Question about Fellowes Office Equipment & Supplies
On my 58-87c shredder; it has four lightson the left side; i dont understand what the bottom light is when it is lit red. the shredder wont operate
2 Suggested Answers
fellowesrep
  • 102 Answers
SOURCE: red light on with green light
This is more than likely a sensor issue. Fellowes Customer Service can advise you on a solution with a little more info than provided. 1-800-945-4545
Posted on Feb 26, 2008
Shredder wont shred
My boss has a shredder that will not run unless the bin is exactly centered in the bottom of the unit. There is a safety switch inside there, and a magnet to activate it. Make sure nothing is interfering with the bin or the shredder fitting together.
On other units, there is a slot that must match up with the shredder. It will only work one way. See of the shredder will turn around and put it on the bin the other way.
Mar 10, 2012 | Aurora Electronics AS1018CD Shredder
Have a 1999 John Deere Dozer 650G LGP series and on the control panel where you crank the engine there are four lights to the left of the key ignition switch about dime size. Starting from left to right...
Check your hydraulic filter,if it has not been replaced in a while the filter may have a restriction allowing the light to illuminate. The red light may be telling you there is not enough flow through the filter to operate safely with out doing damage to the hydarulic system.
Dec 13, 2009 | Garden
Green and middle red light go on but motor does not. does not shred
Check the sensors on top and bottom of cutters. Clean with cotton swabs and compressed air. If this does not help, bad sensors or main board.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
May 14, 2009 | Fellowes DM8C Cross-Cut Shredder
I have a fellows 420 cc power shredder that will not start when paper is inserted
if ther are no red warning lights lit, then you will have to replace the auto feed senors or the main power switch.
May 13, 2009 | Office Equipment & Supplies
How to disassemble the mailmate spl-727MM. I think there are 2 screws from the bottom under the rubber pads and I think you need a long screw driver but what kind? Phillips or regular? No. 1 or No. 2?
1. Remove the two rubber pads (only two out of four pads with Phillips screw, you should be able to see which two).
2. Use a long Phillips screw driver to remove the two screws
3. You may still not able to remove the the housing because there are double side tapes sticking the front part of the housing to the shredder's base, use a ruler (steel ruler) to detach the tapes
4. You should be able to pull out the housing (the machine should be up-side-down) and you should be able to do what you wanted to fix.
Enjoy.
Mar 09, 2009 | Office Equipment & Supplies
Unjamed, but jammed light remains on and won't shred
Most likely the PC board has gone bad. It will cost over 100.00 from fellowes.
Sep 06, 2008 | Fellowes Powershred 480 Shredder
Buzz wireless buzzers
i tried several times to fix the problem by syncing the buzzers. it never solved the problem. finally i removed the dongle and blew on it very hard. i plugged it back in and retried. THIS ACTUALLY WORKED. i have played several times with no problem.
hope this is helpful.
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
Red Light on, but no jam
Your problem is probally with the safety interlock switch on your machine. On the PS-65c It is located on the right hand side of the unit. There will be a tab of plastic on the inside lip of the basket that goes into a slot on shredder head. If plastic piece is bent or broken machine will not operate. If it does not appear broken make sure when you put shredder head on that it fits flush all the way around on the basket. If none of this helps contact Fellowes Customer Service at 1-800-945-4545 and we will be glad to assist you further.
Jan 28, 2008 | Fellowes Powershred PS-65C Medium-Duty...
Red light on with green light
Oct 16, 2007 | Fellowes PS70-2CD Shredder
240 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
