TURNED ON, HEARD A CRACK SOUND, NOW JUST A BLNKING RED LIGHT? PRIOR TO THIS THE COMPUTER WORKED FINE!---MONITOR WORKS ON ANOTHER COMPUTER....I GET NOTHING ON THE SCREEN & THE DISK UNIT DOESN'T FUNCTION....IS THERE A RESET SOMEPLACE ?..........THANKS, VINCE
  • 39 Answers
If the power LED is blinking red, that's usually the PC telling you there is an error. Is it an HP/Compaq? The number of blinks can tell you what the problem is. If you heard a crack sound when you turned it on, I'm willing to bet the power supply went. You can go to the manufacturer's website and look through their Support Information and see what the red LED tells you.
Posted on Oct 03, 2009
I have dual xhdr 6435 power is running to it but the red light won't stop blnking.
Do you have power going to both the red and yellow wires? It sounds like you may not have power going to the red wire.
Sep 25, 2011 | Dual XDM6825 CD/MP3/WMA Player
The monitor (Gateway FPD1975W) turns itself off after a couple of seconds. I have tried rebooting a number of times - same problem. When I turn the monitor off and then on again it works for a second or...
This sounds like the monitors power supply is failing. (if the monitor is truly right off) Use a flashlight to verify the back-light is not just the culprit. If you can see faint image in the monitor with the flashlight, then this would point tothe LCD inverter is failing. Its most likely the power supply board within the monitor itself. Typically It takes 3 35v 470uf capacitors to fix and a little patience to get apart. Do a bit of googling on "replacing the caps in a FPD1975W" and youll see what i mean. Cheers.
Sep 01, 2010 | Gateway FPD1975W 19" LCD Monitor
My monitor won't turn back on after a reboot, no on light, worked fine prior
check with the power cable or the video cable is connected correctly in the motherboard VGA or if you have graphics card connect the video cable of the monitor to the graphics card VGA slot.
Oct 20, 2009 | LG Flatron L1710S 17" LCD Monitor
Acer AL1914 black screen, green light
it sounds like a deleted driver? try getting the driver for the monitor, did you loose the Operating system at some point, if so try a system restore to a date when the computer was working properlly prior to the malfunction. It sounds like it restored you to a time before the driver for that monitor was installed.
Feb 16, 2009 | Acer AL1914B Black 19 in LCD Monitor
245BW Snap/Crack sound and then does not work
Be very careful! Some monitors/TV's have 30,000+ volts DC in them even when not plugged into AC house current. The crack/snap sound was most likely an electrical component breaking down and shorting against the metal of the case of the monitor. I would take the monitor to an authorized repair center because the danger of getting shocked/killed is very possible while working on this type of problem at home.
Nov 10, 2008 | Samsung SyncMaster 245BW Monitor
Dash lights
From the dashboard. 2 days prior to this my Airbag light fuse went out, I replaced it and now it works fine again. I am not sure if they have anything to do with eachother.
Oct 14, 2008 | 2005 Jeep Liberty
My Acer monitor sleeps on red instead of amber. Is this a problem?
Different monitors have different indicator lights. If you do not expereince any problems with the monitor then it is ok
Aug 10, 2008 | Tiny Computers B1996 19" CRT Monitor
Going to Sleep Displayed
I turned on my computer and the monitor displayed this message on the screen "going to sleep no input received". I checked the power cord and unplugged it, nothing. No lights are flashing or beeping sounds. The CPU is working just fine, anyone have any idea what to do
Aug 02, 2008 | HP vs19 (Silver) 19" LCD Monitor
LCD Monitor - green power light blinking - nothing on monitor
Carol,
It sounds like your computer is putting the monitor in power save or sleep mode, and the monitor doesn't respond appropriately. The monitor might be faulty, or overheating. Make sure there is adequate ventilation around the monitor, and that it is clean and free from dust around the vents on the case.
Another thing to try is to check your computer's screen saver and power saving settings. Try turning off the "turn off monitor after [interval]" setting and see if the monitor still shuts off after several hours.
Good luck, hope this helps.
Jun 10, 2008 | Gateway FPD2275W LCD Monitor
Problem in AOC 17
Your second step in troubleshooting this problem (after you check the connections) is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is probably shot.
May 09, 2008 | AOC CT720G 17" CRT Monitor
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
