Question about Hotpoint HSS25GFP Side by Side Refrigerator
Have a hotpoint side by side with water and ice in the door....and you can get ice but no water....we put in a new filter but no water will come out,,,,,help...thank you
Shawn- I had the same problem. Take a hair dryer and blow on the inside of the freezer door behind the water and ice dispenser. The water lines freeze up occasionally. Heat it for about ten minutes, spread the heat around so it doesn't melt anything. When you are done, let it stand for about five minutes before you try to get water out of the dispenser. I hope this works for you. Good luck!!!
Posted on Oct 03, 2009
Ice maker not filling door not dispensing water
Make sure the temps in the fridge aren't cold enough to freeze the filter... Water valves rarely fail at both solenoids at the same time, so be sure the water supply is turned on and that the water line is not kinked (bent in half) behind the machine... Hotpoint Refrigerator Water Filter MWFP , Hotpoint Refrigerator Water Inlet Valve WR57X10032
Aug 02, 2016 | Hotpoint HSS25GFP Side by Side...
Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
Refrigerator makes ice and dispenses ice, but does
could be valve, it is located underneath on back. it also could be the mother board. Check valve with ohms metter. Also make sure water resevior or water lines are not frozen inside refrig section. Also water feed line going up through door bottom hinge on freezer is not frozen. Disconnect at couplin at left bottom front and blow through line
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Water dispenser on Hotpoint S/S door stopped working but ice maker is making ice
could be water inlet valve in need of replacement.also cold be water filter blocked, although would only happen in an area of high mineral content.if your fridge section is lower than 0 deg c, the water holding tank may be frozen up.also if your cab is the type with twin cooling, ie has a cooling element (evaporater)
Feb 27, 2010 | Hotpoint HSS25GFP Side by Side...
Ice maker not making ice.
I'm sure you already replaced the MWF water filter?
Aug 07, 2009 | Hotpoint HSS25GFP Side by Side...
I have a GE Hotpoint Side by Side refrigerator Model #HSM25GFRA SA and have a problem with the water dispenser. I've switched out the filter with two new ones but still have the same problem - no water...
Alot of the GE refrigerators have problems like this. You either need to replace water valve on the back because one of the valves has stopped working OR the tube in the door has frozen and the door will need to be replaced. The best way to tell is remove the hinge cap on the bottom hinge and disconnect the little adapter put a towel down there and then trigger the water dispenser. If water comes out, the tube is frozen in the door. If not, replace the valve.
Jul 15, 2009 | Refrigerators
Ice Maker
First, are you getting water at the door? If not, the filter is installed wrong or there is some packing on the filter you didn't remove.
Jan 10, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
60 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
