My Maytag Neptune washer will not spin. a year ago i installed the R11 Q6 repair kit and things worked fine. I have 120 v at the wax motor and i can watch it move. i have continuity through the spin enable switch and the door lock light is on. The repair to the control board looks good but is my biggest unknown. plus how tough are the bearing kits to put in?
  • John Loper Aug 11, 2012
    Motor control board fuse is good. I also just noticed that if I unplug the machine for a minute or so, plug it back in, and push the "START/STOP" button, the "ON" light comes on for a split second.
    President:
  • 1,304 Answers
Look closely at the motor control board bottom right
check the on boad fuse
and the heat sinks
if its just the fuse you can replace that
Posted on Oct 05, 2009
    Motor control board fuse is good. How do I check the heat sinks?
Neptune Washing Machine (MLE200AWW) spins but water is not pumped all the way out. I can hear it slosh in the drum if I spin the drum manually.
Hi, the sloshing sound is normal because of the balance ring which has liquid in it...
I would be concerned about your door latch wax motor ( part # 12002535) though... See Neptune Help for more information about replacing the faulty wax motor with brown colored actuator tip before it damages your machine control board. When the wax motor shorts out it will blow the Q6 triac and then the R11 resistor will burn and your door probably won't lock anymore as indicated by the door locked light not coming on. The next thing you will notice is that your clothes will be soaking wet after the wash cycle because the spin cycle will not work if the door does not lock...
Your machine control board is located above the dryer on the right side.
Every Maytag Neptune front loader with a timer knob (non digital) has a wax motor and all of them shipped with faulty one except the later 2000 series stacker models. You should proactively replace the wax motor with the new design (with black tip) to prevent the Q6 R11 failure on the control board. If you're too late you can try the STAGE 1 repair kit at the same site above.
To inspect your door latch wax motor on the stackers you:
? Unplug machine
? Remove the (2) screws holding center panel and remove panel
? Remove the (1) center screw holding the top panel located inside compartment above washer
? Remove the top panel to expose the door latch assembly
I hope this helps you.
Apr 25, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
Tip
Maytag Neptune Front Load Washers Machine Control Board Repair
Component failures on Maytag Neptune Font Load Washers such as the pressure switch, wax motor, hot and cold water valve solenoids, timer motor, 24 VDC circuit, and the overall electrical buffer circuit have significant effect on the machine control board. Failed resistors on the machine control board can be used to determine failed washer components. Resistor R9 is associated with the pressure switch, R11 is for the wax motor, R51 for the hot water valve solenoid, R52 for the timer motor, R53 for the cold water valve solenoid, R143 for the 24 VDC circuit, and R162 for the overall electrical buffer circuit. The TRIAC Q6 is also associated with the wax motor while TRIACS Q3, Q9, and Q17 are for the timer motor, cold water valve solenoid, and hot water valve solenoid respectively. These TRIACS must also be replaced should the corresponding resistors fail or burn out especially when there's no power going to the associated component.
The most common problem experienced is the failure of the wax motor as indicated by the inability of the washer to advance to the high speed spin cycle with the "door locked" light not lit. Replace the TRIAC Q6 and the resistor R11 on the machine control board to get the machine back into operation. Use MAC97A6 or NTE5656 for Q6 and a 3.9 kilo-ohms carbon or carbon film resistor for R11. It is recommended to install a 1/2-ampere pico fuse in series with the wax motor to prevent damage to Q6 and R11 should the wax motor shorts out and fails again.
Replacement of the wax motor is a must before installing the repaired or new machine control board to prevent damage to the repaired or new part. Make sure the wiring harness connections of washer components are good and snug fit. Reseat the connectors several times to clean off corrosion build up both on the connectors and terminals.
on May 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag MLE2000AYW will not lock, how hard is it to replace or fix?
  • Unplug machine
  • Remove the (2) screws holding center panel and remove panel
  • Remove the (1) center screw holding the top panel located inside compartment above washer
  • Remove the top panel to expose the door latch assembly
Mar 27, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
The door will not lock
There is a small actuator that locks the door before the spin cycle located in the door latch assembly. This actuator is called a wax motor, Maytag part # 12002535 is the redesigned part. It works by heating a ball of wax up which causes the actuator pin to push out and lock the door. It takes around 45 seconds to extend so it is rather slow compared to a typical electromechanical solenoid. The older wax motors have a brown actuator pin while the newer version has a black actuator pin.
The wax motor failure is caused by moisture penetrating the wax motor (older design) over time, which causes the electrical resistance to drop to such a value that the small Q6 triac located on the upper control board overheats and shorts out internally. The triac is essentially an electronic switch that is controlled by a low control voltage, which is provided ultimately by the processor U1. The R11 overheats because the failed Q6 is allowing 120 volts on the triac's center control pin. When this happens, R11 burns and opens up electrically. Sometimes Q6 still looks normal and other times the plastic case ruptures after the failure. However, a burnt R11 is the telltale sign that you have had this failure and the Neptune washer should be left off to prevent further damage to your upper control board.
To inspect your control board you need to do the following:
1. Unplug your Neptune's power cord.
2. Remove three Philips screws along top of washer console.
3. Pull top of control console towards you while pushing bottom of console away from you.
4. Control board is located behind timer assembly on back panel.
5. Inspect the R11 resistor located near the left control board mounting screw.
If your R11 is burnt, you have two options. The first is to repair the control board and the second option is to replace the control board. To repair your control board you will need a 25-watt pencil type soldering iron, solder, diagonal cutters, needle nose pliers, replacement Q6 and R11 components. Whether you repair or replace control board I would not power up machine until the new wax motor is installed or you risk damaging your repaired or new control board again.
If you have not experienced the No-Spin problem consider yourself lucky because you are now aware of the issue and can replace the wax motor before you have a failure. You need to inspect your door lock wax motor and make sure you dont have the older style with the brown actuator pin. Note: If you identify that you have the older brown pin wax motor you need to replace it a.s.a.p. so you don't experience the R11/Q6 failure. I would not use machine until the original wax motor is replaced
Dec 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer #MAH400AWW drains water fine but will not go into high speed spin cycle
Your washer uses a wax motor door latch assembly with a high failure rate that led to the filing of class suit against Maytag in 2004. The failure of the wax motor results in a no spin problem.
Verify first if the door lock light is on. If not, the wax motor failed and resistor R11 and transistor Q6 on the machine control board also failed. Replace the wax motor and R11 and Q6.
Most technicians will advise you to replace the machine control board and not just the wax motor. But replacing them is not a difficult task. You just need to know how to solder and desolder.
When you opt to ask a technician to repair your machine, insist that only the wax motor, R11 and Q6 must be replaced, not the entire control board. The service will cost you about $300.
Do not hesitate to inform me if you want to do the repair yourself for the complete disassembly and repair procedure.
Jan 13, 2010 | Maytag Washing Machines
MY MAYTAG NEPTUNE MAH4000 WILL NOT DRAIN OUT OR SPIN
Check if the "locked"or "door locked" light comes on. If it does not, you need to replace the wax motor in the door lock assembly and the machine control board, which is inside the control panel. The control board is expensive, so instead of buying the whole control board, if you're good in electronic repair and soldering, try checking ebay for the control board repair kit. Search for "MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT". It has all instructions how to do the repair. Good luck!
Dec 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Common maytag neptune washers malfunctioning-R11/Q6+spin switch!!
yes if replacing the machine control board because of burnt resistor you do also replace the wax motor and spin switch.the spin switch and wax motor are next to each other in a bracket above where the door closes top of door jam.where the door lock mechanism are
Jan 24, 2009 | Washing Machines
Machine keeps tumbling after wash cycle is completed.
Make sure that the replacement R11 is in fact connected to pins 1 & 2 of the Q6 triac. If the copper trace on the backside is open on either leg of the R11 to the Q6 then the wax motor will stay energized and that will cause the tumbling after the wash cycle.
See www.neptunehelpsong.com for a new funny song that explains the Maytag Neptune door latch wax motor issue.
Jan 21, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune not spinning - further help pls if you can
Hi Charles,
If your door latch wax motor actuator pin color matches the body color (brownish color) then you have the defective wax motor and it needs to be replaced. See www.neptunewaxmotor.com for step by step disassembly photos. Then, I would check the machine control board (located behind the timer in upper console) for a burnt resistor, R11 which is located near the left circuit board mounting slot. If the R11 is burnt you can try the STAGE 1 repair kit, which includes a new R11 resistor and Q6 triac and wax motor or you can purchase a new control board. Don't forget to unplug machine when servicing your Neptune.
You can try to solder the new R11 and Q6 into the machine control board as there is a video on the above mentioned site that shows you how to perform the R11 and Q6 replacement. Another option is to call local t.v. repair shops and see if they will replace the components for you for a nominal fee. I hope this helps
Nov 06, 2008 | Washing Machines
My Mother's Maytag Neptune front load washer has water left under the drum after the final spin cycle. I am not sure that this is normal. Please advise.
This is normal to hear water sloshing under the drum when machine is done washing and you spin the drum. This is part of their water balance method to help spinning procedure. I called a Maytag repair shop and they helped with my question.
Jul 23, 2008 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
