\'t set a new code, entering 6688 will
remove the red key and unblock your program. If you\'ve set a new password and
forgotten it, entering 3308 will reset the code and unblock your program. For more, http://electronicshelponline.blogspot.com/
Jul 01, 2013 | Televison & Video
PF2020 RESET CHILD LOCK
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
Oct 31, 2012 | Apex Digital PF2020 20" TV
Need to know how to remove the red key on tv and code
When a red key appears in the lower left corner of your Apex television screen, the set's V-chip is engaged, preventing you from watching restricted content. You can override parental controls and reset your television's pass code with your remote.
Parental Lock
  1. The Apex prompts you to enter a 4-digit code when you set up parental controls. You can block programs according to their MPAA ratings or their content designations, such as V for violence or S for ****** situations.
Disabling the Lock
  1. You can override parental controls on most Apex models by simultaneously pressing the F and mute buttons on the remote control. If you own Apex models GT2011J or GT2011S, hold the remote's display button for ten seconds. The red key will vanish and the V-chip will unblock your program.
Override Codes Apex's default parental lock control code is 6688, so if you haven't set a new code, entering 6688 will remove the red key and unblock your program. If you've set a new password and forgotten it, entering 3308 will reset the code and unblock your program.
Sep 25, 2012 | Apex Digital Televison & Video
How do you reset forgotten parental control password?
try 3308 if not read the instruction manual or telephone them for support
Jan 04, 2009 | RCA HD52W59 HDTV Projection Television
I dont know the parental code and my color is messed up how do i fix it.
OR TRY THIS..
Bill
Jan 30, 2008 | RCA TruFlat 27F520T 27" TV
APEX Television
1234, if the factory setting...accordianman
Jan 08, 2008 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Apex Digital GT2015DV 20 in. TV/DVD Combo Logo
341 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
