Question about Nikon Optics
Night vision quickly fades out after unit is powered on. If unit is turned off and then on, it will work for several seconds and then fade to black again.
  • 1 more comment
  • msharak Oct 04, 2009
    rigel optics d-2mv
    Batteries are duracells dated to expire 2013. I have replaced them with new ones twice. Thanks
    Also wanted to add that the IR illuminater doesn't seem to be effected.
    Sergeant:
  • 247 Answers
Im assuming this has batteries,ethier rechargable,or alkaline replaceables,without specfic make and model,all i know so far is nikon night vision,having said that rechargible,battery may not pass load test even though appears to function and charge normally,if this doesnt apply ,bad solder joints or connections on main circuit board,would be the next thing i would inspect, ,you say it works,then it doesnt,as long as power supply is constant and capeable,circuit failure is most likely,power transistor,diode,capacator,ect.,without schematic,visual inspection,and limited,multimeter testing ,hopefully will give you some sign of problem.sorry for the vauge answer,if more tech info is avialable post comment and ill try to help further,hope this helps,aloha from maui todd0708
Posted on Oct 05, 2009
    President:
  • 1,564 Answers
Quite simply it sounds as though you've got an outdated battery. They will show a full charge and just after a few minutes use they go dead. This also pertains to rechargeable batteries
Posted on Oct 04, 2009
Please specifiy the make and model. Thanks..
Posted on Oct 03, 2009
My dropcam pro's night vision is not working. it fades out after a second or two
contact the makers website and see what support can do for you
Mar 12, 2015 | Optics
Maglight fades to off after 5 seconds
Has this just happened after working ok? Is this a new maglight? Have you tried brand new batteries? Have you checked metal contacts to the batteries?
Dec 19, 2014 | Rothco Maglight 3-D Cell LED Flashlight -...
Unit powers up but after about 30 seconds the image fades out even with the power still on. what is wrong?
Lets see here, new battery, not showing it to bright light, have you looked at bright lights in tha past? Has it been droped? How long have own ths NV? There could be a number of problems. stewbison
Jun 15, 2011 | Optics
I have an RCA HD52W59 TV that will turn on and picture is fine for awhile, then it will fade to total black. Still has sound and does not power off. Nothing will show on screen, not even menu options....
Thats a deflection problem which is causing the CRTs to shut down during deflection loss. The deflection board will need replacement. You can get replacement deflection boards from www.tvrepairworld.com
Apr 23, 2011 | RCA HD52W59 HDTV Projection Television
When I got this it worked now when i press the power button the power light comes on dim and goes out right away. I have tried changing the batteries and no joy. Any help would be great.
Hi, Quit a few of these NV monoculars don't have auto shut offs. So the switch on you NV unit is a momentary switch--that is as long as you push on the switch the unit will stay on. Once released the on/off switch, image will start fading because the capacitors are discharging there current to a point where image in the tube has clasped. stewbison
Feb 15, 2011 | Night Owl Optics Discovery™ NODS3...
I have a NV-100 Compact with illuminator should I have to hold the switch pushed in all the time I am trying to use it?
Not all the time, but if you release the button the image will fade to nothing in a minute or so. This is how it switches itself off. Don't expose it to light while it's powered up as this might damage it.
Oct 17, 2010 | Kalinka Zenit NV Piezo Russian Night...
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Optics Logo
88 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
