Question about Kenmore Dishwashers
My ultra wash model 665.1359 wont drain.found two half inch plastic balls in motor drain outlet.are the balls part of the drain system?
  • 641 Answers
SOURCE: Kenmore Ultra Wash Model 665 Dishwasher
Dishwashers which are properly installed and regularly used won't normally have a problem with bad odors. Check the following: ?Was the drain hose brought in at the top of the cabinet, or down near the floor? it must be 34" from the floor. ?Do you run the unit at least once every 2 days? -Run a cycle with a quart of vinegar to clean the tub and pump. ?Does the disposal tend to back up slightly when the dishwasher drains? Drain may be clogged. -Don't use gel detergent! ?Check your water softener(If so equipped) These can cause foul odors in the water supply if not properly balanced or maintained Good luck!
Posted on Sep 02, 2007
SOURCE: Kenmore Ultra Wash Dishwasher - 665 - 13783
dcvxzcxzcxzczxc
Posted on Feb 26, 2008
reg501
  • 413 Answers
SOURCE: Kenmore Ultra Wash Dishwasher does not drain
Some Kenmore DW have a check valve attached to the sump that may have a blockage. Remove toe panel, look for a long, white, plastic fitting attached the front, right side of the sump. Remove the drain hose from the valve. Unscrew the valve from the sump and inspect for debris inside the valve.
Posted on Jun 14, 2008
SOURCE: My kenmore ultra wash model
my model #665 dishwasher will not pump water into the unit
Posted on Jul 15, 2008
SOURCE: Kenmore dish washer wont drain
Those are Chinese massage balls. You place them in your palm and rub them together and the result is a "calming" effect, which are ingeniously placed their by the courteous engineers at Kenmore to help you relax while you perform the self-repair. Just kidding. I had the same problem and learned that they are called "float balls". There should a small hole where the water comes up and drains - they are placed in that hole.
Posted on Nov 27, 2008
My kenmore HE2 wont drain.
Hi there I suggest that some machines have that white ball to stop water from syphoning out of the machine when on a wash cycle but your problem is either a blocked pump, (try and take the pump off as some debris will go past the filter and stop the impeller from turning hence no water being pumped out) or a kinked outlet hose which can easily happen when you push the machine back into it's place in the kitchen.
I'm not too conversant with your make of machine but in general all machines are basically the same.
If you can't hear the pump spinning then it may be something more like one of the circuit boards may have failed.
Mar 11, 2014 | Kenmore HE2 Plus Front Load Washer
Washer stopped. F6 code, didn't drain.
that is called an eco ball it is part off the machine
its job is to save money by not heating the water below it in the drain pipe
Dec 29, 2013 | Kenmore 46462 Front Load Washer
MY DISHWASHER WONT KICK INTO WASH CYCLE CAN HEAR THAT IT WANTS TO BUT DOESN'T ..IT WILL FILL AND DRAIN AND DRY...CHECKED DRAIN AND FILTER CLEAR
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump.
First though, do you hear a quiet sound of a motor starting once the unit has completed filling with water ?
( it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Viking...built by "Asko"...are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver )
If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely.
This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design.
What happens typically is the ball-bearings from the upper rack holders ( which are plastic which fatigues due to heat and fall apart ) fall out making their way into the sump, hence breaking the wash impeller from the motor.
Let me know what you find and I'll try and help you move forward from there.
Good luck,
Macmarkus :)
Aug 26, 2010 | Viking 24 in. Professional Series VUD141...
Water does not drain out
Hi and welcome to FixYa, I am Kelly.
There is always just a minimal amount of water in the bottom of a dishwasher so that the pump seal does not dry out causing water to run through the pump motor. Usually though it is not visible yet is is possible.
Excess water in the bottom of the tub post cycle are a sign of draining problems however this is a list of what it could be.
1. A partially clogged drain
2. The timer motor is not functioning properly
3. A broken or worn pump impeller
4. Clogged wash arm holes.
Here is what you need to do:
Check your entire drain system. Start at the final outlet and work your way backward to the motor pump connection on the dishwasher.
Suspected areas are.
a. The sink connection outlet is clogged (this can be inside a garbage disposal.
b. The air-gap is clogged in the very top part of the air-gap (Usually located on the back of the sink and is around 3 inches tall) Remove the cover, unscrew the top nut and check under the horse shoe bend inside the plastic top for obstructions. Clean as needed)
c. There is debris on top of the the motor pump housing blocking the inlet drain. (This would be inside the housing of the lower wash arm on the very bottom)
d. The motor pump outlet drain port is partially blocked. (only accessable from the motor pump exit hole after drain hose removal.)
A partially blocked inlet tub drain to the motor pump would also explain why the lower part of the dishes are not getting clean. Additionally you would have spotted dishes post cycle.
When the drain is partially blocked some models use the float level switch in the tub to control the advancement of the timer. If the water does not drain the motor pump continues to run and run and the cycle does not advance until the tub is drained and the float switch senses same. i.e extended cycle
Check under the float assy for debris.
One more thing to check is the lower wash arm holes for debris or obstructions. If the wash arm is retaining water it can drip out after a drain cycle and cause the puddling you noticed.
Thanks for using FixYa.
Kelly
Apr 29, 2010 | GE 24 in. Profile PDW7800 Built-in...
Not washing dishes
Hi and welcome to FixYa. I am Kelly.
Dirty dishes post cycle are a sign of draining problems however this is a list of what it could be.
Kelly
Apr 27, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Not cleaning dishes properly
A partially blocked inlet tub drain to the motor pump would also explain your soap dispenser problem. Additionally you would have spotted dishes post cycle.
Kelly
Fridgidair Dishwasher takes long time to run
ok with the soap prime the sink before you start it and clean the dish washer.take a table sppon full of tang put it the dispencer and run the unit this will clean the unit
Apr 25, 2010 | Dishwashers
I have a whirlpool ultra care 11 washer, model # LSQ92002T0. WILL NOT DRAIN OR AGITATE. STARTED FINE STOPPED DURING USING. THANK YOU
Your motor coupling is probably broken. Tip washer back and look for rubber shavings or any broken plastic.Motor coupling goes from motor to transmission This is common with these models/t.Visually check coupler.
Jul 07, 2009 | Whirlpool Washing Machines
the odd shaped screws are called trox screws and can get a set of drivers any where also pull the hose off the sink connection and check it there the main motor reverses and acts as the drain pump if you recently installed it to a garbage disposal make sure you knocked the plug out where the dishwasher connects if not check the hole there i found a olive pit in one one day now when you go to by the trox drivers and a bunch of things are using them now days get the set in the metal case that fold out like a pocket knife if you know what i mean and the drain hose must come up 20 inches and then loop to the sink drain so let me know what you find and if i can help further
Mar 18, 2008 | Dishwashers
Dishwashers Logo
96 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
