Question about Pool & Spa
My spa pump is not turning on after priming sequence. I took pump to leslie's and it is working. The pump panel is saying 137 then 65 in beginning. Then 24 and 12 to PR as normal. Never noticed the 137 and 65 code before. Put meter to leads and looks like I'm getting power. I am stumped any suggestions. Thanks mike
  • mhwaverider Oct 04, 2009
    Tried it just for the heck of it, but no joy. The pump was running before. I don't think its a priming problem. I'm pretty sure its something electrical. I'm trying to see if the 137 or 65 numbers mean anything these are coming up before the priming mode on the display unit.
  • mhwaverider Oct 05, 2009
    I used my meter and was getting a low voltage at the input of the spa from the GFCI breaker (only reading 90 vac on black). The wire on the GFCI breaker was loose the set screw holding the wire wasn't tight. Ended up being easy fix and saved me a load of cash. Thank you so much for your help.
  • 990 Answers
Is this a self contained spa? If it is Your pump probally is running , but if you pulled it out and put it back you created an air lock. You can fix this simpley by opening your drain valve untill you get a steady flow of water out of it. Also check to be shure your shut off valves are fully open before you start.
Posted on Oct 03, 2009
Testimonial: "Thanks for the info. Gave me a good starting point and was able to fix problem very easily."
  • Kieran Ruppert Oct 04, 2009
    So your motor is not running now but it did at Leslies. Are the readings your getting at the spa panel or are you using a meter to ck the wires at the motor? If these are varying volts at the leads you need to start at the breaker and ck at each stop the power makes. If it is a plug in spa ck the outlet then in the main box in the spa be sure to ck these with the leads off the motor as you can get bleed through the motor and get a false reading if that is the case. If it is a 220v spa you can ck in the power box under the spa to start. If your power is still fluctuating at this point it is in your wires to the spa and you will probably need to run new wires. Although it could be a bad breaker but you will see that when you ck for power there. Its hard to describe how to run down the problem if it is under the spa. once in the main power box in the spa assuming you have good power there, your first stop is the main contractor in the panel this will have two heavy leads going in and two heavy leads going out. Secondary power will come off this in smaller wires (#14 like small household wireing) If you have bad power on the load side of this the contractor is bad. This can be one of two things a bad contact or the solenoid electromagnet that pulls the connection in is bad. If the main wires have good power and the contractor is pulling in then you can ck at the side of the box where there is a plug coming from the motor ck to see what kind of power you have here. If you have good power here ck your connections at the motor again. be sure to confirm wiring on plate on back of motor their should be a schematic on the motor for this. Back to the main contractor in the power box for the spa. If the solenoid doesn't pull you will need a schematic for the box probably glued to the inside of the box door. Here the smaller wires start where the power comes in and will go through a safety circuit if you can follow the wires you can ck different things in the box,(timers, thermostat, air control switches from spa side) all of this will be in the box along with heater circuit (main wires) Often this will get to be a mess of wires and all of it main line voltage if it looks to be to much let a pro get into it. most of it will be color coded and can be ran down. It will get confusing as all roads go out to different things and intermingle then end up at the motor. If your sharp you can follow these through. (power goes out to timer, jet switches, heater all of these will go back to motor to turn it on by themselves and will work at the same time so if you disconnect these make sure they go back wire for wire from where they came or you could cross polarity when things come on at the same time.) with these things the spa will normally run on one or two of the circuits but not another so your problem is probably before these circuits split or after they come together. Well that seems like a lot of stuff to ck but go one stop at a time from the breaker and where the power stops is where you will find the problem. You may end up getting a pro but this should at least cut out the simple stuff. Good luck, write and let me know how you do. Kieran
  • Kieran Ruppert Oct 06, 2009
    Glad I could help :)
Pool water will not circulate even though pump is running
if the water doesnt circulate, there could be many causes. start at the very beginning. does the pump sound 'normal'? if there is rattling or buzzing, the pump might not be turning and there fore no circulation. is there water in the system? even though most pumps are 'self priming', you should fill the hopper with water to prime it. are the lines open? make sure the supply to pump from skimmer is free of blockage and that the return lines to pool are open and free from blockage. if all this looks fine, then you have to get deeper into diagnosis.
Dec 20, 2015 | Hayward Pool & Spa
How do you prime it?
Hi Tom:
Priming is essentially the action of getting the air out so that the pump can push water. Sometimes there is a plug at the top of the pump. If you remove it, either air and then water will come out, or nothing comes out and you can see no water inside. Fill it with water, put the plug back in, and it should work. If the pump is higher than the water level in the pool you will have a bigger task.
We'll cross that bridge if we need to.
Apr 09, 2015 | Pool & Spa
Waterway pump not priming
Foam will definitely keep a pump from priming. Why do you think it's the calcium causing the foam? I have added large amounts of calcium to pools and I do not recall ever having any foaming issues.
Check to see if your impeller may be clogged. Take the lid off of the pump and fill the basket up with water. Leaving the lid off, start the pump for three seconds and then turn it off. The water should be sucked away almost instantly. If the water level drops slowly you have debris clogging the impeller. If that is the case the pump needs to be opened and cleaned.
Jul 23, 2013 | Waterway Champion 1 1/2 Hp 230v Energy...
Pool pump wont prime
if this is a inground try only the main drain if it works something is in the skimmer line
Jun 01, 2013 | Pentair Pinnacle High Performance 1 HP...
How do I prime the pump on my VS500
The pump will prime when you turn on the circuit breaker. There is a prime cycle that will run for a couple of minutes to get all the air out of your spa system before the heater will engage.
Rod
US Parts Center
888-521-6183
Apr 05, 2013 | Pool & Spa
The motor and filter seem to be ok, but can't get it to prime. Everything is working,just very little water pumping into filter.
It sounds like you have a suction leak or a clogged impeller. A quick way to check the impeller is to fill the pump pot (where the basket is) with water, then start the pump with the lid OFF. The water should be sucked down into the pump immediately. Turn the pump off. If it took more than about half a second for the water to disappear you need to open the pump and clear the debris from the impeller.
Otherwise any leak from the skimmer to the pump will cause the problem. Make sure your pump lid o-ring is lubricated.
Not gettin suction from line it is free of debris no leaks back of pump does not have good suction but water when i try to prime it will not **** from suction pipe but does try to prime filter helpppp
Hi crazee,
If you go through the prime sequence and the water just sits there, the impeller may be damaged. Over time the blades get worn down.
I could help you better if you provide some more detail.
Mike
Jun 17, 2010 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Leslies put new 1 hp motor with old pump housing I put unit back in in ground pool but pump will not prime. used to work good but motor burned up. suspect leak between pump and screen area.pump works when...
Your pump is drawing air which is causing cavitation. Check all fittings leading to the intake. Then after that, pull the pump and re-seal the housing. That should be all.
Jan 15, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
Pump problems?
Their can be a number of things.. Is the pump priming. Hopefully it did prime. what usually happens after running for awhile, with no cool water coming in. The water inside the pump basket starts to heat up, then the tubing turns to brownish on the input side of pump and exhaust side. (you could have air leaking in throught the input side, which could result in the pump never priming) Or if it is priming and no pressure (can mean your empellar is clogged up)
Mar 07, 2009 | Pentair Mastertemp Heater
Pool & Spa Logo
118 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
