Question about Car Audio & Video
Need to know what colors are the wires for like power speakers remote ground
  • 84 Answers
There isnt a remote wire in the factory wireing u run ur own from the deck to the amp.its usually white green purple grey.also look in the trunk at the wires goin to the rear speaker
Posted on Oct 04, 2009
Need a wiring diagram for a DEH-X6600BT. IT'S GOING IN A 1993 CHEVY ASTRO VAN. I KNOW KNOW THE WIRES OF THE VAN. I NEED TO KNOW WHAT TO CONNECT TO ON THE RADIO. THAY ARE DIFFERENT COLORS.
I hope someone comes along who can help; in the meantime, you might try the following. Naturally the power wires will be 12V and usually red(+) and black(-), if they're not, you can examine the other colors, to determine if their are separate ground wires for each speaker. If it uses a remote, and you want to hook that up; I can't help. sorry. But, if the speakers have a common ground, there will only be 1 wire for each speaker, the other connects to the ground of the car. If there are two wires for each speaker, they will be 4 different colors, with a 2nd wire which has the same color for all 4 speakers, so each speaker has a colored wire, and a common colored wire. This will leave the power connections, unless you have other controllers (see above).
One you know which are the power wires, you can connect them to a spare 12 V battery, and then comes the fun part. While adjusting the radio for front back, left and right, using the colored and a common wire for each speaker, this will be the same as the ground wire for the power even if not the same color, you can connect it to ground for the test. Then connect the colored wire and common wire to a speaker, by adjusting the controls you can find out if that colored wire is for front or back, left or right. Then you'll have your color code.
Although prolonged use of only one speaker or only two could cause damage to the radio, short use to troubleshoot at low volume shouldn't be an issue. Just don't use it that way.for a long time!
I hope this helps. Let me know.by rating up my answer! :-)
Sep 03, 2015 | Cars & Trucks
What is the color codes to a pioneer dxt-2266ub? putting it into a 1997 firebird.
PIONEER STEREO DXT-2266UB
----POWER---
Yellow = Radio Constant 12V Batt +
Red = Radio Switched 12V Acc +
Black = Radio Ground Neg -
Blue/wht = Remote Amp turn on or Pwr Ant
----SPEAKERS----
White = Left Front Speaker Wire (+)
White/blk = Left Front Speaker Wire (-)
Grey = Right Front Speaker Wire (+)
Grey/blk = Right Front Speaker Wire (-)
Green = Left Rear Speaker Wire (+)
Green/blk = Left Rear Speaker Wire (-)
Purple = Right Rear Speaker Wire (+)
Purple/blk = Right Rear Speaker Wire (-)
RCA = Output to Amp
Owners Manual = http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DXT-2266UB_OwnersManual0607.pdf
1997 PONTIAC FIREBIRD WIRE COLORS
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Radio Power Antenna Trigger Wire: Pink
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′ Speakers
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′ Speakers
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Hope this info helps
please let me know if you need any further info
May 20, 2011 | Pioneer Car Audio & Video
I need the radio wire color code or wiring diagram
two purple wires, speaker
two white wires, speaker
two gray wires, speaker
two green wires, speaker
black wire, ground
yellow wire, battery...for memory( goes to a constant 12V power source)
red wire, ignition, to pwr on when key is on
blue wire(remote wire if you have a system)
Mar 18, 2010 | Chevrolet C1500 Cars & Trucks
Need a wiring diagram for a sony cdx-gt08 it is going into a 2000 saturn sl2 I have the new wiring harness but need to know what wires go where
yellow to yellow main power wire
red to red key wire
black to black ground
speaker wires are green purple for rear speakers and white and grey for front speakers solid wire color is power and black lines is ground
orange is dimmer switch you wont need it
blue wire is for power anntenna your car shouldn't have it and blue with white stripe is remote wire if you have an amp it will shut off your amp when hooked up any other wire unnessary for your car some head units need a anntenna adapter to work good luck. remember ground before anything and disconnect the battery so you don't blow the fuse
Mar 13, 2010 | Sony XPLOD CDX-GT200 CD Player
I need to know what the speaker hookup wire colors on a Pioneer DEH-345 Car Radio CD player
Yellow: battery power
Red: switched power
Black: ground
White: left front speaker
Gray: right front speaker
Green: left rear speaker
Violet: right rear speaker
orange :dimmer
blue:amp remote on
blue/stripe:power antena
should be somthing like this, if you get an adapter from walmart or sonicelectronix it should just be a color code matchup for your vehicle.
Feb 08, 2010 | Pioneer Car Audio & Video
I hav a 95 berrta and im tying to put a head unit
Hello chrisuftring,
Here's a link to the wiring color code for the '95 Chevy Beretta.
You'll need to match the function of each wire from your head unit and the color code for that would be in your manual. Most aftermarket units are somewhat standard as far as power, accessory, ground, and speaker connections are concerned. But the wiring colors may be different for such leads as remote, power antenna, illumination, dimmer, and muting.
An Alpine head unit has the following wiring colors:
Blue - Power Antenna
Blue/White - Remote
Pink/Black - Audio Interrupt (muting)
Orange - Illumination
Red- Switched 12V+
Yellow - Constant 12V+
Black - Ground
Gray - RF Speaker (+)
Gray/Black - RF Speaker (-)
White - LF Speaker (+)
White/Black LF Speaker (-)
Violet - RR Speaker (+)
Violet/Black RR Speaker (-)
Green - LR Speaker (+)
Green/Black - LR Speaker (-)
With this head unit, you would wire Yellow to Orange, Red to Yellow, Black to Black, Orange to Gray, Blue to Pink, Gray to Light Green, Gray/Black to Dark Green, White to Tan, White/Black to Gray, Violet to Dark Blue, Violet/Black to Light Blue, Green to Brown, and Green/Black to Yellow.
Note that there are 2 "yellow" wires in your vehicle color code. You'll have to test them to determine which one is the accessory wire and which one goes to the left rear speaker. Using a 12V "test light" is the simplest. Connect one side of the light to ground. With the ignition ON probe the yellow wires. One of them should light the tester, the other one won't. Verify that the light goes out when the ignition is OFF and your have separated the redundant "yellows". The one that lit the tester is your 12V+ switched wire and the other one goes to the left rear speaker.
Hope this helps.
Sep 11, 2009 | Dual Car Audio & Video
Need wiring color code for power &speaker
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Aug 25, 2009 | Sony CDX-F5710 CD Player
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
Car stereo wiring diagram
Main power wires
Yellow to constant always on power
red to accessories
black to ground
blue if you have an amp this will be remote wire if you dont have amp then just cap off
the other wires are as follows
top section speaker wires right and left
bottom section speaker wires right and left
the speaker wires come in colors like purple purple line
grey grey line
orange orange line
white white blueline
these are your speaker wires simple just remember power lines grounds
May 03, 2008 | Boss 510CA CD Player
Wiring colors
You will need a voltmeter. Normally red is power, black i ground, yellow is memory power. the best way to know for sure is to use a voltmeter to test what each wire is recieving in power and when. If the key is off then the wire that has 12volts dc is for memory and the main power wire should be at 0volts dc. When the key is on that wire should have power now. the ground will be black on that car. Good luck.
Feb 20, 2008 | Car Audio & Video
Car Audio & Video Logo
184 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
